在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3925|回复: 0
[原创] 寻找最优路径解
发表于 2020-12-16 23:09:10 来自手机 | 显示全部楼层 |阅读模式
由于对智能感知世界的初始化的要求,一个灵感可能比一个来自脉冲波多吗?好像智能就是来自于多次选择,然后计算权重,最终得出的最优序列集合。这些发现在本质上具有高度启发性。
because of initialization requirements, was one more than the inspiration came from an impulse wave? as through the intelligence is based on the selection that to compute the weight optimal sequence. these discoveries are highly heuristic in nature.
GMT+8, 2024-5-5 03:31 , Processed in 0.014544 second(s), 6 queries , Gzip On, Redis On.
