在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3471|回复: 5
[求助] 求:用skill做schematic器件的替换
发表于 2020-4-26 10:17:12 | 显示全部楼层 |阅读模式
Find and Replace只能替换一个参数,不能同时替换library name 和 cell name.
谁能分享skill 脚本?谢谢
发表于 2020-5-22 04:17:49 | 显示全部楼层
Hi...
Contact me for skill script automation services.
 楼主| 发表于 2020-8-4 18:01:10 | 显示全部楼层
已有方案能凑合 用。
发表于 2020-8-12 16:45:49 | 显示全部楼层
可以试试在find/replace下拉列表中选择master, 可以同时替换lib, cell和view
Search For lets you specify the search criteria.
The cyclic field contains a list of frequently used properties.
When you select master from the cyclic field, you must specify a property value. You
cannot use wildcards for master property values.
Replace With lets you specify values for the replace action.
cannot use wildcards for master property values. You must type the exact value.
When you select master from the list of property names, you must specify a property value of the form "libname cellname viewname"
发表于 2020-9-11 23:24:48 | 显示全部楼层
真是厲害~
 楼主| 发表于 2020-9-18 20:35:56 | 显示全部楼层
Search For lets you specify  ...
明白了。谢谢!!!
GMT+8, 2024-4-25 17:36 , Processed in 0.023670 second(s), 7 queries , Gzip On, Redis On.
