在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 6360|回复: 14
[求助] 静态形式验证工具vc formal的资料哪位大侠有啊
发表于 2019-6-26 11:34:48 | 显示全部楼层 |阅读模式
具体如下网址:
https://www.synopsys.com/zh-cn/v ... tion/vc-formal.html
发表于 2020-8-14 18:15:01 来自手机 | 显示全部楼层
楼主有软件吗
发表于 2020-8-20 03:44:40 | 显示全部楼层
Wha information are you looking for?
Like tool performance?, or what does it do?.
VC Formal is a Formal verification tool that uses SystemVerilog assertions (that defines the properties/behavior of the design) as a "tesbench", and run mathematical models such as Bounded Model Checking (BMC), K-induction, and hybrid engines, to check the entire design state space with the goal of proving that the properties hold. If they do not, a counter example (CEX) is created. A CEX is a short waveform that shows where the design fails, and only uses the relevant signals.
VC Formal uses verdi as front end. VC is not the only formal tool out there. JasperGold from Cadence, OneSpin, and SymbiYosys does the same thing.
If you don't have VC Formal license, you can try SymbiYosys. That tool is free for Verilog 2005. For SystemVerilog you need a license (to use Verific as a parser), but you can request a demo licnse to try that as well.
Let me know if you have further questions.
发表于 2020-8-21 16:25:41 | 显示全部楼层
同问
发表于 2021-1-14 22:50:48 | 显示全部楼层
好好好
发表于 2021-5-30 17:06:39 | 显示全部楼层
同问,求有关vcf和形式验证断言的资料
发表于 2021-10-22 09:02:59 | 显示全部楼层
有人有user guide吗?
发表于 2021-12-2 17:07:34 | 显示全部楼层
Hi
How can I acquire VC Formal license that you mentioned?
I need VC formal app and its license.
Could you please help me?
Thanks
发表于 2022-7-18 21:43:15 | 显示全部楼层
敬田来 发表于 2021-12-2 17:07
Hi
有了吗?能否share一下?
发表于 2023-5-7 09:54:13 | 显示全部楼层
有人有user guide吗?
GMT+8, 2024-3-28 19:34 , Processed in 0.026609 second(s), 6 queries , Gzip On, Redis On.
