在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1306|回复: 1
[资料] Fabrication and Characterization of CMOS-MEMS Thermoelectric Micro Generators
发表于 2019-1-29 10:39:57 | 显示全部楼层 |阅读模式
Fabrication and Characterization of CMOS-MEMS Thermoelectric Micro Generators.pdf (585.6 KB, 下载次数: 19 )
文中给出了一种采用CMOS工艺制备thermoelectric mirco generators的方法。工艺方法有借鉴作用,不过采用Al做刻蚀用的硬掩膜,会引出颗粒。
This work presents a thermoelectric micro generator fabricated by the commercial 0.35 μm complementary metal oxide semiconductor (CMOS) process and the post-CMOS process. The micro generator is composed of 24 thermocouples in series. Each thermocouple is constructed by p-type and n-type polysilicon strips. The output power of the generator depends on the temperature difference between the hot and cold parts in the thermocouples. In order to prevent heat-receiving in the cold part in the thermocouples, the cold part is covered with a silicon dioxide layer with low thermal conductivity to insulate the heat source. The hot part of the thermocouples is suspended and connected to an aluminum plate, to increases the heat-receiving area in the hot part. The generator requires a post-CMOS process to release the suspended structures. The post-CMOS process uses an anisotropic dry etching to remove the oxide sacrificial layer and an isotropic dry etching to etch the silicon substrate. Experimental results show that the micro generator has an output voltage of 67 μV at the temperature difference of 1 K.
发表于 2022-5-17 12:23:15 | 显示全部楼层
谢谢分享
GMT+8, 2024-4-25 23:37 , Processed in 0.018055 second(s), 7 queries , Gzip On, Redis On.
