各位大神好,最近遇到一个vcs仿真的问题,为了能用vivado2019.2版本,我升级了VCS到vcs mx 201606,但是跑起来的时候报错,见红色字体部分,请问这是什么原因呢?
Warning-[LNX_OS_VERUN] Unsupported Linux version
Linux version 'CentOS release 5.7 (Final)' is not supported on 'x86_64'
officially, assuming linux compatibility by default. Set VCS_ARCH_OVERRIDE
to linux or suse32 to override.
Please refer to release notes for information on supported platforms.
Chronologic VCS (TM)
Version L-2016.06_Full64 -- Thu Jul 23 14:46:57 2020
Copyright (c) 1991-2016 by Synopsys Inc.
ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Warning-[LCA_FEATURES_ENABLED] Usage warning
LCA features enabled by '-lca' argument on the command line. For more
information regarding list of LCA features please refer to Chapter "LCA
features" in the VCS/VCS-MX Release Notes
Parsing design file '/home/ftm2000/working/xilinx_ip_core/Vivado_ip_core_2019/data/secureip/gthe2_channel_fast/gthe2_channel_fast_001.vp'
Error-[DECSPE] Decryption failed
Error while decrypting source file
Failed to load key needed to decrypt data_block. No key_block found for VCS.
Please use vcs RSA public key and pragma expressions to identify the
keyblock mentioned in vcs documentation while encrypting to be able to
decrypt with vcs.
", 593
1 warning
1 error
cpu time: .107 seconds to compile
compiled complete...
mri_sim: Command not found.
simulated successfully, and finished...
in output vcs_sim module
