ET创芯网论坛(EETOP)
您现在是游客状态
请您   登录   或  注册  享受更多权益
查看: 459|回复: 0
[求助] 用lfsr仿真眼图,哪位遇到过这类问题?
发表于 2019-2-6 13:34:02 | 显示全部楼层 |阅读模式
您需要 登录 才可以下载或查看,没有帐号?注册
局部网表:
* StatEye example circuit
.param BW=10n
.param trf = 'BW*0.01'
.param opfreq = '1/BW'
P1 nd_in1 0 port=1 LFSR (1 -1 0 'trf' 'trf''opfreq' 3 [7, 3, 2, 1])
P2 nd_pin2 0 port=2
.stateye T='BW' trf='0.1*BW' incident_port=1 probe_port=2
运行结果提示:
Transient initialization complete.   Starting statEye analysis.
Warning: [STAT_EYE]  port 1 to port 2 signal propagation below the voltage tolerance, 1e-006
Error: [STAT_EYE error] pulse response acquisition failed.  check the pulse response in tr0 file
站长推荐上一条 /1 下一条
小黑屋|手机版|Archiver|ET创芯网 ( 京ICP备:10050787号 京公网安备:110105001212 )
GMT+8, 2019-4-22 08:18 , Processed in 0.054429 second(s), 10 queries , Redis On.
Powered by Discuz! X3.4
© 2001-2017 Comsenz Inc.
