楼主 |
发表于 2020-10-10 10:51:15
显示全部楼层
Analog Senior Design Engineer – NAND Flash Memory
Job Description:
As senior Design engineer in YMTC Shanghai Design Team, you will be responsible to design the analog/Mixed signal circuitry with the state of art 3D NAND Flash Memory technology. You will work with different function groups not only inside design department but also product engineering, process integration, marketing to deliver the memory products.
In charge of multi-voltage domain power supply system for NAND VLSI SOC
Responsible for high voltage system design for 3D NAND Memory, including positive and negative pump design
Power Supply for high speed IO include LDO and DC-DC converter
Power Grid for state of art 3D NAND VLSI design
Reference system design for 3D NAND VLSI including bandgap, Power loss detector and power loss management
Guide Layout Engineer for floorplan and layout performance improvement/ die size optimization
Conducts evaluation of design results by laboratory measurement of ICs
Reliability analysis and design solution for 3D NAND reliability issue
SPEC definition of the analog circuitry to meet the product requirement
Design for testing circuitry
Support product engineer for silicon test and debug
Requirements:
a.Master with 3+ years’ experience or Bachelor with 5+ years’ experience
b.Solid knowledge and experience on analog/mixed signal design, semiconductor process
c.Familiar with EDA tools such as Virtuoso,hspice, finesim etc
d.Experience for memory design is a plus
e.Good team player
f.Good presentation skill
g.Self-motivated
h.Good communication skill in both written and Oral English |
