在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 8270|回复: 11
Syn家Lic求助
发表于 2018-11-3 12:10:38 | 显示全部楼层 |阅读模式
已解决
 楼主| 发表于 2018-11-3 18:11:36 | 显示全部楼层
似乎lic server启动正常, 但是还是不能用。log文件如下
18:07:02 (lmgrd) -----------------------------------------------
18:07:02 (lmgrd)   Please Note:
18:07:02 (lmgrd)
18:07:02 (lmgrd)   This log is intended for debug purposes only.
18:07:02 (lmgrd)   In order to capture accurate license
18:07:02 (lmgrd)   usage data into an organized repository,
18:07:02 (lmgrd)   please enable report logging. Use Flexera Software LLC's
18:07:02 (lmgrd)   software license administration  solution,
18:07:02 (lmgrd)   FlexNet Manager, to  readily gain visibility
18:07:02 (lmgrd)   into license usage data and to create
18:07:02 (lmgrd)   insightful reports on critical information like
18:07:02 (lmgrd)   license availability and usage. FlexNet Manager
18:07:02 (lmgrd)   can be fully automated to run these reports on
18:07:02 (lmgrd)   schedule and can be used to track license
18:07:02 (lmgrd)   servers and usage across a heterogeneous
18:07:02 (lmgrd)   network of servers including Windows NT, Linux
18:07:02 (lmgrd)   and UNIX. Contact Flexera Software LLC at
18:07:02 (lmgrd)   www.flexerasoftware.com for more details on how to
18:07:02 (lmgrd)   obtain an evaluation copy of FlexNet Manager
18:07:02 (lmgrd)   for your enterprise.
18:07:02 (lmgrd)
18:07:02 (lmgrd)
18:07:02 (lmgrd)
18:07:02 (lmgrd) Server's System Date and Time: Sat Nov 03 2018 18:07:02 CST
18:07:02 (lmgrd) SLOG: Summary LOG statistics is enabled.
18:07:02 (lmgrd) The license server manager (lmgrd) running as root:
18:07:02 (lmgrd)         This is a potential security problem
18:07:02 (lmgrd)         and is not recommended.
18:07:02 (lmgrd) FlexNet Licensing (v11.13.1.0 build 167164 x64_lsb) started on IC (linux) (11/3/2018)
18:07:02 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
18:07:02 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
18:07:02 (lmgrd) License file(s): /home/IC/Desktop/my.dat
18:07:02 (lmgrd) lmgrd tcp-port 27000
18:07:02 (lmgrd) (@lmgrd-SLOG@) ===============================================
18:07:02 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
18:07:02 (lmgrd) (@lmgrd-SLOG@) Start-Date: Sat Nov 03 2018 18:07:02 CST
18:07:02 (lmgrd) (@lmgrd-SLOG@) PID: 2667
18:07:02 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.0 build 167164 x64_lsb ( build 167164 (ipv6))
18:07:02 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
18:07:02 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
18:07:02 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
18:07:02 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
18:07:02 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /home/IC/Desktop/my.dat -l /home/IC/Desktop/my.log
18:07:02 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /home/IC/Desktop/my.dat
18:07:02 (lmgrd) Starting vendor daemons ...
18:07:02 (lmgrd) Started snpslmd (internet tcp_port 40073 pid 2670)
18:07:02 (snpslmd) FlexNet Licensing version v11.13.1.0 build 167164 x64_lsb
11/03/2018 18:07:03 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.11
11/03/2018 18:07:09 (snpslmd) File descriptor limit (soft, hard) for snpslmd: 4096, 4096
18:07:09 (snpslmd) SLOG: Summary LOG statistics is enabled.
18:07:09 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
18:07:09 (snpslmd) SLOG: VM Status: 1
18:07:09 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT2
18:07:09 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
18:07:11 (snpslmd) Server started on IC for:        SSS
18:07:11 (snpslmd) xp                xsim                vcd2e
18:07:11 (snpslmd) vcsace                vera_comp        vera_ip
18:07:11 (snpslmd) verilog_writer        vertue                vhdl_compiler
18:07:11 (snpslmd) viewlogic        viewlogic_epic        vlog_epic_pif
18:07:11 (snpslmd) vlog2e                vlsi2000        vlsi500
18:07:11 (snpslmd) vsea-calib        vsea-calib_all        vsea-calib_ise
18:07:11 (snpslmd) vsea-calib_ise_all vsecP_OEM_VCS_FUJITSU_GEN_NL vsecP_OEM_VCS_FUJITSU_GEN_NW
18:07:11 (snpslmd) vsecP_OEM_VCS_FUJITSU_RUN_NL vsecP_OEM_VCS_FUJITSU_USE_NL vsecP_OEM_VCS_FUJITSU_USE_NW
18:07:11 (snpslmd) vtran                usb_device_vmt        techviewer
18:07:11 (snpslmd) testing                tfm                timemill
18:07:11 (snpslmd) timemill/ace        timemill/av        timemill/bcx
18:07:11 (snpslmd) timemill/bdc        timemill/beta_status timemill/btm
18:07:11 (snpslmd) timemill/csx        timemill/internal_use timemill/msx
18:07:11 (snpslmd) timemill/nsaddon tSchema                turboSchema
18:07:11 (snpslmd) turboState        turboTracer        turboWave
18:07:11 (snpslmd) turbowave_epic        sprocess-an-imp3d sprocess-an-imp3d_all
18:07:11 (snpslmd) sprocess-an-imp3d_ise sprocess-an-imp3d_ise_all sprocesskmc_all
18:07:11 (snpslmd) sprocessmc        sprocessmc_all        sprocessmc_ise
18:07:11 (snpslmd) sprocessmc_ise_all sprocessmpp_all sprocess-parallel_all
18:07:11 (snpslmd) sprocess-parallel4_all sptopography2d_all stars_analog
18:07:11 (snpslmd) stars_aryred        stars_cmi        stars_csdf
18:07:11 (snpslmd) stars_hsplnk        stars_ish        stars_linred
18:07:11 (snpslmd) stars_mr        stars_wsf        starsim
18:07:11 (snpslmd) starsimxt        start_aed        start_analysis
18:07:11 (snpslmd) start_bin        startime        sup2lig
18:07:11 (snpslmd) sup2lig_all        sup2lig_ise        sup2lig_ise_all
18:07:11 (snpslmd) svisual_all        swb                swb_all
18:07:11 (snpslmd) swb_ise                swb_ise_all        swb-advanced
18:07:11 (snpslmd) swb-advanced_all swb-advanced_ise swb-advanced_ise_all
18:07:11 (snpslmd) sx_cdslink        sx_chip                sx_daiclink
18:07:11 (snpslmd) sx_drc                sx_wva                synplify
18:07:11 (snpslmd) synplifyasic        synplifydspoption synplifydspsl
18:07:11 (snpslmd) synplifypremier synplifypremierdp synplifypro
18:07:11 (snpslmd) synplifypro_asix systemc_ide        sinterconnect_all
18:07:11 (snpslmd) sinterconnect2d_all sinterconnect3d_all sdevice-parallel_ise
18:07:11 (snpslmd) sdevice-parallel_ise_all sdevice-parallel4 sdevice-parallel4_all
18:07:11 (snpslmd) sdevice-parallel4_ise sdevice-parallel4_ise_all sdevice-pmi
18:07:11 (snpslmd) sdevice-pmi_all sdevice-pmi_ise sdevice-pmi_ise_all
18:07:11 (snpslmd) sdevice-radiation sdevice-radiation_all sdevice-radiation_ise
18:07:11 (snpslmd) sdevice-radiation_ise_all sdevice-reliability sdevice-reliability_all
18:07:11 (snpslmd) sdevice-reliability_ise sdevice-reliability_ise_all sdevice-schroedinger
18:07:11 (snpslmd) sdevice-schroedinger_all sdevice-schroedinger_ise sdevice-schroedinger_ise_all
18:07:11 (snpslmd) sdevice-sige        sdevice-sige_all sdevice-sige_ise
18:07:11 (snpslmd) sdevice-sige_ise_all sdevice-thermo        sdevice-thermo_all
18:07:11 (snpslmd) sdevice-thermo_ise sdevice-thermo_ise_all sdevice-traps
18:07:11 (snpslmd) sdevice-traps_all sdevice-traps_ise sdevice-traps_ise_all
18:07:11 (snpslmd) sdevice-vectoroptic sdevice-vectoroptic_all sdevice-vectoroptic_ise
18:07:11 (snpslmd) sdevice-vectoroptic_ise_all sharp                simif
18:07:11 (snpslmd) simwave                simwave_epic        snps_fs_nwave
18:07:11 (snpslmd) sparallel        sparallel_all        sparallel_ise
18:07:11 (snpslmd) sparallel_ise_all spcmcalib_all        spcmlib
18:07:11 (snpslmd) spcmlib_all        spcmlib_ise        spcmlib_ise_all
18:07:11 (snpslmd) spcmstd                spcmstd_all        spcmstd_ise
18:07:11 (snpslmd) spcmstd_ise_all spcmtcl                spcmtcl_all
18:07:11 (snpslmd) spcmtcl_ise        spcmtcl_ise_all spice_explorer
18:07:11 (snpslmd) spice_parser        sprocess        sprocess_all
18:07:11 (snpslmd) sprocess_ise        sprocess_ise_all sprocess2d
18:07:11 (snpslmd) sprocess2d_all        sprocess2d_ise        sprocess2d_ise_all
18:07:11 (snpslmd) sprocess2dmc        sprocess2dmc_all sprocess2dmc_ise
18:07:11 (snpslmd) sprocess2dmc_ise_all sprocess3d        sprocess3d_all
18:07:11 (snpslmd) sprocess3d_ise        sprocess3d_ise_all sprocess3dmc
18:07:11 (snpslmd) sprocess3dmc_all sprocess3dmc_ise sprocess3dmc_ise_all
18:07:11 (snpslmd) scratch                sda                sde
18:07:11 (snpslmd) sde_all                sde_ise                sde_ise_all
18:07:11 (snpslmd) sde3d                sde3d_all        sde3d_ise
18:07:11 (snpslmd) sde3d_ise_all        sdevcie-laser_all sdevice
18:07:11 (snpslmd) sdevice_all        sdevice_ise        sdevice_ise_all
18:07:11 (snpslmd) sdevice-3d        sdevice-3d_all        sdevice-3d_ise
18:07:11 (snpslmd) sdevice-3d_ise_all sdevice-densitygrad sdevice-densitygrad_all
18:07:11 (snpslmd) sdevice-densitygrad_ise sdevice-densitygrad_ise_all sdevice-ferro
18:07:11 (snpslmd) sdevice-ferro_all sdevice-ferro_ise sdevice-ferro_ise_all
18:07:11 (snpslmd) sdevice-floatinggate sdevice-floatinggate_all sdevice-floatinggate_ise
18:07:11 (snpslmd) sdevice-floatinggate_ise_all sdevice-gateleakage sdevice-gateleakage_all
18:07:11 (snpslmd) sdevice-gateleakage_ise sdevice-gateleakage_ise_all sdevice-hetero
18:07:11 (snpslmd) sdevice-hetero_all sdevice-hetero_ise sdevice-hetero_ise_all
18:07:11 (snpslmd) sdevice-hydro        sdevice-hydro_all sdevice-hydro_ise
18:07:11 (snpslmd) sdevice-hydro_ise_all sdevice-kpgain        sdevice-kpgain_all
18:07:11 (snpslmd) sdevice-kpgain_ise sdevice-kpgain_ise_all sdevice-laser
18:07:11 (snpslmd) sdevice-laser_all sdevice-laser_ise sdevice-laser_ise_all
18:07:11 (snpslmd) sdevice-led        sdevice-led_all sdevice-led_ise
18:07:11 (snpslmd) sdevice-led_ise_all sdevice-mixedmode sdevice-mixedmode_all
18:07:11 (snpslmd) sdevice-mixedmode_ise sdevice-mixedmode_ise_all sdevicemonosemicond
18:07:11 (snpslmd) sdevicemonosemicond_all sdevicemonosemicond_ise sdevicemonosemicond_ise_all
18:07:11 (snpslmd) sdevice-montecarlo sdevice-montecarlo_all sdevice-montecarlo_ise
18:07:11 (snpslmd) sdevice-montecarlo_ise_all sdevice-noise        sdevice-noise_all
18:07:11 (snpslmd) sdevice-noise_ise sdevice-noise_ise_all sdevice-optic
18:07:11 (snpslmd) sdevice-optic_all sdevice-optic_ise sdevice-optic_ise_all
18:07:11 (snpslmd) sdevice-parallel sdevice-parallel_all rad
18:07:11 (snpslmd) railmill        railmill/ace        railmill/av
18:07:11 (snpslmd) railmill/bcx        railmill/beta_status railmill/gbx
18:07:11 (snpslmd) railmill/internal_use railmill/msx        railmill/power
18:07:11 (snpslmd) railmill/rvfp        railmill/snx        railmill/spnx
18:07:11 (snpslmd) railmill/ssnx        rm_eee                route66
18:07:11 (snpslmd) rslv3d                rslv3dviewer        pathfinder
18:07:11 (snpslmd) pathmill        pathmill/cso        pathmill/ctx
18:07:11 (snpslmd) pathmill/dsx        pathmill/pfx        pathmill/sfx
18:07:11 (snpslmd) pathmill_plus        planet_migrate        platform_creator_sysc
18:07:11 (snpslmd) pmga                polaris-cbs        polaris-com
18:07:11 (snpslmd) polaris-int        polaris-mt        polaris-signalscan
18:07:11 (snpslmd) powerarc        powergate        powrmill
18:07:11 (snpslmd) powrmill/ace        powrmill/av        powrmill/bcx
18:07:11 (snpslmd) powrmill/beta_status powrmill/btm        powrmill/csx
18:07:11 (snpslmd) powrmill/internal_use powrmill/msx        powrmill/nsaddon
18:07:11 (snpslmd) powrmill/power        powrmill/svcz        powrmill/vlog_a
18:07:11 (snpslmd) primepower_beta primepower_vcd        primerail_hsim
18:07:11 (snpslmd) prmspx_visual_all provhdl_checker psf
18:07:11 (snpslmd) pwga                nAnalyzer        nanochar
18:07:11 (snpslmd) nanosim                nanosim/ace        nanosim/ace_cosim
18:07:11 (snpslmd) nanosim/av        nanosim/bcx        nanosim/bdc
18:07:11 (snpslmd) nanosim/beta_status nanosim/btm        nanosim/gui
18:07:11 (snpslmd) nanosim/internal_use nanosim/msx        nanosim/postlayout_har
18:07:11 (snpslmd) nanosim/power        nanosim/vlog_a        nanosim_starsimxt
18:07:11 (snpslmd) nBench                nClock                nCompare
18:07:11 (snpslmd) nECO                nESL                nlcc
18:07:11 (snpslmd) nLint                nLint_either        nLint_mixed
18:07:11 (snpslmd) nLint_sv        nLint_verilog        nLint_vhdl
18:07:11 (snpslmd) nMonitor        npi                nProp
18:07:11 (snpslmd) nSC                nSchema                nSchemaOnly
18:07:11 (snpslmd) nState                nTE                nTiming
18:07:11 (snpslmd) nTrace                nTree                nTX
18:07:11 (snpslmd) nWave                mentorf                metaencrypt3des
18:07:11 (snpslmd) metawaves        metawaveswin        mg_falcon_epic
18:07:11 (snpslmd) milltools        misc                mti_epic
18:07:11 (snpslmd) mentor/f        leda_checker        leda_mx
18:07:11 (snpslmd) leda-mx                libarc                lsim_parser
18:07:11 (snpslmd) identdebugger        identdebugger_encrypt identdebugger_xilinx
18:07:11 (snpslmd) identify_tps        identifydebugger identifydebugger_encrypt
18:07:11 (snpslmd) identifydebugger_xilinx identifyinstrumentor identifyinstrumentor_encrypt
18:07:11 (snpslmd) identifyinstrumentor_xilinx identinstrumentor identinstrumentor_encrypt
18:07:11 (snpslmd) identinstrumentor_xilinx identprodebugger identprodebugger_encrypt
18:07:11 (snpslmd) identprodebugger_xilinx identproinstrumentor identproinstrumentor_encrypt
18:07:11 (snpslmd) identproinstrumentor_xilinx ispLSI1K        ispLSI2K
18:07:11 (snpslmd) ispLSI2KE        ispLSI3K        ispLSI5000S
18:07:11 (snpslmd) ispLSI5000SE        ispLSI5K        ispLSI6K
18:07:11 (snpslmd) ispLSI8K        ispMACH4000        hd_foundation
18:07:11 (snpslmd) hd_pna                hd_special1        hd_special2
18:07:11 (snpslmd) hd_special3        hd_utils        hdlin
18:07:11 (snpslmd) hdlin_mixed        hdlin_verilog        hdlin_vhdl
18:07:11 (snpslmd) hicdr_test        hicdr_test/test1 hicdr_test/test2
18:07:11 (snpslmd) hicdr_test/test3 hicdr_test/test4 hicdr_test/test5
18:07:11 (snpslmd) hicdr_test/test6 hicdr_test/test7 hicdr_test/test8
18:07:11 (snpslmd) him_mb                him_mb_dsml        him_mm_pi
18:07:11 (snpslmd) him_mod                him_sml                hsim
18:07:11 (snpslmd) hsim-cosim        hsim-xl                hspice
18:07:11 (snpslmd) hspice_adv        hspice_cosim        hspice_gui
18:07:11 (snpslmd) hspice_mt        hspice_pack        hspice_rf
18:07:11 (snpslmd) hspice_rf_char        hspice3des        hspicecmidev
18:07:11 (snpslmd) hspicecmirt        hspicemt        hspicerf
18:07:11 (snpslmd) hspiceva        hspicewin        hspice-XO
18:07:11 (snpslmd) hspicext        hsptest                hspui
18:07:11 (snpslmd) gemini_hspice        gentech                fastspice_xa
18:07:11 (snpslmd) ficdr_test        ficdr_test/gds        ficdr_test/goa
18:07:11 (snpslmd) ficdr_test/io        ficdr_test/nc        ficdr_test/poly
18:07:11 (snpslmd) ficdr_test/size ficdr_test/sizeOr ficdr_test/stmp
18:07:11 (snpslmd) ficdr_test/tio        fpc_foundation        fpc_pna
18:07:11 (snpslmd) fpc_special1        fpc_special2        fpc_special3
18:07:11 (snpslmd) fpc_utils        features        fullhspice
18:07:11 (snpslmd) edif2e                electromigration_drc emw
18:07:11 (snpslmd) emw_all                emw_ise                emw_ise_all
18:07:11 (snpslmd) emw-farfield        emw-farfield_all emw-farfield_ise
18:07:11 (snpslmd) emw-farfield_ise_all emw-nonuniform-2d_all emw-nonuniform-3d
18:07:11 (snpslmd) emw-nonuniform-3d_all emw-nonuniform-3d_ise emw-nonuniform-3d_ise_all
18:07:11 (snpslmd) emw-sdevice        emw-sdevice_all emw-sdevice_ise
18:07:11 (snpslmd) emw-sdevice_ise_all emw-static        emw-static_all
18:07:11 (snpslmd) emw-static_ise        emw-static_ise_all emw-thermal
18:07:11 (snpslmd) emw-thermal_all emw-thermal_ise emw-thermal_ise_all
18:07:11 (snpslmd) emw-uniform-2d_all emw-uniform-3d        emw-uniform-3d_all
18:07:11 (snpslmd) emw-uniform-3d_ise emw-uniform-3d_ise_all encore
18:07:11 (snpslmd) encrypt                etran                eX
18:07:11 (snpslmd) example_INCREMENT example_feature express
18:07:11 (snpslmd) express_fpga        express_fpga_all_vendor express_fpga_altera
18:07:11 (snpslmd) express_fpga_xilinx express_sim_verify express_ui
18:07:11 (snpslmd) express_ui_fpga express_ui_fpga_all_vendor express_ui_fpga_altera
18:07:11 (snpslmd) express_ui_fpga_xilinx express_ui_verify extreme
18:07:11 (snpslmd) extreme_fpga        extreme_fpga_all_vendor extreme_fpga_altera
18:07:11 (snpslmd) extreme_ui_fpga_xilinx extreme_power        extreme_power_ui
18:07:11 (snpslmd) extreme_sharing extreme_ui_fpga extreme_ui_fpga_all_vendor
18:07:11 (snpslmd) extreme_ui_fpga_altera extreme_ui        delaymill
18:07:11 (snpslmd) c_exe_ax        c_exe_cbx        c_exe_drc
18:07:11 (snpslmd) c_exe_gx        c_exe_ipc        c_exe_lvs
18:07:11 (snpslmd) cadence                cadence_epic        cdsaavmx
18:07:11 (snpslmd) cdsaawaves        cdsmetalib        cdsnet
18:07:11 (snpslmd) certify                certifysc        chiparch_migrate
18:07:11 (snpslmd) chipviewer        cmod                cmod/ax
18:07:11 (snpslmd) cmod/cbx        cmod/drc        cmod/gx
18:07:11 (snpslmd) cmod/gxadv        cmod/hdrc        cmod/hlvs
18:07:11 (snpslmd) cmod/ipc        cmod/lvs        cmod/viewer
18:07:11 (snpslmd) coreAssembler        coreBuilder        coreConsultant
18:07:11 (snpslmd) coremill        coreSynthesis        cosmos_other
18:07:11 (snpslmd) cxp                cmpro_main        ace_core
18:07:11 (snpslmd) acega                acehdl                acehdl/beta_status
18:07:11 (snpslmd) acehdl/internal_use acehdl_beta        acehdl_gui
18:07:11 (snpslmd) aiu_foundation        alien2lig        alien2lig_all
18:07:11 (snpslmd) alien2lig_ise        alien2lig_ise_all amat-calib
18:07:11 (snpslmd) amat-calib_all        amat-calib_ise        amat-calib_ise_all
18:07:11 (snpslmd) amga                amplify                amplifyasic
18:07:11 (snpslmd) amplifyissp        amplifyrapidchip amps
18:07:11 (snpslmd) amps/cso        amps/pfx        amps/tr
18:07:11 (snpslmd) any_technology        arc                arc/bcx
18:07:11 (snpslmd) arc/c2x                arc/c3x                arc/cns
18:07:11 (snpslmd) arc/dnx                arc/dpx                arc/gds2
18:07:11 (snpslmd) arc/giper        arc/lefdef        arc/ppx
18:07:11 (snpslmd) arc/pro                arc/r3x                arc1
18:07:11 (snpslmd) arc2                arcexpert        arcfc
18:07:11 (snpslmd) arcviewer        arcviewer/raph        arcxl
18:07:11 (snpslmd) avanwaves        avanwaveswin        awe_rcr
18:07:11 (snpslmd) ace_cosim        XC3000                XC4000
18:07:11 (snpslmd) XC4000E                XC4000EX        XC4000L
18:07:11 (snpslmd) XC4000XL        XC4000XLA        XC4000XV
18:07:11 (snpslmd) XC5200                XC9500                XC9500XL
18:07:11 (snpslmd) XC9500XV        XVCSDebugger        XVCSiDebugger
18:07:11 (snpslmd) XVVCDebugger        WF_API_HSPICE        WF_API_HSPICE_MEMSSE
18:07:11 (snpslmd) WF_API_MEMSSE        WF_API_STARSIM        WF_API_STARSIM_MEMSSE
18:07:11 (snpslmd) WhatIfAnalysis        WRITE                VT_AssertionIP
18:07:11 (snpslmd) VT_Assertions        VT_AssertionsRuntime VT_CBUG
18:07:11 (snpslmd) VT_Coverage        VT_CoverageRuntime VT_CoverageURG
18:07:11 (snpslmd) VT_DVE                VT_DVE_COV        VT_DVENTB
18:07:11 (snpslmd) VT_LCA_Assertions VT_LCA_Coverage VT_LCA_DEBUG
18:07:11 (snpslmd) VT_LCA_Language VT_LCA_MixedSignal VT_LCA_Testbench
18:07:11 (snpslmd) VT_NativeTBDebuggerGui VT_NativeTestbench VT_NTB
18:07:11 (snpslmd) VT_OtherTechnology VT_Pioneer        VT_PVCSCompiler_Net
18:07:11 (snpslmd) VT_SDebug        VT_SVAssertionCompiler VT_SVAssertions
18:07:11 (snpslmd) VT_SVDesign        VT_SVTestbench        VT_SYSTEMC21
18:07:11 (snpslmd) VT_SystemVerilog VT_Testbench        VT_TestbenchRuntime
18:07:11 (snpslmd) VT_UCLI                VT_UnifiedCoverage VT_VCS_Advanced_INCREMENTs
18:07:11 (snpslmd) VT_VCS_BETA_INCREMENTs VT_VCS_BETA_Program VT_VCS_Checker
18:07:11 (snpslmd) VT_VCS_Echo        VT_VCS_LCA_INCREMENTs VT_VCS_NTBE
18:07:11 (snpslmd) VT_VCS_Power_Management VT_Visual        Verdi_HwSwDebug
18:07:11 (snpslmd) VT_VCS_BETA_Features VT_VCS_LCA_Features VT_VCS_Advanced_Features
18:07:11 (snpslmd) VC-STATIC-COMPILE VC-STATIC-RUNTIME VC-STATIC-LP
18:07:11 (snpslmd) VC-STATIC-FV        VC-STATIC-CDC        VC-STATIC-LINT
18:07:11 (snpslmd) VC-STATIC-COV        VERDISIGNOFF        VERIDIGNOFF_LP
18:07:11 (snpslmd) VERIDIGNOFF_FV        VERIDIGNOFF_CDC VERIDIGNOFF_LINT
18:07:11 (snpslmd) VERIDIGNOFF_COV VERDISIGNOFF_CDC Verification-Token
18:07:11 (snpslmd) Verilog                Verilog-Netlist-Writer Verilog-Parser
18:07:11 (snpslmd) Verilog-To-BE        Verilog-VirSim        VF
18:07:11 (snpslmd) VHDLAMS_TAURI        VHDLAMS_TAURILI VHDL-Analyzer
18:07:11 (snpslmd) VHDL-Compiler        VHDL-Compiler-Old VHDL-Compiler-Presto
18:07:11 (snpslmd) VHDL-Cycle-Sim        VHDL-Elaborator VHDL-Event-Sim
18:07:11 (snpslmd) VHDLi-Elaborator VHDLi-Event-Sim VHDL-Netlist-Writer
18:07:11 (snpslmd) VHDL-ScSim        VHDL-To-BE        VHDL-Tools
18:07:11 (snpslmd) VHDL-VirSim        VHMC-Eval        VHMC-GenUnlocked
18:07:11 (snpslmd) VHMC-Runtime        VIEWLOGIC_FRAMEWAY VIEWLOGIC_FRAMEWAY_MEMSSE
18:07:11 (snpslmd) VIEWLOGIC_NET        VIEWLOGIC_NET_MEMSSE VIP-AMBA-SVT
18:07:11 (snpslmd) VIP-LIBRARY-SVT VirSim                VIRTEX
18:07:11 (snpslmd) VIRTEX2                VIRTEX2P        VIRTEXE
18:07:11 (snpslmd) VIRTEXEA        Vivace-Code-Generator Vivace-Core
18:07:11 (snpslmd) Vivace-Debug        Vivace-Elaborator Vivace-Expert
18:07:11 (snpslmd) Vivace-Express        Vivace-GUI        Vivace-HDL-Analyzer
18:07:11 (snpslmd) Vivace-Model-Compiler Vivace-Pro        Vivace-Simulator
18:07:11 (snpslmd) Vivace-VHDL-Analyzer VMCCompiler        VMCCompiler_Net
18:07:11 (snpslmd) VMCCompiler_Node VMCCore                VMCEvaluation
18:07:11 (snpslmd) VMCEvaluation_Net VMCEvaluation_Node VMCExpress_Compiler
18:07:11 (snpslmd) VMCExpress_Compiler_Net VMCExpress_Compiler_Node VMCGeneratorUnlocked
18:07:11 (snpslmd) VMCGeneratorUnlocked_Net VMCGeneratorUnlocked_Node VMCRuntime
18:07:11 (snpslmd) VMCRuntime_Net        VMCRuntime_Node VPC
18:07:11 (snpslmd) VSP_DRIVER        VSS-Analyzer        VSS-Backplane
18:07:11 (snpslmd) VSS-Cadence-Interface VSS-CLI                VSS-CompiledSim
18:07:11 (snpslmd) VSS-Debugger        VSS-Falcon-Interface VSS-GateSim
18:07:11 (snpslmd) VSS-LAI-Models        VSS-Lib-Tools        VSS-LMSI
18:07:11 (snpslmd) VSS-Model-Developer VSS-NEC-Tran        VSS-SDF-Interface
18:07:11 (snpslmd) VSS-SGE-Tool        VSS-Simulator        VSS-SmartModels
18:07:11 (snpslmd) VSS-SPC                VSS-Tran        VSS-Utilities
18:07:11 (snpslmd) VSS-Verilog-PLI VSS-VIP-Interface VSS-Wave-Display
18:07:11 (snpslmd) VSS-XP-Accelerator VT_64Bit        VANTIS
18:07:11 (snpslmd) VCSAMSCompiler        VCSAMSCompiler_Net VCSAMSRuntime
18:07:11 (snpslmd) VCSAMSRuntime_Net VCSCompile        VCSCompile_Net
18:07:11 (snpslmd) VCSCompile_Node VCSCompiler        VCSCompiler_Net
18:07:11 (snpslmd) VCSCompiler_Node VCSDebugger        VCSDebugger_Net
18:07:11 (snpslmd) VCSDebugger_Node VCS-Express-Compile VCS-Express-Runtime
18:07:11 (snpslmd) VCSiCompile        VCSiCompile_Net VCSiCompile_Node
18:07:11 (snpslmd) VCSiCompiler        VCSiCompiler_Net VCSiCompiler_Node
18:07:11 (snpslmd) VCSiDebugger        VCSiDebugger_Net VCSiDebugger_Node
18:07:11 (snpslmd) VCSiRuntime        VCSiRuntime_Net VCSiRuntime_Net(3)
18:07:11 (snpslmd) VCSiRuntime_Node VCSiRuntimeLimited VCSiRuntimeLimited_Net
18:07:11 (snpslmd) VCSiRuntimeLimited_Node VCSlm_Hm        VCSlm_Hm_Net
18:07:11 (snpslmd) VCSlm_Hm_Node        VCSMXiRunTime_Net VCSMXRunTime_Net
18:07:11 (snpslmd) VCSNativeCode        VCSNativeCode_Net VCSNativeCode_Node
18:07:11 (snpslmd) VCSOldPostProcDebugger_Net VCSOldPostProcDebugger_Node VCSParallelCompiler
18:07:11 (snpslmd) VCSParallelCompiler_Net VCSParallelCompiler_Node VCSParallelRuntime
18:07:11 (snpslmd) VCSParallelRuntime_Net VCSParallelRuntime_Node VCSParallelThread
18:07:11 (snpslmd) VCSParallelThread_Net VCSParallelThread_Node VCSPostProcDebugger
18:07:11 (snpslmd) VCSPostProcDebugger_Net VCSPostProcDebugger_Node VCSRuntime
18:07:11 (snpslmd) VCSRuntime_Net        VCSRuntime_Node VCSRuntimeLimited
18:07:11 (snpslmd) VCSRuntimeLimited_Net VCSRuntimeLimited_Node VCSStd
18:07:11 (snpslmd) VCSStd_Net        VCSStd_Node        VCSTools
18:07:11 (snpslmd) VCSTools_Net        VCSTools_Node        VCS-VERIFICATION-LIBRARY
18:07:11 (snpslmd) VDesktop-Debug        VDesktop-GUI        VDesktop-VCDTrans
18:07:11 (snpslmd) VDesktop-Verilog VDesktop-VHDL        VEHICLE_ELECTRIC_LIB
18:07:11 (snpslmd) VEHICLE_ELECTRIC_LIB_MEMSSE VENDOR_LIBRARY        VENDOR_LIBRARY_MEMSSE
18:07:11 (snpslmd) Vera                Vera_debug        Vera_rtime
18:07:11 (snpslmd) Verdi                VERIAS_HSPICE_COMPILER VERIAS_SIMULATOR
18:07:11 (snpslmd) Ultra37000        Test-Physical        Test-Power
18:07:11 (snpslmd) Test-PR-1        Test-PR-2        Test-PR-3
18:07:11 (snpslmd) Test-PR-4        Test-RTL-Check        Test-RTL-Tristate
18:07:11 (snpslmd) Test-ScanRoute        Test-SDD-Timing TestSim
18:07:11 (snpslmd) Test-STDVR        Test-Validate        TestVE
18:07:11 (snpslmd) THERM_TOOL        THERM_TOOL_MEMSSE TimingAnalysis
18:07:11 (snpslmd) TLM_Synthesis        TLU_TOOL        TLU_TOOL_MEMSSE
18:07:11 (snpslmd) TP                TR                TR_ANALYSIS
18:07:11 (snpslmd) TR_ANALYSIS_MEMSSE TV                True
18:07:11 (snpslmd) T3                TA                TBM-Manager-UI
18:07:11 (snpslmd) TBM-VSS-Check        TBS                TC-Beta
18:07:11 (snpslmd) TD                TDL-Interface        TDL-Reader
18:07:11 (snpslmd) TDL-Writer        Tdx                Tdx_all
18:07:11 (snpslmd) Tdx_ise                Tdx_ise_all        Tecplot
18:07:11 (snpslmd) Tecplot_all        Tecplot_ise        Tecplot_ise_all
18:07:11 (snpslmd) TecplotSmall_all Ted                Ted_all
18:07:11 (snpslmd) Ted_ise                Ted_ise_all        TedSmall_all
18:07:11 (snpslmd) Test-Accelerate-Max Test-Accelerator Test-Analysis
18:07:11 (snpslmd) Test-Analysis-GUI Test-Analysis-RTL Test-ATPG
18:07:11 (snpslmd) Test-ATPG-30        Test-ATPG-Limited Test-ATPG-Max
18:07:11 (snpslmd) Test-ATPG-PRO        Test-ATPG-Ultra Test-ATPG-XP
18:07:11 (snpslmd) Test-Beta        Test-Beta-2        Test-Beta-3
18:07:11 (snpslmd) Test-Beta-4        Test-Beta-5        Test-Beta-6
18:07:11 (snpslmd) Test-Beta-7        Test-Beta-8        Test-Beta-9
18:07:11 (snpslmd) Test-BIST        Test-BSDL        Test-CA
18:07:11 (snpslmd) Test-CA-2        Test-CA-3        Test-CA-4
18:07:11 (snpslmd) Test-Compile        Test-Compile-Max Test-Compiler
18:07:11 (snpslmd) Test-Compile-Remodel Test-Compiler-Plus Test-Compiler-Remodel
18:07:11 (snpslmd) Test-Compile-Share Test-Compression-ATPG Test-CompressionPlus-ATPG
18:07:11 (snpslmd) Test-CompressionPlus-Syn Test-Compression-Synthesis Test-Core-Integration
18:07:11 (snpslmd) Test-Core-Wrapper Test-CTL-Model        Test-Custom-Protocols
18:07:11 (snpslmd) Test-Delay        TestDesignCorrelation Test-DFTC-TMAX
18:07:11 (snpslmd) Test-DFT-Top        Test-Diagnosis        Test-Eval
18:07:11 (snpslmd) Test-Fault-Max        Test-Faultsim        Test-Faultsim-8L
18:07:11 (snpslmd) Test-Format        Test-IDDQ        Test-IEEE-Std-1149-1
18:07:11 (snpslmd) TESTIFY                TESTIFY_MEMSSE        TESTIFY_NETLISTER
18:07:11 (snpslmd) TESTIFY_NETLISTER_MEMSSE Test-LBIST-ATPG Test-LBIST-Integration
18:07:11 (snpslmd) Test-LBIST-Synthesis Test-Library        TestManager
18:07:11 (snpslmd) Test-Map        Test-Mbist        Test-Mbist-Algorithm
18:07:11 (snpslmd) Test-Mbist-Bitstream Test-Mbist-CAM        Test-Mbist-Diagnosis
18:07:11 (snpslmd) Test-Mbist-DRAM Test-Mbist-FLASH Test-MBIST-Integration
18:07:11 (snpslmd) Test-Mbist-Multiport Test-Mbist-Program STAR-DC
18:07:11 (snpslmd) STAR-EX                STAR-EX_ERC        STAR-FILTER
18:07:11 (snpslmd) STAR-GAZER        STAR-LD2LTL        STAR-R
18:07:11 (snpslmd) STAR-RC                STAR-RC2        STAR-RC2_MANAGER
18:07:11 (snpslmd) STAR-RC2-AEO        STAR-RC2-ANAL        STAR-RC2-ASCII
18:07:11 (snpslmd) STAR-RC2-CLOCK        STAR-RC2-DB        STAR-RC2-DEBUG
18:07:11 (snpslmd) STAR-RC2-DISTRIB10 STAR-RC2-GUI        STAR-RC2-NETLIST
18:07:11 (snpslmd) STAR-RC2-PROBER STAR-RC2-TCAD        STAR-RC2-VIEWER
18:07:11 (snpslmd) STAR-RC2-XSTOR1 STAR-RC2-XSTOR2 STAR-RC2-XTRACT
18:07:11 (snpslmd) STAR-RC2-XTR-AEO STAR-RC-GUI        STAR-R-GUI
18:07:11 (snpslmd) STAR-SYN2STAR        STAR-TCAD        STAR-XREF
18:07:11 (snpslmd) StarXtract        STATEBENCH        STRESS
18:07:11 (snpslmd) STRESS_MEMSSE        Sxtract_all        SYMLIB
18:07:11 (snpslmd) SYMLIB_JAPANESE SYMLIB_JAPANESE_MEMSSE SYMLIB_MEMSSE
18:07:11 (snpslmd) SYMLIB_PLUS        SYMLIB_PLUS_MEMSSE SYMLIB_POWER
18:07:11 (snpslmd) SYMLIB_POWER_MEMSSE SYNARIO                SynLib-AdvMath
18:07:11 (snpslmd) SynLib-ALU        SynLib-Control        SynLib-DSPFIR
18:07:11 (snpslmd) SynLib-Eval        SynLib-FltTol        SynLib-PCIbasic
18:07:11 (snpslmd) Syn-Library-Compiler SynLib-Seq        SynLib-VerilogSimMdl
18:07:11 (snpslmd) SynLib-VHDLSimMdl Synopsys        Synopsys_VCS_cmv
18:07:11 (snpslmd) Synopsys-Queue        Synopsys-Release SABER_MODELSIM_MM
18:07:11 (snpslmd) SynopsysCustomICCLink SynopsysCustomLayout SynopsysCustomSAE
18:07:11 (snpslmd) SynopsysCustomSAEBatch SynopsysCustomSDL SynopsysCustomSchematic
18:07:11 (snpslmd) SK_sinterconnect_all SK_sinterconnect2d_all SK_sdevice-led_all
18:07:11 (snpslmd) SK_sdevice-mixedmode SK_sdevice-mixedmode_all SK_sdevicemonosemicond
18:07:11 (snpslmd) SK_sdevicemonosemicond_all SK_sdevice-montecarlo SK_sdevice-montecarlo_all
18:07:11 (snpslmd) SK_sdevice-noise SK_sdevice-noise_all SK_sdevice-optic
18:07:11 (snpslmd) SK_sdevice-optic_all SK_sdevice-parallel SK_sdevice-parallel_all
18:07:11 (snpslmd) SK_sdevice-parallel4 SK_sdevice-parallel4_all SK_sdevice-pmi
18:07:11 (snpslmd) SK_sdevice-pmi_all SK_sdevice-radiation SK_sdevice-radiation_all
18:07:11 (snpslmd) SK_sdevice-reliability SK_sdevice-reliability_all SK_sdevice-schroedinger
18:07:11 (snpslmd) SK_sdevice-schroedinger_all SK_sdevice-sige SK_sdevice-sige_all
18:07:11 (snpslmd) SK_sdevice-thermo SK_sdevice-thermo_all SK_sdevice-traps
18:07:11 (snpslmd) SK_sdevice-traps_all SK_sdevice-vectoroptic SK_sdevice-vectoroptic_all
18:07:11 (snpslmd) SK_sparallel        SK_sparallel_all SK_spcmlib
18:07:11 (snpslmd) SK_spcmlib_all        SK_spcmstd        SK_spcmstd_all
18:07:11 (snpslmd) SK_spcmtcl        SK_spcmtcl_all        SK_sprocess
18:07:11 (snpslmd) SK_sprocess_all SK_sprocess2d        SK_sprocess2d_all
18:07:11 (snpslmd) SK_sprocess2dmc SK_sprocess2dmc_all SK_sprocess3d
18:07:11 (snpslmd) SK_sprocess3d_all SK_sprocess3dmc SK_sprocess3dmc_all
18:07:11 (snpslmd) SK_sprocess-an-imp3d SK_sprocess-an-imp3d_all SK_sprocessmc
18:07:11 (snpslmd) SK_sprocessmc_all SK_sup2lig        SK_sup2lig_all
18:07:11 (snpslmd) SK_svisual_all        SK_swb                SK_swb_all
18:07:11 (snpslmd) SK_swb-advanced SK_swb-advanced_all SK_Tdx
18:07:11 (snpslmd) SK_Tdx_all        SK_Tecplot        SK_Tecplot_all
18:07:11 (snpslmd) SK_Ted                SK_Ted_all        SK_vsea-calib
18:07:11 (snpslmd) SK_vsea-calib_all SKDB_Import        SNPS-Assertions
18:07:11 (snpslmd) SNPS-CSL        SNPS-Keygen        SNPS-MOTIVE
18:07:11 (snpslmd) SolarGAII        SolarII                SPARTAN
18:07:11 (snpslmd) SPARTAN2        SPARTAN2E        SPARTANXL
18:07:11 (snpslmd) SPECTRAL        SPECTRAL_MEMSSE ST_LIBRARY
18:07:11 (snpslmd) Stamp-Compiler        STAR-ASCII        STAR-CR
18:07:11 (snpslmd) SK_emw_all        SK_emw-farfield SK_emw-farfield_all
18:07:11 (snpslmd) SK_emw-nonuniform-3d SK_emw-nonuniform-3d_all SK_emw-sdevice
18:07:11 (snpslmd) SK_emw-sdevice_all SK_emw-static        SK_emw-static_all
18:07:11 (snpslmd) SK_emw-thermal        SK_emw-thermal_all SK_emw-uniform-3d
18:07:11 (snpslmd) SK_emw-uniform-3d_all SK_Floops-1D        SK_Floops-1D_all
18:07:11 (snpslmd) SK_Floops-1D-MC SK_Floops-1D-MC_all SK_Floops-2D
18:07:11 (snpslmd) SK_Floops-2D_all SK_Floops-2D-MC SK_Floops-2D-MC_all
18:07:11 (snpslmd) SK_Floops-3D        SK_Floops-3D_all SK_Floops-3D-MC
18:07:11 (snpslmd) SK_Floops-3D-MC_all SK_GENESISe        SK_GENESISe_all
18:07:11 (snpslmd) SK_Inspect        SK_Inspect_all        SK_Ligament
18:07:11 (snpslmd) SK_Ligament_all SK_LigamentFE        SK_LigamentFE_all
18:07:11 (snpslmd) SK_Mesh1D        SK_Mesh1D_all        SK_Mesh2D
18:07:11 (snpslmd) SK_Mesh2D_all        SK_Mesh3D        SK_Mesh3D_all
18:07:11 (snpslmd) SK_Noffset-2D        SK_Noffset-2D_all SK_Noffset-3D
18:07:11 (snpslmd) SK_Noffset-3D_all SK_OptimISE-DOE SK_OptimISE-DOE_all
18:07:11 (snpslmd) SK_OptimISE-Iterative SK_OptimISE-Iterative_all SK_OptimISE-RSMOpt
18:07:11 (snpslmd) SK_OptimISE-RSMOpt_all SK_OptimISE-Statistical SK_OptimISE-Statistical_all
18:07:11 (snpslmd) SK_ProcessExplorer SK_ProcessExplorer_all SK_Prolyt
18:07:11 (snpslmd) SK_Prolyt_all        SK_sde                SK_sde_all
18:07:11 (snpslmd) SK_sde3d        SK_sde3d_all        SK_sdevice
18:07:11 (snpslmd) SK_sdevice_all        SK_sdevice-3d        SK_sdevice-3d_all
18:07:11 (snpslmd) SK_sdevice-densitygrad SK_sdevice-densitygrad_all SK_sdevice-ferro
18:07:11 (snpslmd) SK_sdevice-ferro_all SK_sdevice-floatinggate SK_sdevice-floatinggate_all
18:07:11 (snpslmd) SK_sdevice-gateleakage SK_sdevice-gateleakage_all SK_sdevice-hetero
18:07:11 (snpslmd) SK_sdevice-hetero_all SK_sdevice-hydro SK_sdevice-hydro_all
18:07:11 (snpslmd) SK_sdevice-kpgain SK_sdevice-kpgain_all SK_sdevice-laser
18:07:11 (snpslmd) SK_sdevice-laser_all SK_sdevice-led        SK_Dessis-Ferro_all
18:07:11 (snpslmd) SK_Dessis-FloatingGate SK_Dessis-FloatingGate_all SK_Dessis-GateLeakage
18:07:11 (snpslmd) SK_Dessis-GateLeakage_all SK_Dessis-Hetero SK_Dessis-Hetero_all
18:07:11 (snpslmd) SK_Dessis-Hydro SK_Dessis-Hydro_all SK_Dessis-kpGain
18:07:11 (snpslmd) SK_Dessis-kpGain_all SK_Dessis-Laser SK_Dessis-Laser_all
18:07:11 (snpslmd) SK_Dessis-LED        SK_Dessis-LED_all SK_Dessis-MixedMode
18:07:11 (snpslmd) SK_Dessis-MixedMode_all SK_Dessis-Mono-Semicond SK_Dessis-Mono-Semicond_all
18:07:11 (snpslmd) SK_Dessis-MonteCarlo SK_Dessis-MonteCarlo_all SK_Dessis-Noise
18:07:11 (snpslmd) SK_Dessis-Noise_all SK_Dessis-Optic SK_Dessis-Optic_all
18:07:11 (snpslmd) SK_Dessis-Parallel SK_Dessis-Parallel_all SK_Dessis-Parallel4
18:07:11 (snpslmd) SK_Dessis-Parallel4_all SK_Dessis-PMI        SK_Dessis-PMI_all
18:07:11 (snpslmd) SK_Dessis-Radiation SK_Dessis-Radiation_all SK_Dessis-Reliability
18:07:11 (snpslmd) SK_Dessis-Reliability_all SK_Dessis-Schroedinger SK_Dessis-Schroedinger_all
18:07:11 (snpslmd) SK_Dessis-SiGe        SK_Dessis-SiGe_all SK_Dessis-Thermo
18:07:11 (snpslmd) SK_Dessis-Thermo_all SK_Dessis-Traps SK_Dessis-Traps_all
18:07:11 (snpslmd) SK_Dessis-VectorOptic SK_Dessis-VectorOptic_all SK_Devise
18:07:11 (snpslmd) SK_Devise_all        SK_Devise-3D        SK_Devise-3D_all
18:07:11 (snpslmd) SK_Dfisetools        SK_Dfisetools_all SK_Dip
18:07:11 (snpslmd) SK_Dip_all        SK_Emlab        SK_Emlab_all
18:07:11 (snpslmd) SK_Emlab-Dessis SK_Emlab-Dessis_all SK_Emlab-Farfield
18:07:11 (snpslmd) SK_Emlab-Farfield_all SK_Emlab-Nonuniform-2D SK_Emlab-Nonuniform-2D_all
18:07:11 (snpslmd) SK_Emlab-Nonuniform-3D SK_Emlab-Nonuniform-3D_all SK_Emlab-Static
18:07:11 (snpslmd) SK_Emlab-Static_all SK_Emlab-Thermal SK_Emlab-Thermal_all
18:07:11 (snpslmd) SK_Emlab-Uniform-2D SK_Emlab-Uniform-2D_all SK_Emlab-Uniform-3D
18:07:11 (snpslmd) SK_Emlab-Uniform-3D_all SK_emw                S4
18:07:11 (snpslmd) S4ED                S4EI                SABER_BUNDLE
18:07:11 (snpslmd) SABER_DEV_MM        SABER_DEV_MMP        SABER_GUIDE
18:07:11 (snpslmd) SABER_GUIDE_MEMSSE SABER_HARNESS        SABER_HARNESS_NETLISTER
18:07:11 (snpslmd) SABER_IF        SABER_INTERFACE SABER_INTERFACE_MEMSSE
18:07:11 (snpslmd) SABER_LEAPFROG_MM SABER_MODELSIM_MM_MEMSSE SABER_MODELSIM_PLUS_MM
18:07:11 (snpslmd) SABER_MODELSIM_PLUS_MM_MEMSSE SABER_MODELSIM_VHDL_MM SABER_MODELSIM_VHDL_MM_MEMSSE
18:07:11 (snpslmd) SABER_MODELSIM_VLOG_MM SABER_PLUGNSIM_MM SABER_QSIM_MM
18:07:11 (snpslmd) SABER_QVSPRO_MM SABER_RT_MM        SABER_RT_MM_MEMSSE
18:07:11 (snpslmd) SABER_RUNTIME        SABER_SCOPE        SABER_SCOPE_MEMSSE
18:07:11 (snpslmd) SABER_SCOPE_NETLIST SABER_SIMMATRIX_MM SABER_SIMULATOR
18:07:11 (snpslmd) SABER_SIMULATOR_MEMSSE SABER_SKETCH        SABER_SKETCH_MEMSSE
18:07:11 (snpslmd) SABER_SKETCH_NETLIST SABER_SKETCH_NETLISTER SABER_SKETCH_NETLISTER_MEMSSE
18:07:11 (snpslmd) SABER_TSP        SABER_VERILOG_MM SABER_VERILOG_MM_MEMSSE
18:07:11 (snpslmd) SABER_VHDLAMS        SABER_VHDLAMS_MEMSSE SABER_VIEWSIM_MM
18:07:11 (snpslmd) SABER_VIEWSIM_MM_MEMSSE SABERRT_ADI        SABERRT_ADI_MEMSSE
18:07:11 (snpslmd) SABERRT_AP2633        SABERRT_FE        SABERRT_FE_MEMSSE
18:07:11 (snpslmd) SABERRT_HIL        SABERRT_HIL_MEMSSE SCAN_TOOL
18:07:11 (snpslmd) SCAN_TOOL_MEMSSE SC-BC                SC-COSIM
18:07:11 (snpslmd) SC-FPGA                SC-HLS                SC-KAZAM
18:07:11 (snpslmd) SC-RTL                SENSITIVITY        SENSITIVITY_MEMSSE
18:07:11 (snpslmd) SEU                SGE-DC-Interface SGE-EDIF-Interface
18:07:11 (snpslmd) SGE-Tool        SGE-Verilog-Interface SGE-VHDL-Interface
18:07:11 (snpslmd) ShortCut-DC-Expert ShortCut-DC-Pro Shortcut-FPGA
18:07:11 (snpslmd) Siloti                Siloti_fe        Siloti_o2
18:07:11 (snpslmd) SilVE                SimVE                SJCL_LIBRARY
18:07:11 (snpslmd) SK_alien2lig        SK_alien2lig_all SK_amat-calib
18:07:11 (snpslmd) SK_amat-calib_all SK_AN-Impl3D        SK_AN-Impl3D_all
18:07:11 (snpslmd) SK_Dessis        SK_Dessis_all        SK_Dessis-3D
18:07:11 (snpslmd) SK_Dessis-3D_all SK_Dessis-DensityGrad SK_Dessis-DensityGrad_all
18:07:11 (snpslmd) SK_Dessis-Ferro RA                RailMacro
18:07:11 (snpslmd) RCXTEO                Reusner                RMAN_RUN
18:07:11 (snpslmd) RouteCompiler        RT54SXS                RTL-Analyzer
18:07:11 (snpslmd) RTL-Analyzer-DAP RTL-Analyzer-Shell RTL-Analyzer-Shell-DAP
18:07:11 (snpslmd) RtlGateCorrelation RTL-Power-Analysis QLOGIC
18:07:11 (snpslmd) QT                Quantum38k        ParDiSo_all
18:07:11 (snpslmd) Parse-Tree-Translator Pathmill-migrate Pathmill-plus-migrate
18:07:11 (snpslmd) PAW                PC-Expert        PhysOpt
18:07:11 (snpslmd) PhysOpt-Beta        PhysOpt-Beta-CTS PhysOpt-Beta-Milkyway
18:07:11 (snpslmd) PhysOpt-Beta-Route PhysOpt-Beta-SI PhysOpt-ClockTree
18:07:11 (snpslmd) PhysOpt-Extraction PhysOpt-GUI        PhysOpt-Hierarchy
18:07:11 (snpslmd) PhysOpt-Integration PhysOpt-MV        PhysOpt-Onroute
18:07:11 (snpslmd) PhysOpt-Parallel PhysOpt-Route        PhysOpt-Route-TD
18:07:11 (snpslmd) PhysOpt-Routing PhysOpt-SI        PhysOpt-Ultra
18:07:11 (snpslmd) PhysOpt-VH        PhysOpt-XG        PLACEHOLDER
18:07:11 (snpslmd) PlanetPL        PlanetRTL        PM
18:07:11 (snpslmd) PNET_LIBRARY        PNEU_HYD_LIBRARY PNEUM_HYD_PRG1
18:07:11 (snpslmd) POLARIS_SCOPE        POLARIS_X        POWER_EXPRESS
18:07:11 (snpslmd) Power-Analysis        Power-Optimization Power-Optimization-Beta1
18:07:11 (snpslmd) Power-Optimization-Beta2 Power-Optimization-Upgrade PPPRT
18:07:11 (snpslmd) Primepower        Primepower_gui        PrimeRail
18:07:11 (snpslmd) PrimeRail-adv        PrimeRail-New-Technology PrimeRail-static
18:07:11 (snpslmd) PrimeTime        PrimeTime_gui        PrimeTime-New-Technology
18:07:11 (snpslmd) PrimeTime-Plus        PrimeTime-PX        PrimeTime-PX-New-Technology
18:07:11 (snpslmd) PrimeTime-PX-Statistical PrimeTime-SI        PrimeTime-VX
18:07:11 (snpslmd) ProcessExplorer ProcessExplorer_all ProcessExplorer_ise
18:07:11 (snpslmd) ProcessExplorer_ise_all Prolyt                Prolyt_all
18:07:11 (snpslmd) Prolyt_ise        Prolyt_ise_all        ProMA-L1
18:07:11 (snpslmd) ProMA-L2        ProMA-LD        ProMA-P1
18:07:11 (snpslmd) ProMA-P2        ProMA-PD        Protocol-Compiler-Analysis
18:07:11 (snpslmd) Protocol-Compiler-COutput Protocol-Compiler-FML Protocol-Compiler-Synth
18:07:11 (snpslmd) Protocol-Compiler-UI PS_CTS                PS_Extraction
18:07:11 (snpslmd) PS_Noise_Optimization PSG-SDE                PsynGui-AARender
18:07:11 (snpslmd) PsynGui-ChipMap PVCSCompiler_Net PVCSRuntime_Net
18:07:11 (snpslmd) OPT_TEMPLATE_LIB OPT_TEMPLATE_LIB_MEMSSE OptimISE-DOE
18:07:11 (snpslmd) OptimISE-DOE_all OptimISE-DOE_ise OptimISE-DOE_ise_all
18:07:11 (snpslmd) OptimISE-Iterative OptimISE-Iterative_all OptimISE-Iterative_ise
18:07:11 (snpslmd) OptimISE-Iterative_ise_all OptimISE-RSMOpt OptimISE-RSMOpt_all
18:07:11 (snpslmd) OptimISE-RSMOpt_ise OptimISE-RSMOpt_ise_all OptimISE-Statistical
18:07:11 (snpslmd) OptimISE-Statistical_all OptimISE-Statistical_ise OptimISE-Statistical_ise_all
18:07:11 (snpslmd) ORCA2A                ORCA2TB                ORCA3C
18:07:11 (snpslmd) ORCA3FPSC        ORCA3L                ORCA4E
18:07:11 (snpslmd) NanoTime        NanoTime-PathMill-Shared NanoTime-ultra
18:07:11 (snpslmd) NCX                NCX-addon        NET-TRAN
18:07:11 (snpslmd) Noffset-2D        Noffset-2D_all        Noffset-2D_ise
18:07:11 (snpslmd) Noffset-2D_ise_all Noffset-3D        Noffset-3D_all
18:07:11 (snpslmd) Noffset-3D_ise        Noffset-3D_ise_all Nova-ExploreRTL-Verilog
18:07:11 (snpslmd) NP                MOS_TOOL        MOS_TOOL_MEMSSE
18:07:11 (snpslmd) MOTIVE-PrimeTime MOTOR_DCPM_TOOL MOTOR_DCPM_TOOL_MEMSSE
18:07:11 (snpslmd) MV-Astro-Opt        MVerilog        MV-Opt
18:07:11 (snpslmd) MWAPIaccess        MWAPIdev        MVRC
18:07:11 (snpslmd) MVSIM                MACH1                MACH2
18:07:11 (snpslmd) MACH3                MACH4                MACH5
18:07:11 (snpslmd) MAdv                Magellan        Magellan-Shell
18:07:11 (snpslmd) Magellan-Sim        Magellan-TB        Mars
18:07:11 (snpslmd) MAST_COMPILER        MAX3000A        MAX7000
18:07:11 (snpslmd) MAX7000A        MAX7000AE        MAX7000B
18:07:11 (snpslmd) MAX7000E        MAX7000S        MAX9000
18:07:11 (snpslmd) MCD                MCE                MCE-Base
18:07:11 (snpslmd) MCE-Eval        MCE-Lib-ALU        MCE-Lib-Arith1
18:07:11 (snpslmd) MCE-Lib-Arith2        MCE-Lib-Arith3        MCE-Lib-Logic
18:07:11 (snpslmd) MC-Pro                MC-Pro-RP        MC-Retime
18:07:11 (snpslmd) MD                MDAM                MDataCheck
18:07:11 (snpslmd) MDataPrep        MDCA                MDHJ
18:07:11 (snpslmd) MDLT                MDOD                MDPD
18:07:11 (snpslmd) MDTC                MDynLink        MEASURE
18:07:11 (snpslmd) MEASURE_MEMSSE        MEMPRO                MEMPRO-LIB
18:07:11 (snpslmd) MEMS                MENTOR_FRAMEWAY MENTOR_FRAMEWAY_MEMSSE
18:07:11 (snpslmd) MENTOR_NETLISTER MENTOR_NETLISTER_MEMSSE Mentor-Interface
18:07:11 (snpslmd) MERCURY                Mesh1D                Mesh1D_all
18:07:11 (snpslmd) Mesh1D_ise        Mesh1D_ise_all        Mesh2D
18:07:11 (snpslmd) Mesh2D_all        Mesh2D_ise        Mesh2D_ise_all
18:07:11 (snpslmd) Mesh3D                Mesh3D_all        Mesh3D_ise
18:07:11 (snpslmd) Mesh3D_ise_all        MG                MI
18:07:11 (snpslmd) MICROCOSM_LIB        MICROCOSM_LIB_MEMSSE MICROCOSM_LIB2
18:07:11 (snpslmd) MICROCOSM_LIB2_MEMSSE MICROCOSM_LIB3        MICROCOSM_LIB3_MEMSSE
18:07:11 (snpslmd) MICROCOSM_LIB4        MICROCOSM_LIB4_MEMSSE MICROCOSM_LIB5
18:07:11 (snpslmd) MICROCOSM_LIB5_MEMSSE MICROCOSM_LIB6        MICROCOSM_LIB6_MEMSSE
18:07:11 (snpslmd) MICROCOSM_LIB7        MICROCOSM_LIB7_MEMSSE MIF-Reader
18:07:11 (snpslmd) MIF-Writer        Milkyway        Milkyway-Interface
18:07:11 (snpslmd) Milkyway-MDE        Millennium-ATPG-EE Millennium-ATPG-STD
18:07:11 (snpslmd) Millennium-Beta Millennium-DRC        Millennium-Eval
18:07:11 (snpslmd) Millennium-FS        Mixed-Language        Mixed-Paradigm
18:07:11 (snpslmd) MODEL_ARCHITECT MODEL_ENCRYPTION MODEL_ENCRYPTION_MEMSSE
18:07:11 (snpslmd) MODEL_SYNTHESIS MODEL_SYNTHESIS_MEMSSE MODPEX
18:07:11 (snpslmd) MODPEX_AQUEDUCT MODPEX_ASIM        MODPEX_ATFT
18:07:11 (snpslmd) MODPEX_AWB        MODPEX_CTC        MODPEX_ELDO
18:07:11 (snpslmd) MODPEX_MARELLI        MODPEX_NOPOWER        MODPEX_PTFT
18:07:11 (snpslmd) MODPEX_SABER        MODPEX_STATIS        MODPEX_TVS
18:07:11 (snpslmd) MONTE_CARLO        MONTE_CARLO_MEMSSE Laker_AMS
18:07:11 (snpslmd) Laker_iDRC        Laker_iLVS        Laker_L1
18:07:11 (snpslmd) Laker_L2        Laker_L3        Laker_T1
18:07:11 (snpslmd) Laker_T1_LE        Laker_Viewer        Leakage-Power
18:07:11 (snpslmd) Library-Compiler Ligament        Ligament_all
18:07:11 (snpslmd) Ligament_ise        Ligament_ise_all LigamentFE
18:07:11 (snpslmd) LigamentFE_all        LigamentFE_ise        LigamentFE_ise_all
18:07:11 (snpslmd) LINK_MATLAB        LINK_MATLAB_MEMSSE LINK_XMATH
18:07:11 (snpslmd) LINYE                LMCSwift        LMCSwift_Net
18:07:11 (snpslmd) LMCSwift_Node        LO                LOAD_TOOL
18:07:11 (snpslmd) LOAD_TOOL_MEMSSE LP                LSA
18:07:11 (snpslmd) LSA_MEMSSE        LSI-Interface        LSS4E
18:07:11 (snpslmd) LTL-100                LTL-100_CIF        LTL-100_GDS
18:07:11 (snpslmd) LTL-100_NDW        LTX_LIBRARY        LYNX-DS
18:07:11 (snpslmd) LYNX-FRS        LYNX-TSL        Key-Generator
18:07:11 (snpslmd) JUAdvOptA        JUAdvOptB        JUAOPAS
18:07:11 (snpslmd) JUAPlan                JUATime                JUAUD
18:07:11 (snpslmd) JUClock                JUDP                JUOPAS
18:07:11 (snpslmd) Jupiter                JupiterXT        JupiterXT_VF
18:07:11 (snpslmd) JUPlan                JUTime                JUUD
18:07:11 (snpslmd) JUVS                IC_DESIGN_LIB        ICInteractive
18:07:11 (snpslmd) IMECH_LIBRARY        INCREMENTs        Inspect
18:07:11 (snpslmd) Inspect_all        Inspect_ise        Inspect_ise_all
18:07:11 (snpslmd) Interface-Shell Interfise_all        IQBUS_AUTHOR
18:07:11 (snpslmd) IQBUS_AUTHOR_MEMSSE IQBUS_DESIGNER        IQBUS_LIB
18:07:11 (snpslmd) IQBUS_LIB_MEMSSE IROI                ISExtract_all
18:07:11 (snpslmd) HARNESS_CATIA        HARNESS_MCADREAD HARNESS_PROCABLE
18:07:11 (snpslmd) HARNESS_UNIGRAPHICS HDL                HDL2SC_mixed
18:07:11 (snpslmd) HDL2SC_verilog        HDL2SC_vhdl        HDL-Advisor
18:07:11 (snpslmd) HDL-Advisor-Estimator HDL-Advisor-Estimator-Package HDL-Advisor-Package
18:07:11 (snpslmd) HDL-Advisor-Shell HDL-Advisor-Shell-Estimator HDL-Advisor-Shell-Estm-Package
18:07:11 (snpslmd) HDL-Advisor-Shell-Package HDL-Compiler        HDL-Compiler-Old
18:07:11 (snpslmd) HDL-Compiler-SystemVerilog HERCULES_DEBUGGER HERCULES_DEVICE
18:07:11 (snpslmd) HERCULES_DRC        HERCULES_ERC        HERCULES_HDRC
18:07:11 (snpslmd) HERCULES_HDRC-HTML HERCULES_HERC-ADV HERCULES_HERC-BASIC
18:07:11 (snpslmd) HERCULES_HLPE        HERCULES_HLVS        HERCULES_HLVS-DEBUG
18:07:11 (snpslmd) HERCULES_HLVS-HTML HERCULES_LVS        HERCULES_MANAGER
18:07:11 (snpslmd) HERCULES_MASK        HERCULES_RCE        HERCULES_VUE
18:07:11 (snpslmd) HERCULES-CRYPT_XREF_DATA HERCULES-DISTRIBUTED HERCULES-DISTRIBUTED-2
18:07:11 (snpslmd) HERCULES-DISTRIBUTED-24 HERCULES-DISTRIBUTED-24/2000.4 HERCULES-DISTRIBUTED-4
18:07:11 (snpslmd) HERCULES-DP_MT        HERCULES-EXPLORER_DRC HERCULES-EXPLORER_FILTERS
18:07:11 (snpslmd) HERCULES-EXPLORER_LVS HERCULES-FINDSHORT HERCULES-NETLIST
18:07:11 (snpslmd) HERCULES-RUN_TRAN HighLevel-Power-Analysis HighLevel-Power-Optimization
18:07:11 (snpslmd) HLS-FPGA-SystemC HLS-SystemC        HSPICE_MODEL_LIBRARY
18:07:11 (snpslmd) HSPICE_MODEL_LIBRARY_MEMSSE Hsp-vacomp        Gaia
18:07:11 (snpslmd) Galaxy_FP_Beta        Galaxy_MultiRoute4 Galaxy_MultiRoute8
18:07:11 (snpslmd) Galaxy-AdvCTS        Galaxy-AdvOpt        Galaxy-AdvRules
18:07:11 (snpslmd) Galaxy-AdvTech        Galaxy-Beta        Galaxy-CCS
18:07:11 (snpslmd) Galaxy-Common        Galaxy-CTMesh        Galaxy-DFT
18:07:11 (snpslmd) Galaxy-DFY        Galaxy-FlipChip Galaxy-FP
18:07:11 (snpslmd) Galaxy-FP-AdvCTS Galaxy-FP-AdvTech Galaxy-FP-Hier
18:07:11 (snpslmd) Galaxy-FP-MV        Galaxy-GUI-PNR        Galaxy-GUI-PSYN
18:07:11 (snpslmd) Galaxy-ICC        Galaxy-Internal-Only Galaxy-IU
18:07:11 (snpslmd) Galaxy-MCMM        Galaxy-MV        Galaxy-PNR
18:07:11 (snpslmd) Galaxy-Power        Galaxy-Prototype Galaxy-PSYN
18:07:11 (snpslmd) Galaxy-SPG        Galaxy-Zroute        Galileo
18:07:11 (snpslmd) Galileo-GUI        Galileo-Internal-Only Galileo-PnR
18:07:11 (snpslmd) Galileo-PSYN        Gate2LayoutCorrelation Gate2RTLCorrelation
18:07:11 (snpslmd) GENERICVSP        GENESISe        GENESISe_all
18:07:11 (snpslmd) GENESISe_ise        GENESISe_ise_all GRAPHICS_INTERFACE
18:07:11 (snpslmd) Gsim_dump_advance Gsim_dump_basic Gsim_framework_advance
18:07:11 (snpslmd) Gsim_framework_basic Gsim_snapshot        Gsim_wave
18:07:11 (snpslmd) GuidedTraceAnalysis FPGA-Express-ISP4000-Optimizer FPGA-Express-isp4K-Optimizer
18:07:11 (snpslmd) FPGA-Express-ISP5000-Optimizer FPGA-Express-isp5K-Optimizer FPGA-Express-isp6K-Optimizer
18:07:11 (snpslmd) FPGA-Express-isp7K-Optimizer FPGA-Express-isp8K-Optimizer FPGA-Express-MERCURY-Optimizer
18:07:11 (snpslmd) FPGA-Express-Open-Optimizer FPGA-Express-ORCA2-Optimizer FPGA-Express-ORCA3-Optimizer
18:07:11 (snpslmd) FPGA-Express-Synario-Optimizer FPGA-Express-VHDL-Base FPGA-Express-VHDL-Training
18:07:11 (snpslmd) FPGA-Express-VIRTEX-Optimizer FPGA-Express-VLOG-Base FPGA-Express-XC3k-Optimizer
18:07:11 (snpslmd) FPGA-Express-XC4k-Optimizer FPGA-Express-XC5k-Optimizer FPGA-Express-XC9k-Optimizer
18:07:11 (snpslmd) FPGA-HDL-Bundle FPGA-Library-Compiler FPGA-Option
18:07:11 (snpslmd) FPGA-VHDL-Bundle FPPRT                FPTA
18:07:11 (snpslmd) FPTime                Fridge-GUI        Fridge-Interpolator
18:07:11 (snpslmd) Fridge-Simulation FSM-Reader        FSM-Writer
18:07:11 (snpslmd) FUSE_CHAR        FUSE_CHAR_MEMSSE FusionVantageLmcInterface
18:07:11 (snpslmd) FAILURE_MODE        FAILURE_MODE_MEMSSE FASTPARTS
18:07:11 (snpslmd) FCII-Altera-Edition FCO                FL_cosim_run
18:07:11 (snpslmd) FL_ice_run        FL_multichip_partition FL_recalc
18:07:11 (snpslmd) Flash370i        FLE_main        FLEX10K
18:07:11 (snpslmd) FLEX10KA        FLEX10KB        FLEX10KE
18:07:11 (snpslmd) FLEX6000        FLEX8000        Floops-1D
18:07:11 (snpslmd) Floops-1D_all        Floops-1D_ise        Floops-1D_ise_all
18:07:11 (snpslmd) Floops-1D-MC        Floops-1D-MC_all Floops-1D-MC_ise
18:07:11 (snpslmd) Floops-1D-MC_ise_all Floops-2D        Floops-2D_all
18:07:11 (snpslmd) Floops-2D_ise        Floops-2D_ise_all Floops-2D-MC
18:07:11 (snpslmd) Floops-2D-MC_all Floops-2D-MC_ise Floops-2D-MC_ise_all
18:07:11 (snpslmd) Floops-3D        Floops-3D_all        Floops-3D_ise
18:07:11 (snpslmd) Floops-3D_ise_all Floops-3D-MC        Floops-3D-MC_all
18:07:11 (snpslmd) Floops-3D-MC_ise Floops-3D-MC_ise_all Floops-Parallel_all
18:07:11 (snpslmd) Floops-Parallel4_all Floorplan-Management Formality
18:07:11 (snpslmd) Formality-Beta1 Formality-Beta2 Formality-Distributed
18:07:11 (snpslmd) Formality-DV        Formality-E1        Formality-ESP
18:07:11 (snpslmd) Formality-TransForm Formality-Transit Formality-TX
18:07:11 (snpslmd) FPABP                FPDP                FPGA_Express-APROA-Optimizer
18:07:11 (snpslmd) FPGA-Compiler        FPGA-Express        FPGA-Express-32OODx-Optimizer
18:07:11 (snpslmd) FPGA-Express-A1200XL-Optimizer FPGA-Express-A1400-Optimizer FPGA-Express-A3200DX-Optimizer
18:07:11 (snpslmd) FPGA-Express-A42MX-Optimizer FPGA-Express-A54SX-Optimizer FPGA-Express-APEX2-Optimizer
18:07:11 (snpslmd) FPGA-Express-APROA-Optimizer FPGA-Express-Constraint-Mgr FPGA-Express-EP20k-Optimizer
18:07:11 (snpslmd) FPGA-Express-EPF10k-Optimizer FPGA-Express-EPF6k-Optimizer FPGA-Express-EPF8k-Optimizer
18:07:11 (snpslmd) FPGA-Express-EPM7k-Optimizer FPGA-Express-EPM9k-Optimizer FPGA-Express-GAT
18:07:11 (snpslmd) FPGA-Express-isp1K-Optimizer FPGA-Express-isp2K-Optimizer FPGA-Express-isp3K-Optimizer
18:07:11 (snpslmd) E3                E5                E502
18:07:11 (snpslmd) E505                E520                Early-Access-Technology
18:07:11 (snpslmd) ECL-Compiler        ECO-Compiler        EDIF_NETLISTER
18:07:11 (snpslmd) EDIF_NETLISTER_MEMSSE EDIF-Netlist-Read-DC EDIF-Netlist-Write-DC
18:07:11 (snpslmd) EDIF-Netlist-Writer EDIF-Reader        EDIF-Schematic-Writer
18:07:11 (snpslmd) ELGRECO_Davis        ELGRECO_DesignCenter ELGRECO_Simulator
18:07:11 (snpslmd) Emlab                Emlab_all        Emlab_ise
18:07:11 (snpslmd) Emlab_ise_all        Emlab-Dessis        Emlab-Dessis_all
18:07:11 (snpslmd) Emlab-Dessis_ise Emlab-Dessis_ise_all Emlab-Farfield
18:07:11 (snpslmd) Emlab-Farfield_all Emlab-Farfield_ise Emlab-Farfield_ise_all
18:07:11 (snpslmd) Emlab-Nonuniform-2D Emlab-Nonuniform-2D_all Emlab-Nonuniform-2D_ise
18:07:11 (snpslmd) Emlab-Nonuniform-2D_ise_all Emlab-Nonuniform-3D Emlab-Nonuniform-3D_all
18:07:11 (snpslmd) Emlab-Nonuniform-3D_ise Emlab-Nonuniform-3D_ise_all Emlab-Static
18:07:11 (snpslmd) Emlab-Static_all Emlab-Static_ise Emlab-Static_ise_all
18:07:11 (snpslmd) Emlab-Thermal        Emlab-Thermal_all Emlab-Thermal_ise
18:07:11 (snpslmd) Emlab-Thermal_ise_all Emlab-Uniform-2D Emlab-Uniform-2D_all
18:07:11 (snpslmd) Emlab-Uniform-2D_ise Emlab-Uniform-2D_ise_all Emlab-Uniform-3D
18:07:11 (snpslmd) Emlab-Uniform-3D_all Emlab-Uniform-3D_ise Emlab-Uniform-3D_ise_all
18:07:11 (snpslmd) ENACE                ENACS                Enterprise
18:07:11 (snpslmd) Enterprise_VO        Equation-Reader Equation-Writer
18:07:11 (snpslmd) Espresso-Reader Espresso-Writer EssentialSignalAnalysis
18:07:11 (snpslmd) Estm-HDL-Advisor Estm-HDL-Advisor-Package EV-ACCESS
18:07:11 (snpslmd) EV-ACCESS_UTIL        Eview                EXCALIBUR_ARM
18:07:11 (snpslmd) EXCALIBUR_MIPS        EXPT_EDITOR        EXPT_EDITOR_MEMSSE
18:07:11 (snpslmd) EXPT_EDITOR_PLUS EXPT_EDITOR_PLUS_MEMSSE Extraction
18:07:11 (snpslmd) Dios-MC_all        Dios-PDEF_all        Dios-SDO_all
18:07:11 (snpslmd) DiosSmall_all        Dip                Dip_all
18:07:11 (snpslmd) Dip_ise                Dip_ise_all        DIRECTMEM
18:07:11 (snpslmd) DRCYCLE_TOOL        DRCYCLE_TOOL_MEMSSE DS-Schem-Gen
18:07:11 (snpslmd) DS-Schem-Gen-Estimator-Pa DS-Schem-Gen-Estimator-Package DS-Schem-Gen-Package
18:07:11 (snpslmd) DS-Verinet        DS-Verinet-Estimator-Pack DS-Verinet-Estimator-Package
18:07:11 (snpslmd) DS-Verinet-Package DS-Vhdlnet        DS-Vhdlnet-Estimator-Pack
18:07:11 (snpslmd) DS-Vhdlnet-Estimator-Package DS-Vhdlnet-Package DV
18:07:11 (snpslmd) DVAM                DVCA                DVHJ
18:07:11 (snpslmd) DVLT                DVOD                DVPD
18:07:11 (snpslmd) DVTC                DW-Developer        DW-IP-Consultant
18:07:11 (snpslmd) DW-IP-DEBUG        DW-IP-Developer DC-FPGA-Features
18:07:11 (snpslmd) Dessis-MixedMode_ise Dessis-MixedMode_ise_all Dessis-Mono-Semicond
18:07:11 (snpslmd) Dessis-Mono-Semicond_all Dessis-Mono-Semicond_ise Dessis-Mono-Semicond_ise_all
18:07:11 (snpslmd) Dessis-MonteCarlo Dessis-MonteCarlo_all Dessis-MonteCarlo_ise
18:07:11 (snpslmd) Dessis-MonteCarlo_ise_all Dessis-Noise        Dessis-Noise_all
18:07:11 (snpslmd) Dessis-Noise_ise Dessis-Noise_ise_all Dessis-Optic
18:07:11 (snpslmd) Dessis-Optic_all Dessis-Optic_ise Dessis-Optic_ise_all
18:07:11 (snpslmd) Dessis-Parallel Dessis-Parallel_all Dessis-Parallel_ise
18:07:11 (snpslmd) Dessis-Parallel_ise_all Dessis-Parallel4 Dessis-Parallel4_all
18:07:11 (snpslmd) Dessis-Parallel4_ise Dessis-Parallel4_ise_all Dessis-PMI
18:07:11 (snpslmd) Dessis-PMI_all        Dessis-PMI_ise        Dessis-PMI_ise_all
18:07:11 (snpslmd) Dessis-Radiation Dessis-Radiation_all Dessis-Radiation_ise
18:07:11 (snpslmd) Dessis-Radiation_ise_all Dessis-Reliability Dessis-Reliability_all
18:07:11 (snpslmd) Dessis-Reliability_ise Dessis-Reliability_ise_all Dessis-Schroedinger
18:07:11 (snpslmd) Dessis-Schroedinger_all Dessis-Schroedinger_ise Dessis-Schroedinger_ise_all
18:07:11 (snpslmd) Dessis-SiGe        Dessis-SiGe_all Dessis-SiGe_ise
18:07:11 (snpslmd) Dessis-SiGe_ise_all Dessis-Thermo        Dessis-Thermo_all
18:07:11 (snpslmd) Dessis-Thermo_ise Dessis-Thermo_ise_all Dessis-Traps
18:07:11 (snpslmd) Dessis-Traps_all Dessis-Traps_ise Dessis-Traps_ise_all
18:07:11 (snpslmd) Dessis-VectorOptic Dessis-VectorOptic_all Dessis-VectorOptic_ise
18:07:11 (snpslmd) Dessis-VectorOptic_ise_all Devise                Devise_all
18:07:11 (snpslmd) Devise_ise        Devise_ise_all        Devise-3D
18:07:11 (snpslmd) Devise-3D_all        Devise-3D_ise        Devise-3D_ise_all
18:07:11 (snpslmd) DF                Dfisetools        Dfisetools_all
18:07:11 (snpslmd) Dfisetools_ise        Dfisetools_ise_all Dfisetools-Topo_all
18:07:11 (snpslmd) DIODE_TOOL        DIODE_TOOL_MEMSSE Dios_all
18:07:11 (snpslmd) Dios-3D_all        DesignWare-MemoryBist-Source DesignWare-MGI
18:07:11 (snpslmd) DesignWare-MPEG DesignWare-MPEG2 DesignWare-MPEG2-Source
18:07:11 (snpslmd) DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source DesignWare-MPEG-Source
18:07:11 (snpslmd) DesignWare-Package DesignWare-PCI        DesignWare-PCIbasic
18:07:11 (snpslmd) DesignWare-PCI-Source DesignWare-PCI-X DesignWare-PCI-X-Source
18:07:11 (snpslmd) DESIGNWARE-REGRESSION DESIGNWARE-SIO-VIP DesignWare-SystemIO
18:07:11 (snpslmd) DesignWare-SystemIO-Source DesignWare-TCA        DesignWare-TCA-Source
18:07:11 (snpslmd) DesignWare-USB        DesignWare-USB2 DesignWare-USB2-Source
18:07:11 (snpslmd) DesignWare-USB-Source DESIGNWARE-USB-VIP DesignWare-VERA
18:07:11 (snpslmd) DESIGNWARE-VERIFICATION Dessis                Dessis_all
18:07:11 (snpslmd) Dessis_ise        Dessis_ise_all        Dessis-3D
18:07:11 (snpslmd) Dessis-3D_all        Dessis-3D_ise        Dessis-3D_ise_all
18:07:11 (snpslmd) Dessis-BONSIM_all Dessis-DensityGrad Dessis-DensityGrad_all
18:07:11 (snpslmd) Dessis-DensityGrad_ise Dessis-DensityGrad_ise_all Dessis-Ferro
18:07:11 (snpslmd) Dessis-Ferro_all Dessis-Ferro_ise Dessis-Ferro_ise_all
18:07:11 (snpslmd) Dessis-FloatingGate Dessis-FloatingGate_all Dessis-FloatingGate_ise
18:07:11 (snpslmd) Dessis-FloatingGate_ise_all Dessis-GateLeakage Dessis-GateLeakage_all
18:07:11 (snpslmd) Dessis-GateLeakage_ise Dessis-GateLeakage_ise_all Dessis-Hetero
18:07:11 (snpslmd) Dessis-Hetero_all Dessis-Hetero_ise Dessis-Hetero_ise_all
18:07:11 (snpslmd) Dessis-Hydro        Dessis-Hydro_all Dessis-Hydro_ise
18:07:11 (snpslmd) Dessis-Hydro_ise_all Dessis-kpGain        Dessis-kpGain_all
18:07:11 (snpslmd) Dessis-kpGain_ise Dessis-kpGain_ise_all Dessis-Laser
18:07:11 (snpslmd) Dessis-Laser_all Dessis-Laser_ise Dessis-Laser_ise_all
18:07:11 (snpslmd) Dessis-LED        Dessis-LED_all        Dessis-LED_ise
18:07:11 (snpslmd) Dessis-LED_ise_all Dessis-MixedMode Dessis-MixedMode_all
18:07:11 (snpslmd) D3                DataExpansion        DataExpansionCoverage
18:07:11 (snpslmd) DataExpansionSim DATAIO                DataReplay
18:07:11 (snpslmd) DataReplaySim        DB-Mode                DC64
18:07:11 (snpslmd) DC-Beta                DC-Cadence-Interface DC-Expert
18:07:11 (snpslmd) DCExpert-PrimeTime DC-Extension        DC-Falcon-Interface
18:07:11 (snpslmd) DC-FPGA-Accelerator DC-FPGA-Add-On        DC-FPGA-Add-On-to-DC
18:07:11 (snpslmd) DC-FPGA-INCREMENTs DC-Layout-Interface DCM-Delay-Calculation
18:07:11 (snpslmd) DC-Min-Area-Retime DC-SDF-Interface DCT-Congestion
18:07:11 (snpslmd) DCT-GUI                DC-Topographical DC-Ultra
18:07:11 (snpslmd) DC-Ultra-Features DC-Ultra-INCREMENTs DC-Ultra-Opt
18:07:11 (snpslmd) DC-XG                DE                Debussy
18:07:11 (snpslmd) Debussy_shared        Delta39k        DEMO
18:07:11 (snpslmd) Design-Analyzer Design-Analyzer-DAP Design-Budgeting
18:07:11 (snpslmd) Design-Compiler Design-Estimator Design-Estimator-FPI
18:07:11 (snpslmd) Design-Expert        DesignSource        DesignSource-Estimator-Package
18:07:11 (snpslmd) DesignSource-Package DESIGNSTAR        DESIGNSTAR_NET
18:07:11 (snpslmd) DesignTime        Design-Vision        DesignWare
18:07:11 (snpslmd) DesignWare-1394 DesignWare-1394-Source DesignWare-6811-Source
18:07:11 (snpslmd) DesignWare-8051 DesignWare-8051MCU DesignWare-8051-Source
18:07:11 (snpslmd) DesignWare-AMBA-tlm DESIGNWARE-AMBA-VIP DesignWare-ARMCORES-tlm
18:07:11 (snpslmd) Designware-Basic DesignWare-BIST DesignWare-BIST-Source
18:07:11 (snpslmd) DesignWare-Cardbus Designware-Developer DesignWare-Developer-MGI
18:07:11 (snpslmd) DesignWare-ETHERNET DesignWare-ETHERNET-Source DESIGNWARE-ETHERNET-VIP
18:07:11 (snpslmd) DesignWare-FloatingPoint DesignWare-Foundation DesignWare-Foundation-Exp
18:07:11 (snpslmd) DesignWare-Foundation-Expert DesignWare-Foundation-Power DesignWare-Foundation-Ultra
18:07:11 (snpslmd) Designware-FPGA-Basic DESIGNWARE-I2C-VIP DesignWare-ISA-PnP
18:07:11 (snpslmd) DesignWare-MEMCTL-Source DesignWare-MemoryBist Cyclone-Simulator
18:07:11 (snpslmd) Cyclone-VHDL-Analyzer CYPRESS                COSSAP_gsmfrsc
18:07:11 (snpslmd) COSSAP_gsmhrcc        COSSAP_dcg_ariel32c COSSAP_dcg_fe
18:07:11 (snpslmd) COSSAP_dcg_gc        COSSAP_dcg_krc        COSSAP_dcg_lsic30s
18:07:11 (snpslmd) COSSAP_dcg_m96000 COSSAP_dcg_mp        COSSAP_ddk_arm
18:07:11 (snpslmd) COSSAP_ddk_devlp COSSAP_ddk_dsp16000 COSSAP_ddk_dsp1610
18:07:11 (snpslmd) COSSAP_ddk_hawk COSSAP_ddk_nec        COSSAP_ddk_oak
18:07:11 (snpslmd) COSSAP_ddk_pine COSSAP_ddk_ssp16xx COSSAP_ddk_tic5x
18:07:11 (snpslmd) COSSAP_ddk_tic5xx COSSAP_dect        COSSAP_dvb
18:07:11 (snpslmd) COSSAP_ecc        COSSAP_gsmdve        COSSAP_gsmdve_utils
18:07:11 (snpslmd) COSSAP_gsmefrsc COSSAP_gsmeq        COSSAP_gsmfrcc
18:07:11 (snpslmd) COSSAP_gsmhrsc        COSSAP_gsmphy        COSSAP_is136
18:07:11 (snpslmd) COSSAP_is95        COSSAP_matlab        COSSAP_mfd
18:07:11 (snpslmd) COSSAP_mpeg2        COSSAP_pdc        COSSAP_qed
18:07:11 (snpslmd) COSSAP_sds        COSSAP_srcfd        COSSAP_vcg_generic
18:07:11 (snpslmd) COSSAP_vcg_synopsys COSSAP_vcg_vantage COSSAP_vdefcg
18:07:11 (snpslmd) COSSAP_vdefcg_vlgxl COSSAP_vsiccg        COSSAP_vsiccg_cyc
18:07:11 (snpslmd) COSSAP_vsiccg_mti COSSAP_vsiccg_mtivlg COSSAP_vsiccg_vcs
18:07:11 (snpslmd) COSSAP_vsiccg_vlgxl COSSAP_vsivcg        COSSAP_vsivcg_vlgxl
18:07:11 (snpslmd) COSSAP_xdcg        COSSAP_xvcg        COSSAP_xvsi
18:07:11 (snpslmd) COVENTOR_LIB10        COVENTOR_LIB10_MEMSSE COVENTOR_LIB11
18:07:11 (snpslmd) COVENTOR_LIB11_MEMSSE COVENTOR_LIB12        COVENTOR_LIB12_MEMSSE
18:07:11 (snpslmd) COVENTOR_LIB13        COVENTOR_LIB13_MEMSSE COVENTOR_LIB14
18:07:11 (snpslmd) COVENTOR_LIB14_MEMSSE COVENTOR_LIB15        COVENTOR_LIB15_MEMSSE
18:07:11 (snpslmd) COVENTOR_LIB8        COVENTOR_LIB8_MEMSSE COVENTOR_LIB9
18:07:11 (snpslmd) COVENTOR_LIB9_MEMSSE CoverMeter        CoverMeterOBC
18:07:11 (snpslmd) CoverMeterOBCVCSAMSCompiler CPI-100                CRS_COVERMETER
18:07:11 (snpslmd) CRS_VCM                CRS_VCS                CRS_VCSi
18:07:11 (snpslmd) CTV-Interface        CUSTOM_LIB        CXp_Analysis
18:07:11 (snpslmd) CXp_CircuitEnvironment CXp_GUI                Cyclone-Code-Generator
18:07:11 (snpslmd) Cyclone-Core        Cyclone-cosim        Cyclone-Elaborator
18:07:11 (snpslmd) Cyclone-GUI        Cyclone-HDL-Analyzer CA-Chip-Edit
18:07:11 (snpslmd) CA-CP-Advanced        CA-CP-Basic        CA-CP-Standard
18:07:11 (snpslmd) CADENCE_DIVA_NETLISTER CADENCE_FRAMEWAY CADENCE_FRAMEWAY_MEMSSE
18:07:11 (snpslmd) CADENCE_NETLISTER CADENCE_NETLISTER_MEMSSE CA-Foundation
18:07:11 (snpslmd) CA-Frame        CA-Hier-Timer        CA-Optimization
18:07:11 (snpslmd) CA-Timer        CA-Utils        CBA-ApolloGA-Interface
18:07:11 (snpslmd) CBA-Blk-Export        CBA-Blk-Import        CBA-CadenceSE-Interface
18:07:11 (snpslmd) CBA-DS-Beta        CBA-Frame        CBA-Logical-DS
18:07:11 (snpslmd) CBA-Logical-MA        CBA-Physical-DS CBA-Physical-MA
18:07:11 (snpslmd) CBA-Transport        CD-Compiled-Lib-Gen CD-Compiled-Sys-Gen
18:07:11 (snpslmd) CD-GDI                CD-GDII-Link        CD-Model-Developer
18:07:11 (snpslmd) CD-MSSC-Cross-Probe CD-MSSC-Netlist CD-Present-Builder
18:07:11 (snpslmd) CD-Present-Layer-Gen CD-REX                CD-Vhdlgen-Gen
18:07:11 (snpslmd) CD-Vhdlgen-GUI        CmMonitor        CmView
18:07:11 (snpslmd) CoCentric-FXD-GUI CoCentric-FXD-Interpolator CoCentric-FXD-Simulation
18:07:11 (snpslmd) CoCentric-SYS-Davis CoCentric-SYS-DesignCenter CoCentric-SYS-HWflow
18:07:11 (snpslmd) CoCentric-SYS-HWSimIF CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000
18:07:11 (snpslmd) CoCentric-SYS-RDK-docsis CoCentric-SYS-Simulator Columbia
18:07:11 (snpslmd) ColumbiaTE        COMPONENT_LIBRARY COMPONENT_LIBRARY_MEMSSE
18:07:11 (snpslmd) CONCEPT_FRAMEWAY CONCEPT_NETLISTER Constraint_Translation
18:07:11 (snpslmd) Converter        COOLRUNNER        COOLRUNNER2
18:07:11 (snpslmd) CORENL_CHAR        CORENL_CHAR_MEMSSE COSIM-LFG
18:07:11 (snpslmd) COSIM-MTI        COSIM-NCV        COSIM-SRO
18:07:11 (snpslmd) COSIM-VCS        COSIM-VXL        COSMOS
18:07:11 (snpslmd) COSMOS_GUIDE        COSMOS_SCOPE        COSMOS_SKETCH
18:07:11 (snpslmd) COSMOS_SKETCH_BACK_ANN COSMOS_SKETCH_NETLISTER COSMOS_VO
18:07:11 (snpslmd) COSSAP_adpcm        COSSAP_adsl        COSSAP_amr
18:07:11 (snpslmd) COSSAP_arm        COSSAP_bde        COSSAP_celp
18:07:11 (snpslmd) COSSAP_chart        COSSAP_cw_filter_hdl COSSAP_cw_filter_sds
18:07:11 (snpslmd) COSSAP_dab        COSSAP_dcg_ad21020 COSSAP_dcg_ansic
18:07:11 (snpslmd) BASIC_ANALYSES        BASIC_ANALYSES_MEMSSE BATCH_MEASURE
18:07:11 (snpslmd) BATCH_MEASURE_MEMSSE BATT_TOOL        BATT_TOOL_MEMSSE
18:07:11 (snpslmd) BC-FPGA                BC-FPGA-HDL        BC-FPGA-VHDL
18:07:11 (snpslmd) BC-HDL                BC-Schedule        BC-VHDL
18:07:11 (snpslmd) Behavioral-Analyzer Behavioral-Compiler BETA_LIBRARY
18:07:11 (snpslmd) BOA-BRT                BUILD_DATE        BUILD_NUMBER
18:07:11 (snpslmd) BUNDLE_MCAD_PROJECTION A3200DX                A42MX
18:07:11 (snpslmd) A500K                A54SX                A54SXA
18:07:11 (snpslmd) A7                AARKOS-A        ABB_CHCRC_LIBRARY
18:07:11 (snpslmd) ACEX1K                ACS                ACT2-1200XL
18:07:11 (snpslmd) ACT3                AdvanceCalibration_all AdvancedCalibration_all
18:07:11 (snpslmd) AI                AIM_DEBUG        AIM_DEBUG_MEMSSE
18:07:11 (snpslmd) AIM_DECRYPT        AIM_DEVELOPER        AIM_DEVELOPER_MEMSSE
18:07:11 (snpslmd) AIM_ENCRYPT        ALTGEN1                ALTGEN2
18:07:11 (snpslmd) AN-Impl3D        AN-Impl3D_all        AN-Impl3D_ise
18:07:11 (snpslmd) AN-Impl3D_ise_all APACM                APATD
18:07:11 (snpslmd) APCS                APDP                APEX20K
18:07:11 (snpslmd) APEX20KC        APEX20KE        APEXII
18:07:11 (snpslmd) APGA4AP                APGACS                APGADP
18:07:11 (snpslmd) APGAHPO                APGApwr                APGASolar
18:07:11 (snpslmd) APGASolarII        APGATime        APHPO
18:07:11 (snpslmd) Apollo                ApolloGA        APPower
18:07:11 (snpslmd) APpwr                APRV                APSolar
18:07:11 (snpslmd) APSolarII        APTime                APXtalk
18:07:11 (snpslmd) ARKOS-A                ARKOS-B                ARKOS-C
18:07:11 (snpslmd) ARKOS-D                ARKOS-E                ARKOS-Ice
18:07:11 (snpslmd) ARKOS-Mcomp        ARKOS-Rtlcomp        ARKOS-Scomp
18:07:11 (snpslmd) ARKOS-Simul        ARM7TDMI        Astro
18:07:11 (snpslmd) AstroBeta        AstroExp        Astro-Express
18:07:11 (snpslmd) AstroGA                Astro-MV        AstroRail
18:07:11 (snpslmd) Astro-Rail        AstroRailSA        AstroSpecialBeta
18:07:11 (snpslmd) AstroXtalk        Astro-Xtalk        ATMEL
18:07:11 (snpslmd) ATMWB_ATMLAYER        ATMWB_UTOPIA        AU
18:07:11 (snpslmd) AUSP                AUT_NUMBER_MAJOR_PACKAGES 3D
18:07:11 (snpslmd) 3P
18:07:11 (snpslmd)
18:07:11 (snpslmd) Licenses are case sensitive for TE_CATS
18:07:11 (snpslmd)
18:07:11 (snpslmd) EXTERNAL FILTERS are OFF
18:07:11 (lmgrd) snpslmd using TCP-port 40073
18:07:11 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  archprod  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  everest  extremed  hscd  innologd  ISE-TCADd  knights  la_dmon  leda  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  riod  saber_dmn  sandwork  sclmgrd  sigmacd  SIINT  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd
11/03/2018 18:07:12 (snpslmd) ------------------------------------------------------------------
11/03/2018 18:07:12 (snpslmd) Checking the integrity of the license file...
11/03/2018 18:07:12 (snpslmd) Valid SSS feature found.
11/03/2018 18:07:12 (snpslmd) The feature is needed to enable the other keys in your license file.
11/03/2018 18:07:12 (snpslmd) Licensed to student@eetop
11/03/2018 18:07:12 (snpslmd) Siteid: 26356, Server Hostid: a4db30357557, Issued on: 1/8/2014
18:07:13 (snpslmd) SLOG: Statistics Log Frequency is 240 minute(s).
18:07:13 (snpslmd) SLOG: TS update poll interval is 0. TS update is detected by midnight reread only.
18:07:13 (snpslmd) SLOG: Activation borrow reclaim percentage is 0.
18:07:13 (snpslmd) (@snpslmd-SLOG@) ===============================================
18:07:13 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
18:07:13 (snpslmd) (@snpslmd-SLOG@) Vendor daemon: snpslmd
18:07:13 (snpslmd) (@snpslmd-SLOG@) Start-Date: Sat Nov 03 2018 18:07:13 CST
18:07:13 (snpslmd) (@snpslmd-SLOG@) PID: 2670
18:07:13 (snpslmd) (@snpslmd-SLOG@) VD Version: v11.13.1.0 build 167164 x64_lsb ( build 167164 (ipv6))
18:07:13 (snpslmd) (@snpslmd-SLOG@) === Startup/Restart Info ===
18:07:13 (snpslmd) (@snpslmd-SLOG@) Options file used: None
18:07:13 (snpslmd) (@snpslmd-SLOG@) Is vendor daemon a CVD: Yes
18:07:13 (snpslmd) (@snpslmd-SLOG@) Is TS accessed: No
18:07:13 (snpslmd) (@snpslmd-SLOG@) TS accessed for feature load: -NA-
18:07:13 (snpslmd) (@snpslmd-SLOG@) Number of VD restarts since LS startup: 0
18:07:13 (snpslmd) (@snpslmd-SLOG@) === Network Info ===
18:07:13 (snpslmd) (@snpslmd-SLOG@) Listening port: 40073
18:07:13 (snpslmd) (@snpslmd-SLOG@) Daemon select timeout (in seconds): 1
18:07:13 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
18:07:13 (snpslmd) (@snpslmd-SLOG@) Host used in license file: IC
18:07:13 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: VMWare
18:07:13 (snpslmd) (@snpslmd-SLOG@) LMBIND needed: No
18:07:13 (snpslmd) (@snpslmd-SLOG@) LMBIND port: -NA-
发表于 2018-11-3 18:37:34 | 显示全部楼层
过时了
 楼主| 发表于 2018-11-3 18:46:59 | 显示全部楼层
    虚拟机自带的lic可以用, 只是发现有的feature没有。 软件都是15版左右, 都能启动, 但是缺哪些feature就不好说。
自己做的lic就死活不能用,很头疼
发表于 2018-11-20 23:25:45 | 显示全部楼层
應該是整個都過時了。我原本可用的License,到某一天就變成樓主的呈現的樣子,還沒有解決。不知是否有朋友遇到相同的問題,然後解決了呢?謝謝。
发表于 2018-11-21 00:13:30 | 显示全部楼层
回复 1# elone
請問樓主如何解決呢? 謝謝
 楼主| 发表于 2018-11-21 14:23:03 | 显示全部楼层
回复  elone
請問樓主如何解決呢? 謝謝
jwmiaw 发表于 2018-11-21 00:13
    很低级的错误, LM变量没设对
发表于 2019-9-6 21:25:55 | 显示全部楼层
求license     sdevice-ferro_all sdevice-ferro_ise sdevice-ferro_ise_all
发表于 2021-1-25 13:43:23 | 显示全部楼层
thanks for sharing
发表于 2022-1-24 00:38:27 | 显示全部楼层
THANKS
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 02:24 , Processed in 0.035649 second(s), 5 queries , Gzip On, Redis On.
