在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 2214|回复: 0
[求助] 关于上位机串口接收的问题
发表于 2020-11-12 16:57:58 | 显示全部楼层 |阅读模式
#include <stdio.h>
#include <windows.h>
#include <string.h>
#include <conio.h>
#include "tchar.h"
void send()
    /*****************************打开串口***********************************/
HANDLE hCom;//全局变量,串口句柄
COMMTIMEOUTS TimeOuts;
DCB dcb;
DWORD dwWriteLen=0 ;
   // DWORD dwWriteLen = 0;
int data_in;
unsigned char sendData[1];//写入串口缓存区的数据
DWORD dwError;
COMSTAT cs;
//int error = GetLastError();
   hCom = CreateFile(_T("COM4"),
        GENERIC_READ | GENERIC_WRITE,//读写
        0,//独占方式
        NULL,
        OPEN_EXISTING,
        0,//同步方式
        //FILE_ATTRIBUTE_NORMAL|FILE_FLAG_OVERAPPLE,//重叠方式
        NULL);
    if (hCom==INVALID_HANDLE_VALUE )
       printf("send open failed");
// printf("CreateFile() error:%d", GetLastError());
else
        printf("send open successed\n");
    /**************配置串口************/
   SetupComm(hCom, 20480, 20480);//缓冲区
  //  COMMTIMEOUTS TimeOuts;
    TimeOuts.ReadIntervalTimeout = 1000;//读超时
    TimeOuts.ReadTotalTimeoutMultiplier = 500;
    TimeOuts.ReadTotalTimeoutConstant = 5000;
    TimeOuts.WriteTotalTimeoutMultiplier = 500;//写超时
    TimeOuts.WriteTotalTimeoutConstant = 2000;
    SetCommTimeouts(hCom, &TimeOuts);//设置超时
    //DCB dcb;
    GetCommState(hCom, &dcb);
    dcb.BaudRate = 115200;//波特率115200
    dcb.ByteSize = 8;//8bit/byte
    dcb.Parity = NOPARITY;//无奇偶校验位
    dcb.StopBits = ONESTOPBIT;//一个停止位
    dcb.fParity = FALSE;
    dcb.fNull = FALSE;
    SetCommState(hCom, &dcb);
  //  PurgeComm(hCom, PURGE_TXCLEAR|PURGE_RXCLEAR);//读写串口前清空缓冲区
    /*******同步读写串口********/
scanf("%x",&data_in);
printf("%d",&data_in);
//sendData[1]=(data_in&0x80) && 1;//拆
sendData[0]=data_in;//拆
//data_in=data_in<<1;
   ////////////////查看缓存区字节长度//////////////////
  if(!WriteFile(hCom,sendData,1,&dwWriteLen, NULL))
        printf("send failed\n");
    printf("send successed\n");
      printf("send data is\n");
         printf("%x\n", sendData[0]);
// return 1;
if (!ClearCommError(hCom, &dwError, &cs))
     printf("ClearCommError() failed\n");
else
printf("ClearCommError() successed\n");
printf("cs.cbOutQue=%d\n",cs.cbOutQue);
printf("cs.cbInQue=%d\n",cs.cbInQue);
    /***********关闭串口***********/
CloseHandle(hCom);
int receive()
HANDLE hCom;
DCB dcb1;
int i;
DWORD wCount =1;
     DWORD wCount1;
DWORD dwError;
COMSTAT cs;
//DWORD lpErrors;
        unsigned char str[1];
        0,
        NULL,
        OPEN_EXISTING,
        0,
        NULL);
        printf("read open failed\n");
    else
        printf("read open successed\n");
   // DCB dcb1;
    GetCommState(hCom, &dcb1);
    dcb1.BaudRate = 115200;
    dcb1.ByteSize = 8;//一个字节8bit
    dcb1.Parity = NOPARITY;//无校验
    dcb1.StopBits = ONESTOPBIT;//1位停止位
    dcb1.fParity = FALSE;
    dcb1.fNull = FALSE;
    SetCommState(hCom, &dcb1);
//PurgeComm(hCom, PURGE_TXCLEAR|PURGE_RXCLEAR);
  PurgeComm(hCom, PURGE_TXCLEAR);
   ////////////////查看缓存区字节长度//////////////////*/
else
        if(!ReadFile(hCom, str,wCount , &wCount1, NULL))
            printf("read failed!\n");
else
        printf("read successed!\n");
        printf("read actual length:%d\n", wCount1);
printf("read data is\n");
for(i=0;i<wCount1;i++)
  printf("%02X\n", str);
CloseHandle(hCom);
system("pause");
return str[0];
int main()
send();
receive();
在一个进程里实现串口先后写和读(对同一个串口),硬件上短接com的2,3脚,实现自收自发。但运行出来的是写数据成功,接收有问题,接收缓存区没有数据,自然读不出来。
串口监听精灵里显示“写入成功→IRP_MJ_CLEANUP→关闭串口→打开串口→配置串口→IRP_MJ_CLEANUP→关闭串口,但是并没有执行读串口操作,
经调试发现,如果在写完串口没有关闭的时候,在同一个函数(send)里此刻去读,就能读出来。
该怎么样实现用两个函数去分别读写呢,小妹分不多,倾囊求助。
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 13:24 , Processed in 0.015943 second(s), 6 queries , Gzip On, Redis On.
