Specifying Clock-Tree Layer Constraints
To specify clock-tree layer constraints, use the set_clock_routing_rules command. By
default, net-specific minimum layer constraints are soft constraints, while net-specific
maximum layer constraints are hard constraints. Use the following options to set the
constraints and change the default behavior.
