randolpha 发表于 2020-8-28 16:09
To optimize leakage power, replace the set_max_leakage_power command with the
set_multi_vth_constrai ...
If I enter this command'set_multi_vth_constraint -lvth_percentage 0 ', there will be an error "Cannot specify the -lvth_percentage argument without -lvth_groups arguments."
How do I set up my "groups" by using -lvth_groups arguments?
sorry to bother you
To enable leakage power optimization, use the set_multi_vth_constraint command.
For example,
de_shell> set_multi_vth_constraint -lvth_groups {lvt svt} \
-lvth_percentage 15 -type soft -cost cell_count
When running this command in DC Explorer, you should specify the cell_count
keyword with the -cost option for the percentage of low threshold-voltage cells in the
design.
