查看: 2969|回复: 0
[原创] 【稳定方案】宏晶微MS7024:RGB888转CVBS/BT656转CVBS芯片方案
发表于 2018-12-4 20:46:29 | 显示全部楼层 |阅读模式
型号:MS7024
方案:RGB888转AV、BT656转AV
支持分辨率:720x480i/p、720x576i/p
应用:车载影音系统、机顶盒、楼宇广告机
Features
 Supports 24-bit/16-bit/8-bit digital input
 Supports various RGB and YCrCb input data formats
 Supports for input resolutions of 720×480 and 720×576 in interlace or progressive mode
 Supports ITU-R BT.601/656 standard input
 Brightness, contrast and saturation adjustable
 Fully programmed through a serial port
Output Formatter
 High quality 10-bit triple-DAC
 Supports analog AV and S-Video output
 Supports formats NTSC-M, NTSC-J, NTSC-433, PAL-B/D/G/H/I, PAL-M, PAL-N and PAL-60
 Supports hot plug detection
2-wire I2C Slave Interface Package
 TQFP -48 plastic(7mm×7mm)
 PB-free and RoHS compliant
GMT+8, 2025-12-24 13:07 , Processed in 0.011345 second(s), 4 queries , Gzip On, Redis On.
