在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 12853|回复: 13
[求助] 求助,cadence pss仿真不收敛-
发表于 2020-10-27 12:25:57 | 显示全部楼层 |阅读模式
Warning from spectre.
WARNING (SPECTRE-16707): Only tran supports psfxl format, result of other analyses will be in psfbin format.
Periodic Steady-State Analysis `pss': fund = 10 GHz
Trying `homotopy = gmin' for initial conditions.
Trying `homotopy = source' for initial conditions.
Trying `homotopy = dptran' for initial conditions...........
Trying `homotopy = ptran' for initial conditions..
Trying `homotopy = arclength' for initial conditions.
None of the instantiated devices support arclength homotopy. Skipping.
Error found by spectre during IC analysis, during periodic steady state analysis `pss'.
    ERROR (SPECTRE-16385): There were 7 attempts to find the DC solution. In some of those attempts, a signal exceeded the blowup limit of its quantity. The last signal that failed is I(L0:1) = 2.20676 GA, for which the quantity is `I' and the blowup limit is (1 GA). It is possible that the circuit has no DC solution. If you really want signals this large, set the `blowup' parameter of this quantity to a larger value.
    ERROR (SPECTRE-16080): No DC solution found (no convergence).
这是我的电路图 输入匹配做不了,sp仿真也报错。
 楼主| 发表于 2020-10-27 12:26:51 | 显示全部楼层
两个s5p 是两个巴伦
发表于 2020-11-15 04:02:24 | 显示全部楼层
interesting topic
发表于 2020-11-15 04:05:00 | 显示全部楼层
interesting topic
 楼主| 发表于 2021-3-11 13:08:28 | 显示全部楼层
解决了,pss仿真时,换一下引擎就行了
发表于 2021-3-29 23:13:11 | 显示全部楼层
学习学习
发表于 2021-10-21 14:50:02 | 显示全部楼层
刚刚解决,电源全部用vpwl。
发表于 2021-12-1 15:14:02 | 显示全部楼层
zxkzxk 发表于 2021-3-11 13:08
解决了,pss仿真时,换一下引擎就行了
请问一下是换了什么引擎呢 谢谢大哥
 楼主| 发表于 2021-12-14 21:35:33 | 显示全部楼层
VincentLsy 发表于 2021-12-1 15:14
请问一下是换了什么引擎呢 谢谢大哥
谐波平衡
发表于 2022-3-1 14:28:29 | 显示全部楼层
学习一下
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 04:23 , Processed in 0.028536 second(s), 7 queries , Gzip On, Redis On.
