在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2406|回复: 5
有关启动installscape遇到的问题,请求指点。
发表于 2020-4-27 10:42:18 | 显示全部楼层 |阅读模式
首先sh iscape.sh 会报错。如下:Initializing InstallScape using JVM at /home/software/IScape/IScape04.23-s008lnx86.t/iscape.04.23-s008/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/software/IScape/IScape04.23-s008lnx86.t/iscape.04.23-s008/runtime/LNX86/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(Unknown Source)
        at java.lang.ClassLoader.loadLibrary(Unknown Source)
        at java.lang.Runtime.load0(Unknown Source)
        at java.lang.System.load(Unknown Source)
        at java.lang.Runtime.loadLibrary0(Unknown Source)
        at java.lang.System.loadLibrary(Unknown Source)
        at sun.security.action.LoadLibraryAction.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.awt.Toolkit.loadLibraries(Unknown Source)
        at java.awt.Toolkit.<clinit>(Unknown Source)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:107)
论坛中搜索的方法
1.yum install glibc.i686 libXtst.i686
提示:
Loaded plugins: fastestmirror, refresh-packagekit, security
Setting up Install Process
Loading mirror speeds from cached hostfile
* base: mirror.bit.edu.cn
* extras: mirror.bit.edu.cn
* updates: mirror.lzu.edu.cn
http://mirror.bit.edu.cn/centos/ ... epodata/repomd.xml: [Errno 14] PYCURL ERROR 6 - "Couldn't resolve host 'mirror.bit.edu.cn'"
Trying other mirror.
2.$ sudo apt-get install libxtst6:i386
提示:bash: $: command not found
解释:这个我是在/usr/lib64里直接su后运行的,这个路径下有libXext.so.6
 楼主| 发表于 2020-4-27 10:46:19 | 显示全部楼层
第一次弄这个,所以一头雾水,还望高手指点。
发表于 2020-4-27 14:53:32 | 显示全部楼层
什么系统?
 楼主| 发表于 2020-4-27 14:56:16 | 显示全部楼层
您好,CentOS,我已经安装了i686(32位),但是提示和64不能共存,我是不是必须删掉64位的?
以下是报错:
Protected multilib versions: libXtst-1.2.3-1.el6.i686 != libXtst-1.2.2-2.1.el6.x86_64
 楼主| 发表于 2020-4-27 15:33:55 | 显示全部楼层
OK,已经成功了。
yum XXX --setopt=protected_multilib=false,虽然想解决并不想用--setopt,但是实在搞不懂,就这样吧。
发表于 2023-11-22 16:58:18 | 显示全部楼层
ubuntu 下  apt-get install libxrender1:i386 libxtst6:i386 libxi6:i386
GMT+8, 2024-4-25 12:04 , Processed in 0.021196 second(s), 6 queries , Gzip On, Redis On.
