各位大佬,verilog初学者在hdlbits做题时遇到一个问题,mod_a没有被多次声明啊,为什么一直出现这个错误呢?代码如下:
module top_module ( input a, input b, output out );
mod_a instance2 ( .out(out), .in1(a), .in2(b) );
endmodule
module mod_a ( input in1, input in2, output out );
assign out=in1&in2;
endmodule
错误如下:
Error (10228): Verilog HDL error at tb_modules.sv(1): module "mod_a" cannot be declared more than once File: /var/www/verilog/work/vlghG3SJN_dir/tb_modules.sv Line: 1Info (10499): HDL info at top_module.v(4): see declaration for object "mod_a" File: /var/www/verilog/work/vlghG3SJN_dir/top_module.v Line: 4Info (12021): Found 0 design units, including 0 entities, in source file tb_modules.svError: Quartus Prime Analysis & Synthesis was unsuccessful. 1 error, 1 warning Error: Peak virtual memory: 1036 megabytes Error: Processing ended: Wed May 22 23:04:58 2019 Error: Elapsed time: 00:00:00 Error: Total cpu time (on all processors): 00:00:01Error (23031): Evaluation of Tcl script /var/www/verilog/template/compile.tcl unsuccessfulError: Quartus Prime Shell was unsuccessful. 7 errors, 1 warning Error: Peak virtual memory: 902 megabytes Error: Processing ended: Wed May 22 23:04:59 2019 Error: Elapsed time: 00:00:03 Error: Total CPU time (on all processors): 00:00:02
