在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 4893|回复: 7
[已解决]Innovus v20.11-s130_1无法使用TSMC N28 HPC+PDK
发表于 2020-9-22 22:31:39 | 显示全部楼层 |阅读模式
如题,在导入lef文件时报错。不知道是不是还需要其他文件
Loading LEF file ../tcbn28hpcplusbwp40p140_180b/AN61001_20180509/TSMCHOME/digital/Back_End/lef/tcbn28hpcplusbwp40p140_110a/lef/tcbn28hpcplusbwp40p140.lef ...
**ERROR: (IMPLF-53):        The layer 'M1' referenced in pin 'Z' in macro 'AN2D0BWP40P140' is not found in the database. A layer must be defined in the LEF technology LAYER section before it can be referenced from a macro. Review the LEF files specified in the init_lef_file variable to see if the layer does not exist or is specified after the one that defines the macro.
Type 'man IMPLF-53' for more detail.
**ERROR: (IMPLF-3):        Error found when processing LEF file '../tcbn28hpcplusbwp40p140_180b/AN61001_20180509/TSMCHOME/digital/Back_End/lef/tcbn28hpcplusbwp40p140_110a/lef/tcbn28hpcplusbwp40p140.lef'. The subsequent file content is ignored. Refer to error messages above for details. Fix the errors, and restart 'Innovus' again.
Type 'man IMPLF-3' for more detail.
**ERROR: (IMPLF-26):        No technology information is defined in the first LEF file.
Please rearrange the LEF file order and make sure the technology LEF file is the
first one, exit and restart Innovus.
**ERROR: (IMPSYT-16013):        Loading LEF file(s) failed, and has aborted. Refer to error messages above for details. Please exit the tools and fix the errors first, then re-load design again.
Innovus 版本:
Version:        v20.11-s130_1, built Wed Aug 5 15:53:11 PDT 2020
PDK:
tcbn28hpcplusbwp40p140_180b : tcbn28hpcplusbwp40p140_110a_sef.tar.gz
解决方法:
第一个lef引入来自于tn28clpr********.tar.gz/N28_PRTF_Cad_v****/PR_tech/Cadence/LefHeader/VHV的*.tlef来解决问题
发表于 2020-9-23 10:12:03 | 显示全部楼层
没有tech lef
发表于 2020-9-23 15:05:45 | 显示全部楼层
类似 XXXXXXXXXXXX_8m0t1h0a1u.lef
发表于 2020-9-23 15:09:36 | 显示全部楼层
最常见就是  XX_1P9M0t1h0a
表示 1层poly 9层 金属,其中 1层是TOP,1层特别厚的。。。。之类
发表于 2020-9-23 15:10:28 | 显示全部楼层
名字就叫 technology lef file
发表于 2020-12-26 09:52:53 | 显示全部楼层
good job
发表于 2021-3-23 18:49:48 | 显示全部楼层
请问一下2018版的innovus能用tlef吗?
发表于 2022-6-21 11:08:05 | 显示全部楼层
有没有器件耐压参数啊
GMT+8, 2024-4-27 11:14 , Processed in 0.037713 second(s), 6 queries , Gzip On, Redis On.
