#DEFINE BORDER_CHECK YES //valid value is: {YES,NO}
< Choice 15 > deep trench process option
/*If use deep trench process,please change "NO" to "YES"
Default not to check.
#DEFINE Deep_trench_process NO //valid value is: {YES,NO}
#DEFINE CONNECT_ALL_RESISTOR 0
//valid value is:
{0,1}
//;default 0
//;The switch (to connect AA resistor, Hi-R resistor, well resistor
between PAD and AA injector) can control the connectivity of resistor.
//;if value is 0,the connection is broken;
//;if value is 1,the connection is not broken;
