在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3143|回复: 5
[求助] ICC建立milkyway库出现警告,求助
发表于 2018-11-16 20:22:32 | 显示全部楼层 |阅读模式
刚开始学习ICC,使用的是SMIC55nm库,在用create_mw_lib命令创建库时,出现下述警告:Warning: Layer 'M1' has rounded fat table thresholds '(0, 1, 5)'. (line 340) (TFCHK-055)
Warning: Layer 'RDL' is missing the attribute 'minArea'. (line 749) (TFCHK-012)
Warning: ContactCode 'VIA_RDV' is missing the attribute 'unitMinResistance'. (line 1295) (TFCHK-014)
Warning: ContactCode 'VIA_RDV' is missing the attribute 'unitNomResistance'. (line 1295) (TFCHK-014)
Warning: ContactCode 'VIA_RDV' is missing the attribute 'unitMaxResistance'. (line 1295) (TFCHK-014)
Warning: Layer 'M1' has a pitch 0.2 that does not match the recommended wire-to-via pitch 0.21 or 0.18. (TFCHK-049)
Warning: Layer 'M6' has a pitch 0.2 that does not match the recommended wire-to-via pitch 0.34 or 0.38. (TFCHK-049)
Warning: Layer 'M3' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M4' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M5' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M6' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'TM2' has a pitch 0.8 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'RDL' has a pitch 5 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: CapModel sections are missing. Capacitance models should be loaded with a TLU+ file later. (TFCHK-084)
想请教一下,1.这些警告影不影响后续库使用?2.这些警告为什么会出现,即为什么会出现这种不吻合现象?
发表于 2019-2-18 11:31:26 | 显示全部楼层
我也有相同的疑惑!
发表于 2022-1-6 19:39:39 | 显示全部楼层
我也:
Warning: Layer 'AP' is missing the attribute 'minArea'. (line 744) (TFCHK-012)
Warning: Cut layer 'VIA1' has a non-cross primary default ContactCode 'VIA12'. (line 1207) (TFCHK-092)
Warning: Layer 'M1' has a pitch 0.2 that does not match the recommended wire-to-via pitch 0.225. (TFCHK-049)
Warning: Layer 'M7' has a pitch 0.2 that does not match the recommended wire-to-via pitch 0.41 or 0.35. (TFCHK-049)
Warning: Layer 'M9' has a pitch 0.8 that does not match the recommended wire-to-via pitch 3.6. (TFCHK-049)
Warning: Layer 'M7' has a pitch 0.2 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M8' has a pitch 0.8 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'M9' has a pitch 0.8 that does not match the doubled pitch 0.4 or tripled pitch 0.6. (TFCHK-050)
Warning: Layer 'AP' has a pitch 6.5 that does not match the doubled pitch 1.6 or tripled pitch 2.4. (TFCHK-050)
发表于 2022-6-21 16:27:43 | 显示全部楼层
请问楼主 您明白是怎么回事了吗?
发表于 2023-4-18 15:23:35 | 显示全部楼层
这些是不是都不用管?
发表于 2023-4-20 22:06:26 来自手机 | 显示全部楼层
不用管
GMT+8, 2024-3-29 07:04 , Processed in 0.022035 second(s), 6 queries , Gzip On, Redis On.
