在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2205|回复: 0
[资料] 【成熟方案】转换IC/信号转换芯片NCS8805:RGB/LVDS-to-eDP Converter 带Scaler
发表于 2019-8-9 10:38:44 | 显示全部楼层 |阅读模式
**型号**:NCS8805
**产品特点**:低功耗,缩放效果好
**输入**:RGB/LVDS
**输出**:EDP
**封装**:QFN-56 (7mm x 7mm)
**最大分辨率**:2560*1600
【方案说明】适用于把L号通过NCS8805转换到不同显示分辨率的eDP屏。
【应用市场】广告机,TV
**eDP输出**:Embedded-DisplayPort (eDP) Output
1/2/4-lane eDP @ 1.62/2.7Gbps per lane
HD to WQXGA (2560*1600) supported
Up to 6dB pre-emphasis
**RGB输入**:RGB Input
18/24bit RGB Interface
Pixel clock up to 270MHz
SDR/DDR supported
Pin order reversal supported
**LVDS输入**:LVDS Input
Single/dual-channel 6/8bit LVDS interface
400Mbps to 1Gbps per data pair
Built-in termination
Channel and polarity swap supported
Scaler
Hi-Fidelity scaler
Fractional scaling ratio from 2:1 to 1:2
**参考时钟**:Reference Clock
Any freq. between 19MHz and 100MHz
Crystal or single-ended clock input
Built-in 5000ppm SSC generator
**其它**:Misc
I2C for chip configuration
Built-in eDP handshake protocol
I2C-AUX channel for TCON/DPCD/EDID
control
Built-in video test pattern
**功率**:Power
1.2V core supply
2.5V or 3.3V IO supply
RGB IO can go down to 1.8V
Deep-sleep mode power <5mW
~150mW @2048*1536 w/o scaling
~300mW @2048*1536 w/ scaling
**封装**:Package
QFN-56 (7mm x 7mm) package
RoHS Compliant
Sample available now
NCS8805_DS_V0p93.pdf
1.05 MB, 下载次数: 24 , 下载积分: 资产 -2 信元, 下载支出 2 信元
NCS8805
GMT+8, 2024-4-26 04:34 , Processed in 0.017924 second(s), 10 queries , Gzip On, Redis On.
