在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2421|回复: 2
VCS 编译出错 不能生成simv文件
发表于 2018-8-19 20:02:28 | 显示全部楼层 |阅读模式
VCS编译后的错误提示:
/usr/bin/x86_64-linux-gnu-ld: /home/dalys/software/synopsys/verdi/share/PLI/VCS/LINUXAMD64/pli.a(vcs_init.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a PIE object; recompile with -fPIC
/usr/bin/x86_64-linux-gnu-ld: /home/dalys/software/synopsys/verdi/share/PLI/VCS/LINUXAMD64/pli.a(vcs_core_select.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a PIE object; recompile with -fPIC
/usr/bin/x86_64-linux-gnu-ld: /home/dalys/software/synopsys/vcs/linux64/lib/vcs_save_restore_new.o: relocation R_X86_64_32S against undefined symbol `_sigintr' can not be used when making a PIE object; recompile with -fPIC
/usr/bin/x86_64-linux-gnu-ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
Makefile:107: recipe for target 'product_timestamp' failed
make: *** [product_timestamp] Error 1
Make exited with status 2
cpu time: .265 seconds to compile + .476 seconds to elab + .313 seconds to link[/code]
发表于 2018-11-2 17:34:24 | 显示全部楼层
遇到了同样的问题,楼主有解决吗?
发表于 2018-11-2 19:08:21 | 显示全部楼层
回复 1# DALYS
   楼主解决了吗,遇到同样问题
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-16 21:57 , Processed in 0.017763 second(s), 6 queries , Gzip On, Redis On.
