在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1745|回复: 2
CDB 2 OA 失败 出现如下问题
发表于 2018-10-18 17:44:53 | 显示全部楼层 |阅读模式
ERROR   (CDBOA-300): Cannot process <path>/<file> because it is locked.
                      Generated once. The source file is locked. It may be that
                     another user is editing the file or that there are stale
                     edit locks present in the library. The translator stops
                     processing the file and continues with the next file.
                      If you are seeing only isolated instances of this error,
                     remove the file lock on the reported cellview and rerun the
                     translator. If there are many of these errors, it could
                     indicate that there are stale edit locks in the library.
                     Again, you need to remove these and rerun the translator on
                     the affected files and cellviews.
                      You can also use the -ignorelocks argument on the command
                     line to override this check and have the translator convert
                     files and cellviews even if they are locked.
                      Note: The -ignorelocks argument applies only to CDBA data.
                     The translator never overwrites OpenAccess data that is
发表于 2018-10-22 05:51:10 | 显示全部楼层
locked
发表于 2018-10-22 08:42:13 | 显示全部楼层
你的工艺库文件被锁住了,删除工艺库目录下所有的**.cdslck文件和constraint文件夹即可。
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-23 18:13 , Processed in 0.016916 second(s), 7 queries , Gzip On, Redis On.
