YLR-电流采样晶片电阻 Ultra Low Ohm Chip Resistors-YLR Series 产品特征: 阻值范围 Resistance value:1~100mΩ 精度 Tolerance:±1%、±2%、±5% 功率 Power:2W、3W 温度系数 Temperature coefficient ±50ppm/℃;±20ppm/℃ 推荐工作温度范围 Recommended operating temperature range:-55℃~155℃ 定做特殊规格 Customized special specification size 应用范围: ●过流保护 Over current protection ●电流取样 Current sense applications ●伺服电机控制电路 Servo motor control circuits ●智能功率模块 Intelligent power modules ●工业电脑模块及精密测量系统 industrial PC moduls and precision measurement system ● 高速cpu外围设备中电流检测电路 Current detection circuits in high-speed CPU peripherals
