在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1476|回复: 2
[原创] assura41-617运行avview&
发表于 2019-10-30 22:54:57 | 显示全部楼层 |阅读模式
Sub version:                sub-version 4.1_USR5 (64-bit addresses)
*WARNING* envSetVal: Can't set the value of variable 'ignorePointsGravityForSmallTargets',
        in tool[.partition] 'layout' - it has not been registered.
*WARNING* envSetVal: Can't set the value of variable 'manualModePinSize',
*WARNING* envCyclicStringToIndex: could not find variable 'mergeScope'
*WARNING* envSetVal: Can't set the value of variable 'mergeScope',
*WARNING* envSetVal: Can't set the value of variable 'viaEnableValidPurposes',
*WARNING* envSetVal: Can't set the value of variable 'snapPatternFastSnapping',
*WARNING* envSetVal: Can't set the value of variable 'weChangeWireDirectionAfterVia',
*WARNING* envSetVal: Can't set the value of variable 'makeCellUseOriginForOffgridInst',
*WARNING* envSetVal: Can't set the value of variable 'localSnappingIgnoreGlobalGrids',
*WARNING* envCyclicStringToIndex: could not find variable 'manualPinRectJustify'
*WARNING* envSetVal: Can't set the value of variable 'manualPinRectJustify',
*WARNING* envSetVal: Can't set the value of variable 'copyNumber',
*WARNING* envCyclicStringToIndex: could not find variable 'netState'
*WARNING* envSetVal: Can't set the value of variable 'netState',
*WARNING* envCyclicStringToIndex: could not find variable 'viaCutSpacingMethod'
*WARNING* envSetVal: Can't set the value of variable 'viaCutSpacingMethod',
*WARNING* envCyclicStringToIndex: could not find variable 'viaCutClassOrientation'
*WARNING* envSetVal: Can't set the value of variable 'viaCutClassOrientation',
*WARNING* envCyclicStringToIndex: could not find variable 'pinLabelPlacementMode'
*WARNING* envSetVal: Can't set the value of variable 'pinLabelPlacementMode',
*WARNING* envSetVal: Can't set the value of variable 'photonicPinWidth',
*WARNING* envCyclicStringToIndex: could not find variable 'alignToolBarReferenceObject'
*WARNING* envSetVal: Can't set the value of variable 'alignToolBarReferenceObject',
*WARNING* envSetVal: Can't set the value of variable 'propEditViaCompuEnclosures',
*WARNING* envSetVal: Can't set the value of variable 'weUseMTFlightLines',
*WARNING* envSetVal: Can't set the value of variable 'autoZoomScale',
*WARNING* envSetVal: Can't set the value of variable 'viaMaximizeCuts',
*WARNING* envSetVal: Can't set the value of variable 'viaUseEntireOverlap',
*WARNING* envSetVal: Can't set the value of variable 'drdPegasusIntFunctionalPresets',
*WARNING* envSetVal: Can't set the value of variable 'weEnableDanglingTargetsFL',
*WARNING* envSetVal: Can't set the value of variable 'autoModePinSizeFromPath',
*WARNING* envSetVal: Can't set the value of variable 'preserveTermName',
*WARNING* envSetVal: Can't set the value of variable 'viaPrintStatisticsReport',
*WARNING* envSetVal: Can't set the value of variable 'viaReplaceExistingVias',
*WARNING* envSetVal: cyclic value for variable 'pasteRef'
        is out of the choice range 0..9.
*WARNING* envSetVal: Can't set the value of variable 'pinTextPurposeNames',
*WARNING* envSetVal: Can't set the value of variable 'pinStep',
*WARNING* envSetVal: Can't set the value of variable 'weEnableXLCheckoutInL',
*WARNING* envSetVal: Can't set the value of variable 'autoCopyTemplateCellViewList',
*WARNING* envCyclicStringToIndex: could not find variable 'drdEditDensityTypeCheck'
*WARNING* envSetVal: Can't set the value of variable 'drdEditDensityTypeCheck',
*WARNING* envSetVal: Can't set the value of variable 'weInteractiveShielding',
*WARNING* envSetVal: Can't set the value of variable 'viaCheckBlockageTypes',
*WARNING* envCyclicStringToIndex: could not find variable 'pinLPP'
*WARNING* envSetVal: Can't set the value of variable 'pinLPP',
*WARNING* envSetVal: Can't set the value of variable 'weFlightLinesHierLevel',
*WARNING* envSetVal: Can't set the value of variable 'QAMaxPixelsPerMilliSec',
*WARNING* envSetVal: Can't set the value of variable 'enablePinEnhancements',
*WARNING* envCyclicStringToIndex: could not find variable 'descendEIPPopupSelectionWindow'
*WARNING* envSetVal: Can't set the value of variable 'descendEIPPopupSelectionWindow',
*WARNING* envSetVal: Can't set the value of variable 'slotEnable',
*WARNING* envSetVal: Can't set the value of variable 'chopSpecifySpacing',
*WARNING* envSetVal: Can't set the value of variable 'autoPinLayerFunctionsList',
*WARNING* envSetVal: Can't set the value of variable 'trimEnable',
*WARNING* envSetVal: Can't set the value of variable 'searchDepthForAutoPin',
*WARNING* envCyclicStringToIndex: could not find variable 'manualPinCircleJustify'
*WARNING* envSetVal: Can't set the value of variable 'manualPinCircleJustify',
*WARNING* envCyclicStringToIndex: could not find variable 'chopCircleJustify'
*WARNING* envSetVal: Can't set the value of variable 'chopCircleJustify',
*WARNING* envSetVal: Can't set the value of variable 'drdEditSlidingWindowSize',
*WARNING* envCyclicStringToIndex: could not find variable 'snapPatternSnappingDepthMethod'
*WARNING* envSetVal: Can't set the value of variable 'snapPatternSnappingDepthMethod',
*WARNING* envSetVal: Can't set the value of variable 'drdEditMaxHaloLimit',
*WARNING* envSetVal: Can't set the value of variable 'snapPatternFastDetailModeSnapping',
*WARNING* envCyclicStringToIndex: could not find variable 'pinStepOption'
*WARNING* envSetVal: Can't set the value of variable 'pinStepOption',
*WARNING* envSetVal: Can't set the value of variable 'enableAlignToolBarReferenceObject',
*WARNING* envCyclicStringToIndex: could not find variable 'viaAutoViaEnclosureDirection'
*WARNING* envSetVal: Can't set the value of variable 'viaAutoViaEnclosureDirection',
*WARNING* envSetVal: Can't set the value of variable 'probeInstDisplayRadio',
*WARNING* envSetVal: Can't set the value of variable 'rotateInstParam',
*WARNING* envSetVal: Can't set the value of variable 'createInstResetCDF',
*WARNING* envSetVal: Can't set the value of variable 'enableCopyAndPaste',
*WARNING* envSetVal: Can't set the value of variable 'chopLineUserWidth',
*WARNING* envSetVal: Can't set the value of variable 'chopSpecifySize',
*WARNING* envSetVal: Can't set the value of variable 'drdEditEnableBatchCheckOnReadOnlyDesign',
*WARNING* envCyclicStringToIndex: could not find variable 'chopLineJustify'
*WARNING* envSetVal: Can't set the value of variable 'chopLineJustify',
*WARNING* envCyclicStringToIndex: could not find variable 'removeTerminals'
*WARNING* envSetVal: Can't set the value of variable 'removeTerminals',
*WARNING* envSetVal: Can't set the value of variable 'displayFigGroupName',
*WARNING* envSetVal: Can't set the value of variable 'snapPatternSnapToXYGridFirst',
*WARNING* envCyclicStringToIndex: variable 'autoZoomMode' in tool[.partition] 'layout'
        must be of type cyclic
*WARNING* envSetVal: type mismatch for variable 'autoZoomMode'
        in tool[.partition] 'layout'.
*WARNING* envSetVal: Can't set the value of variable 'chopRectHeight',
*WARNING* envSetVal: Can't set the value of variable 'enablePinStepOption',
*WARNING* envSetVal: Can't set the value of variable 'snapResizeWireObjects',
*WARNING* envSetVal: Can't set the value of variable 'weCoverPin',
*WARNING* envSetVal: Can't set the value of variable 'enableCutColorSupport',
*WARNING* envSetVal: Can't set the value of variable 'mergeEnable',
*WARNING* envSetVal: Can't set the value of variable 'chopRectWidth',
*WARNING* envSetVal: Can't set the value of variable 'viaAlignCuts',
*WARNING* envCyclicStringToIndex: could not find variable 'chopLineType'
*WARNING* envSetVal: Can't set the value of variable 'chopLineType',
*WARNING* envSetVal: Can't set the value of variable 'boundarySnapXGrids',
*WARNING* envSetVal: Can't set the value of variable 'realignLabelToPinCenter',
*WARNING* envSetVal: Can't set the value of variable 'weViaCutColorPatterns',
*WARNING* envCyclicStringToIndex: could not find variable 'copySpacingMode'
*WARNING* envSetVal: Can't set the value of variable 'copySpacingMode',
*WARNING* envSetVal: Can't set the value of variable 'updateLabelLPPWithPin',
*WARNING* envSetVal: Can't set the value of variable 'viaPreventDRCOnOverlap',
*WARNING* envSetVal: Can't set the value of variable 'boundarySnapYGrids',
*WARNING* envSetVal: Can't set the value of variable 'photonicPinAngle',
*WARNING* envCyclicStringToIndex: could not find variable 'chopRectJustify'
*WARNING* envSetVal: Can't set the value of variable 'chopRectJustify',
*WARNING* envSetVal: Can't set the value of variable 'viaValidPurposes',
*WARNING* envCyclicStringToIndex: could not find variable 'copyOrder'
*WARNING* envSetVal: Can't set the value of variable 'copyOrder',
*WARNING* envSetVal: Can't set the value of variable 'manualPinRectWidth',
*WARNING* envSetVal: Can't set the value of variable 'QAHoldTimeMilliSec',
*WARNING* envSetVal: Can't set the value of variable 'snapPatternSnappingDepth',
*WARNING* envSetVal: Can't set the value of variable 'weCustomLayerPattern',
*WARNING* envSetVal: Can't set the value of variable 'dynamicMeasurementTextColor',
*WARNING* envSetVal: Can't set the value of variable 'photonicPinRadius',
*WARNING* envCyclicStringToIndex: could not find variable 'updatePinIODirection'
*WARNING* envSetVal: Can't set the value of variable 'updatePinIODirection',
*WARNING* envSetVal: Can't set the value of variable 'manualPinCircleRadius',
*WARNING* envSetVal: Can't set the value of variable 'viaBlockageTypes',
*WARNING* envSetVal: Can't set the value of variable 'chopCircleRadius',
*WARNING* envSetVal: Can't set the value of variable 'manualPinRectHeight',
*WARNING* envSetVal: Can't set the value of variable 'viaPreventDRCWithNeighbors',
*WARNING* envCyclicStringToIndex: could not find variable 'makeCellOriginSnappingGrid'
*WARNING* envSetVal: Can't set the value of variable 'makeCellOriginSnappingGrid',
*WARNING* envSetVal: Can't set the value of variable 'ignoreParallelMinWidthForSquarePinResize',
*WARNING* envSetVal: Can't set the value of variable 'pinTextLayerNames',
*WARNING* ciwMenuLoadFile: system file "/opt/eda/ASSURA41/tools.lnx86/dfII/etc/tools/menus/avview.menus" not found.
如何解除警告路过的看到了,指点一下谢谢
 楼主| 发表于 2019-10-30 23:14:24 | 显示全部楼层
可以集成到virtuoso,用avview&打开有警告,哪里还不到位,没用过assura,
 楼主| 发表于 2019-10-31 09:15:00 | 显示全部楼层
*WARNING* ddRegTrigger: Couldn't find trigger named "POSTUPDATELIBLIST".
哪个目录下有现成的
GMT+8, 2024-4-25 17:18 , Processed in 0.031886 second(s), 7 queries , Gzip On, Redis On.
