系统:Android 7.1 删除开机锁屏界面 diff --gita/frameworks/base/packages/SettingsProvider/res/values/defaults.xmlb/frameworks/base/packages/SettingsProvider/res/values/defaults.xml indexf4cefc2..7734cfd 100644 ---a/frameworks/base/packages/SettingsProvider/res/values/defaults.xml +++b/frameworks/base/packages/SettingsProvider/res/values/defaults.xml @@ -80,7 +80,7 @@ <string name="def_trusted_sound" translatable="false">/system/media/audio/ui/Trusted.ogg</string> <string name="def_wireless_charging_started_sound" translatable="false">/system/media/audio/ui/WirelessChargingStarted.ogg</string> - <bool name="def_lockscreen_disabled">false</bool> + <bool name="def_lockscreen_disabled">true</bool> <bool name="def_device_provisioned">false</bool> <integer name="def_dock_audio_media_enabled">1</integer>
