检查时钟树,发现报了很多如下的warning,在waring的后面可以发现CKcheckpin1被识别为sink点了。
Warning: The phase delay skew of entrance pin pulpino_i/axi_interconnect_i/axi_node_i/u_RESP_BLOCK_GEN_0__RESP_BLOCK/DW_ADDR_DEC/MASTER_ID_FIFO/cg_cell_0/TLATNTSCAX4/CK in clock clk_gen is 0.817, larger than the threshold 0.050. (CTS-871)
The smallest early delay internal sink: pulpino_i/axi_interconnect_i/axi_node_i/u_RESP_BLOCK_GEN_0__RESP_BLOCK/DW_ADDR_DEC/MASTER_ID_FIFO/cg_cell_0/TLATNTSCAX4/CKcheckpin1 (early delay: -0.390 (type: SINK) )
The largest late delay output pin: pulpino_i/axi_interconnect_i/axi_node_i/u_RESP_BLOCK_GEN_0__RESP_BLOCK/DW_ADDR_DEC/MASTER_ID_FIFO/cg_cell_0/TLATNTSCAX4/ECK (late delay 0.428 (type: SINK) )
Warning: The phase delay skew of entrance pin pulpino_i/axi_interconnect_i/axi_node_i/u_RESP_BLOCK_GEN_1__RESP_BLOCK/DW_ADDR_DEC/MASTER_ID_FIFO/cg_cell_0/TLATNTSCAX4/CK in clock clk_gen is 0.816, larger than the threshold 0.050. (CTS-871)
The smallest early delay internal sink: pulpino_i/axi_interconnect_i/axi_node_i/u_RESP_BLOCK_GEN_1__RESP_BLOCK/DW_ADDR_DEC/MASTER_ID_FIFO/cg_cell_0/TLATNTSCAX4/CKcheckpin1 (early delay: -0.390 (type: SINK) )
The largest late delay output pin: pulpino_i/axi_interconnect_i/axi_node_i/u_RESP_BLOCK_GEN_1__RESP_BLOCK/DW_ADDR_DEC/MASTER_ID_FIFO/cg_cell_0/TLATNTSCAX4/ECK (late delay 0.426 (type: SINK) )
