- 1.Table of contents
- 2.Introduction to the Special Section on the 2018 IEEE BCICTS Conference Shahriar Shahramian
- 3.Analysis and Design of Wideband I/Q CMOS 100–200 Gb/s Modulators
- 4.Design of a 55-nm SiGe BiCMOS 5-bit Time-Interleaved Flash ADC for 64-Gbd 16-QAM Fiberoptics Applications
- 5.Broadband 240-GHz Radar for Non-Destructive Testing of Composite Materials
- 6.A Three-Stage 18.5–24-GHz GaN-on-SiC 4 W 40% Efficient MMIC PA
- 7.20-nm In0.8Ga0.2As MOSHEMT MMIC Technology on Silicon
- 8.A Fully Integrated 384-Element, 16-Tile, W -Band Phased Array With Self-Alignment and Self-Test
- 9.A 115–135-GHz 8PSK Receiver Using Multi-Phase RF-Correlation-Based Direct-Demodulation Method
- 10.A 0.34-THz Wideband Wide-Angle 2-D Steering Phased Array in 0.13- μ m SiGe BiCMOS
- 11.A 4-GHz Low-Power, Multi-User Approximate Zero-IF FM-UWB Transceiver for IOT
- 12.RF Filter Synthesis Based on Passively Coupled N-Path Resonators
- 13.A 1–2 GHz Computational-Locking ADPLL With Sub-20-Cycle Locktime Across PVT Variation
- 14.A 320-fs RMS Jitter and – 75-dBc Reference-Spur Ring-DCO-Based Digital PLL Using an Optimal-Threshold TDC
- 15.Analysis and Correction of Noise Injection Due to Parallel-Output-Misalignment (POM) Effects in Ring-Type Time-to-Digital Converters (TDCs)
- 16.A 1-V 175- μ W 94.6-dB SNDR 25-kHz Bandwidth Delta-Sigma Modulator Using Segmented Integration Techniques
- 17.A 9.1-ENOB 6-mW 10-Bit 500-MS/s Pipelined-SAR ADC With Current-Mode Residue Processing in 28-nm CMOS
- 18.Study and Design of a Fast Start-Up Crystal Oscillator Using Precise Dithered Injection and Active Inductance
- 19.Single-Chip 3072-Element-Channel Transceiver/128-Subarray-Channel 2-D Array IC With Analog RX and All-Digital TX Beamformer for Echocardiography
- 20.A 1.17-Megapixel CMOS Image Sensor With 1.5 A/D Conversions per Digital CDS Pixel Readout and Four In-Pixel Gain Steps
- 21.A Reconfigurable Cross-Connected Wireless-Power Transceiver for Bidirectional Device-to-Device Wireless Charging
- 22.Analysis and Design of a Multi-Step Bias-Flip Rectifier for Piezoelectric Energy Harvesting
- 23.Design of Sub-Gigahertz Reconfigurable RF Energy Harvester From −22 to 4 dBm With 99.8% Peak MPPT Power Efficiency
- 24.Self-Convergent Trimming SRAM True Random Number Generation With In-Cell Storage
- 25.Reconfigurable Clock Networks for Wide Voltage Scaling
- 26.IEEE Asian Solid-State Circuits Conference A-SSCC 2019Information For Authors
复制代码
