查看: 20356|回复: 42
求个支持Cadence STRATUS的License
发表于 2019-3-15 10:49:04 | 显示全部楼层 |阅读模式
想学习尝试下Cadence的STRATUS,从论坛上下载安装了,但之前的crack license里面好像没有STRATUS这个feature。不知道哪位大佬有支持这个feature的license能共享一下嘛!谢谢!
启动的时候出现下面错误:
Unable to load library icui18n "Cannot load library icui18n: (icui18n: cannot open shared object file: No such file or directory)"
  ERROR 02518:# Failed to checkout license for feature 'Stratus_IDE'. ERROR   #
  ERROR 02518.#   (LMF-02005): License call failed for feature Stratus_IDE,   #
  ERROR 02518.#   version 17.000 and quantity 1. The license server search    #
  ERROR 02518.#   path is defined as /opt/EDA/cadence/license/license.dat.    #
  ERROR 02518.#   The FLEXnet error message is as follows,                    #
  ERROR 02518.#   FLEXnet ERROR(-5, 0, 0): No such feature exists.            #
  ERROR 02518.#   Run 'lic_error LMF-02005' for more information.             #
应该是缺少Stratus_IDE这个feature
发表于 2019-3-15 14:15:49 | 显示全部楼层
加了四个feature
Stratus_IDE
Stratus_HLS_L
Stratus_HLS_XL
Stratus_FloatingPoint
cadence.txt
153.96 KB, 下载次数: 509 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2019-3-16 14:55:39 | 显示全部楼层
Thanks . It's helpful.
发表于 2019-3-16 15:32:39 | 显示全部楼层
學習了
发表于 2019-3-16 16:39:08 | 显示全部楼层
Thanks
发表于 2019-3-17 00:52:00 | 显示全部楼层
Thank you.
发表于 2019-3-17 00:53:14 | 显示全部楼层
Thank you.
发表于 2019-3-17 18:53:29 | 显示全部楼层
paul0911 发表于 2019-3-15 14:15
加了四个feature
Stratus_IDE
 楼主| 发表于 2019-3-18 18:32:29 | 显示全部楼层
加了四个feature
Stratus_IDE
亲测可用,非常感谢这位兄弟!
发表于 2019-3-18 20:20:12 | 显示全部楼层
Thank you.
GMT+8, 2025-11-21 08:44 , Processed in 1.284028 second(s), 4 queries , Gzip On, Redis On.
