在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2275|回复: 0
[调查] dc_shell-t initialization error
发表于 2019-3-14 22:33:11 | 显示全部楼层 |阅读模式
When I ran the "dc_shell-t" in local directory after copy "synopsys_dc.setup" to local directory, I got the following messages:
Version V-2004.06-SP2-6 for linux -- Feb 18, 2005
Copyright (c) 1988-2004 by Synopsys, Inc.
ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys, Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Initializing...
Error: Cannot create procedure named 'group_variable' - existing command
Use error_info for more info. (CMD-013)
Error: Procedure 'group_variable' cannot be modified. (CMD-051)
Error: ::group_variable
Error: Cannot create procedure named 'print_variable_group' - existing command
Error: Procedure 'print_variable_group' cannot be modified. (CMD-051)
Error: ::print_variable_group
Error: Cannot create procedure named 'read_verilog' - existing command
Error: Procedure 'read_verilog' cannot be modified. (CMD-051)
Error: ::read_verilog
Error: Cannot create procedure named 'read_sverilog' - existing command
Error: Procedure 'read_sverilog' cannot be modified. (CMD-051)
Error: ::read_sverilog
Error: Cannot create procedure named 'read_vhdl' - existing command
Error: Procedure 'read_vhdl' cannot be modified. (CMD-051)
Error: ::read_vhdl
Error: Cannot create procedure named 'read_db' - existing command
Error: Procedure 'read_db' cannot be modified. (CMD-051)
Error: ::read_db
Error: Cannot create procedure named 'read_edif' - existing command
Error: Procedure 'read_edif' cannot be modified. (CMD-051)
Error: ::read_edif
Error: Cannot create procedure named 'read_ddc' - existing command
Error: Procedure 'read_ddc' cannot be modified. (CMD-051)
Error: ::read_ddc
dc_shell-t>
I found these errors were caused by two commands in .synopsys_dc.setup:
source $synopsys_root/auxx/syn/.dc_common_procs.tcl
source $synopsys_root/auxx/syn/.dc_procs.tcl
But the .synopsys_dc.setup file in my working direcory is the original one which synopsys provided. How can I avoid these error messages?
GMT+8, 2024-4-26 01:34 , Processed in 0.020590 second(s), 6 queries , Gzip On, Redis On.
