在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2192|回复: 16
[资料] JSSC 2019.08
发表于 2019-8-9 17:42:34 | 显示全部楼层 |阅读模式
如题。
实际上是一个PDF,有兴趣的同学帮忙切成单篇的再开一帖传上来。
jssc_201908.part1.rar (31 MB, 下载次数: 207 )
jssc_201908.part2.rar (31 MB, 下载次数: 184 )
jssc_201908.part3.rar (8.29 MB, 下载次数: 110 )
(以上文件为8月整月杂志的pdf,勿再下载)
2019.08.12更新:
没人愿意分割一下上面这个pdf合集,还是我来更新吧:
Table of contents.pdf (196.94 KB, 下载次数: 47 )
08.part1.rar (30 MB, 下载次数: 237 )
08.part2.rar (30 MB, 下载次数: 211 )
08.part3.rar (7 MB, 下载次数: 127 )
目录:
  1. A Sub-100 µm-Range-Resolution Time-of-Flight Range Image Sensor With Three-Tap Lock-In Pixels, Non-Overlapping Gate Clock, and Reference Plane Sampling
  2. Self-Timed Pulsed Latch for Low-Voltage Operation With Reduced Hold Time
  3. A 1.06-µW Smart ECG Processor in 65-nm CMOS for Real-Time Biometric Authentication and Personal Cardiac Monitoring
  4. An Energy-Efficient Reconfigurable DTLS Cryptographic Engine for Securing Internet-of-Things Applications
  5. An Instruction-Driven Adaptive Clock Management Through Dynamic Phase Scaling and Compiler Assistance for a Low Power Microprocessor
  6. 5–31-Hz 188-μW Light-Sensing Oscillator With Two Active Inductors Fully Integrated on Plastic
  7. High-Efficiency SiGe-BiCMOS E-Band Power Amplifiers Exploiting Current Clamping in the Common-Base Stage
  8. A 0.016 mm2 0.26-μW MHz 60–240-MHz Digital PLL With Delay-Modulating Clock Buffer in 65 nm CMOS
  9. A Differential Optical Receiver With Monolithic Split-Microring Photodetector
  10. A 12-b 1-GS_s 31.5-mW Time-Interleaved SAR ADC With Analog HPF-Assisted Skew Calibration and Randomly Sampling Reference ADC
  11. A Wireless Multi-Channel Peripheral Nerve Signal Acquisition System-on-Chip
  12. A 600-MS_s DAC With Over 87-dB SFDR and 77-dB Peak SNDR Enabled by Adaptive Cancellation of Static and Dynamic Mismatch Error
  13. A Low-Noise Chopper Amplifier Designed for Multi-Channel Neural Signal Acquisition
  14. A 763 pW 230 pJ Conversion Fully Integrated CMOS Temperature-to-Digital Converter With +0.81 C 0.75 C Inaccuracy
  15. A 25-Gb_s, 2.1-pJ_bit, Fully Integrated Optical Receiver With a Baud-Rate Clock and Data Recovery
  16. Interference Robust Detector-First Near-Zero Power Wake-Up Receiver
  17. A General Theory of Injection Locking and Pulling in Electrical Oscillators—Part II Amplitude Modulation in LC Oscillators, Transient Behavior, and Frequency Division
  18. A General Theory of Injection Locking and Pulling in Electrical Oscillators—Part I Time-Synchronous Modeling and Injection Waveform Design
  19. An IR-UWB CMOS Transceiver for High-Data-Rate, Low-Power, and Short-Range Communication
  20. A Broadband CMOS RF Front End for Direct Sampling Satellite Receivers
复制代码
发表于 2019-8-9 19:01:10 | 显示全部楼层
THANKS
发表于 2019-8-9 19:01:29 | 显示全部楼层
THANKS
发表于 2019-8-9 19:01:50 | 显示全部楼层
THANKS
发表于 2019-8-9 19:47:51 | 显示全部楼层
发表于 2019-8-9 22:00:48 | 显示全部楼层
多谢分享
发表于 2019-8-10 10:43:11 | 显示全部楼层
非常感謝!!!!!
发表于 2019-8-10 15:44:26 | 显示全部楼层
THANKS
发表于 2019-8-11 11:30:32 | 显示全部楼层
Thanks, 楼主能把每篇文章单独分离出来吗?
发表于 2019-8-11 17:40:59 | 显示全部楼层
感謝!感謝!
GMT+8, 2024-3-29 13:24 , Processed in 0.030093 second(s), 7 queries , Gzip On, Redis On.
