Hi all
我在安装Jazz的时候,启动icfb命令提示报错,没有这个命令
我直接用cadence启动,进行版图编辑,启用make editable报错,报错如下
*WARNING* (DB-320030): dbReOpen: Opening the cellview 'ph18/cmim2_m2_2t/layout' in read-only mode because the design has Photonics data present and the virtuoso_Photonics_Option was not set. Set the shell environment variable virtuoso_Photonics_Option to 1 in your environment and restart the application.
我使用grep来查找也没找到该相关参数
