在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2891|回复: 9
[求助] System Vue制作IBIS-AMI模型遇到的问题
发表于 2020-5-9 13:43:14 | 显示全部楼层 |阅读模式
大神们好,最近用system vue2020制作IBIS-AMI模型过程中,生成C++代码编译的时候出现cmake异常退出的报错,有大神们遇到过吗?帮忙解答下,万分感谢
发表于 2020-5-9 15:20:50 | 显示全部楼层
看编译log啊,这里没有任何有价值的提示
 楼主| 发表于 2020-5-9 17:52:51 | 显示全部楼层
您好,编译log如下,也搞不清楚,多谢
 楼主| 发表于 2020-5-9 17:58:30 | 显示全部楼层
xem07 发表于 2020-5-9 17:52
您好,编译log如下,也搞不清楚,多谢
output of RandomBitsGeneratorTimed 'Design1.B1': Sample Rate of this signal defaulting to the System Sample Rate ( 1.0e+01 GHz ).
BlindFFE 'Design1__Subnetwork1.B1': The parameters: Coefficients, SamplesPerBit, use the evaluated values in the generated code.
TimeResponseFIR 'Design1__Subnetwork1.T1': The parameters: ResponseType, Response, ResponseTimeStamps, ResponseFile, use the evaluated values in the generated code.
The parameters: SampleRate, use the translated expressions in the generated code. The expressions assume the parameters are either unitless or use the MKS units.
-- CMake started
CMake Warning (dev) at C:/Program Files/Keysight/SystemVue2020/ModelBuilder/CMake/ModelBuilder.cmake:9 (set):
  implicitly converting 'TYPE' to 'STRING' type.
Call Stack (most recent call first):
  C:/Program Files/Keysight/SystemVue2020/ModelBuilder/CMake/CodeGeneration.cmake:9 (include)
  CMakeLists.txt:11 (include)
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Forcing /MD.
-- Configuring incomplete, errors occurred!
See also "E:/Myworkspace/AMI_Modeling/build-win64-vs2017/CMakeFiles/CMakeOutput.log".
CMake Error at CMakeLists.txt:13 (project):
  Generator
    Visual Studio 15 2017 Win64
  could not find any instance of Visual Studio.
-- CMake exited abnormally.
发表于 2020-5-9 18:22:22 | 显示全部楼层
没有安装VS ?
 楼主| 发表于 2020-5-10 14:42:54 | 显示全部楼层
安装了VS2015
 楼主| 发表于 2020-5-10 15:47:41 | 显示全部楼层
终于用system vue2016搭配VS2013编译通过了,不知道是不是版本的原因,供参考
发表于 2020-5-10 18:09:52 | 显示全部楼层
vs2015相比vs2013变化还是很大的,最显著的就是stdio一些函数内联化,比如 printf 以及 iob_func等,需要用 导入legacy_stdio_definitions.lib进行编译
发表于 2023-12-26 17:57:40 | 显示全部楼层
大佬,请问可以加一个私人联系方式吗?我最近也在用SV做AMI建模,想要与您探讨
发表于 2023-12-27 09:08:16 | 显示全部楼层
phoenixson 发表于 2020-5-10 18:09
vs2015相比vs2013变化还是很大的,最显著的就是stdio一些函数内联化,比如 printf 以及 iob_func等,需要用 ...
大佬,请问方便加一个私人联系方式吗
GMT+8, 2024-3-29 13:26 , Processed in 0.031928 second(s), 7 queries , Gzip On, Redis On.
