在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 5175|回复: 12
Trouble with Assura 4.15-617
发表于 2018-8-27 17:23:34 | 显示全部楼层 |阅读模式
I install Assura 4.10.001-613, after that i update it to Assura 4.15-617 from here: http://bbs.eetop.cn/thread-767675-1-1.html
and now when i start virtuoso i get an error at CDS.log:
  1. \w *WARNING* Cannot find registration file Diva.cdsenv to register environment variables
  2. \w *WARNING* envGetVal: could not find tool[.partition] 'Diva'
  3. \o *Error* (AMS-2168): AMS Unified Netlister cannot create the netlist because the required AMS library '/opt/cadence/assura/tools/affirma_ams/lib/64bit/libmapi.so' does not exist in IC installation. Either fix the issue in your installation or access other AMS netlisters.
  4. \o Loading geView.cxt
  5. \o Loading menuBuilder.cxt
  6. \o Loading schView.cxt
  7. \o Loading selectSv.cxt
  8. \o Loading wireEdit.cxt
  9. \o Loading pte2.cxt
  10. \e *Error* loadContext: could not open file - "/opt/cadence/assura/tools/dfII/etc/context/64bit/transUI.cxt"
  11. \w *WARNING* (autoloads): transUI.cxt was not loaded
  12. \o Loading Skill files for transUI
  13. \e *Error* load: can't access file - "startup.il"
  14. \e ******* Non-recoverable error (no top-level or error handler)
  15. \e ******* Exiting program ...
复制代码
Any ideas? what i'm doing wrong?
发表于 2018-8-28 08:21:09 | 显示全部楼层
 楼主| 发表于 2018-8-28 16:38:25 | 显示全部楼层
Yes, i know. But i don't know why it write it.
I install full Assura 4.15-617 Update. And i do not understand why affirma_ams doesn't include at this update.
I find affirma_ams at incisive 152, but cannot find any docs how to set incisive as main AMS.
i do
  1. export $AMSHOME=/opt/cadence/incisiveexportIUS_ROOT=$AMSHOMEexport  IUSHOME=$AMSHOME
复制代码
But no effect.
 楼主| 发表于 2018-8-28 16:42:55 | 显示全部楼层
maomao198477 发表于 2018-8-28 08:21
Yes, i can read =)I install full Assura 4.15-617 update, but it, as i mean, doesn't include affrima_ams. I cannot understand why.
I find it in incisive 152 packages... But i haven't docs for  setup Cadence packages, because what i cannot understand how to set incisive as default AMS.
I do
  1. export  AMSHOME=/opt/cadence/incisive/        export  IUS_ROOT=$AMSHOME        export  IUSHOME=$AMSHOME
复制代码
at my .bashrc, but no effect!
I cannot find my mistake (
发表于 2018-8-28 17:46:17 | 显示全部楼层
can you share the Assura 4.10.001-613??? cannot install 4.15-617. please
 楼主| 发表于 2018-8-28 17:57:56 | 显示全部楼层
kostser2002 发表于 2018-8-28 17:46
link: https://pan.baidu.com/s/1f06wxoaC39pUGiDfrVTxmA
Passwd: passw.txt (11 Bytes, 下载次数: 57 )
发表于 2018-9-30 15:29:25 | 显示全部楼层
It seems that the Assura version must be match the Virtuoso version correctely.
for example ,if you use IC617,you must match ASSURA415-617,while Assura410-613 cann't work in IC617.
Actually,you just %setenv ASSURAHOME [install_dir]
%set path
in the same enviroment of IC617,it can work well.
发表于 2018-10-7 16:55:11 | 显示全部楼层
In your path environment variable you have to put installation directory for IC617 before installation directory for your ASSURA415-617. Only in this case you will not have a problem!
发表于 2019-4-22 14:04:35 | 显示全部楼层
Passwd:
谢谢该楼主
发表于 2019-4-23 10:26:04 | 显示全部楼层
avview error while loading shared libraries:lib_cadencehelp.so.2:connot open shared object file
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-17 04:55 , Processed in 0.031644 second(s), 7 queries , Gzip On, Redis On.
