在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
EETOP诚邀模拟IC相关培训讲师 创芯人才网--重磅上线啦!
查看: 5447|回复: 14
[资料] 资料《Unitrode Applications Handbook 1987-88》
发表于 2018-8-12 11:33:50 | 显示全部楼层 |阅读模式
封面
封面
目录
POWER SUPPLY DESIGN
U-68A  Switching Regulator Design Guide _ ................................................................................. 1
U-73A  The Importance of Rectifier Characteristics in Switching Power Supply Design ....................................... 23
U-76  Flyback and Boost Switching Regulator Design Guide .............................................................. 34
U-81  Detecting Impending Core Saturation in Switched-Mode Power Converters ........................................... 56
U-82  Hybrid Circuits for Low Voltage Switched-Mode Converters ......................................................... 64
U-83  Incorporate Active Inrush Current Limiting to Improve Reliability and Efficiency of Power Supplies .................... 73
U-85  Design Guide - Power Schottky Rectifiers in a Switching Regulator ................................................. 77
U-87  500W, 200KHz Off-Line Power Supply Using Power MOSFETs ....................................................... 93
U-89  A Second-Generation IC Switch Mode Controller Optimized for High Frequency Power MOSFET Drive ................. 115
U-90  The UC1524A Integrated PWM Control Circuit Provides New Performance Levels for an Old Standard ................ 126
U-91  Applying the UC1840 to Provide Total Control for Low Cost, Primary Referenced Switching Power Systems ........... 138
U-93  A New Integrated Circuit for Current-Mode Control ................................................................ 148
U-94  The UC1901 Simplifies the Problem of Isolated Feedback in Switching Regulators .................................. 157
U-95  Versatile UC1834 Optimizes Linear Regulator Efficiency ........................................................... 169
U-96  A 25 Watt Off-Line Flyback Switching Regulator ................................................................... 192
U-97  Modelling, Analysis and Compensation of the Current-Mode Controller ............................................. 198
U-98  A New IC Optimizes High Speed Power MOSFET Drive for Switching Power Supplies ................................ 204
U-100  UC3842 Provides Low-Cost Current-Mode Control ................................................................. 220
U-101  200KHz Current-Mode Converter Provides 500W .................................................................. 234
U-103  Using Bipolar Synchronous Rectifiers Improves Power Supply Efficiency ............................................ 254
U-107  New Pulse Width Modulator Chip Controls 1MHz Switchers ........................................................ 280
U-108  Schottky Rectifiers for Low Voltage Outputs ....................................................................... 290
DN-3  Minimizing Storage Time When Using Unitrode Switching Regulator Power Output Circuits (PIC600 Series) ........... 299
DN-4  Avoiding Spurious Oscillation When Using Unitrode Switching Regulator Power Output Circuits (PIC600 Series) ....... 300
DN-6  Operating the Switching Regulator Output Circuit (PIC600 Series) at Low Frequencies ............................... 301
DN-20  New High Efficiency Circuit Designs Utilizing Low Saturation Drop Transistor ....................................... 313
ST-A1  250 Watt Off-Line Forward Converter Design Review ............................................................... 316
ST-A2  High Frequency Series Resonant Power Supply - Design Review .................................................. 332
ST-A3  150 Watt Flyback Regulator ...................................................................................... 347
ST-D1  Proportional Base Drive of Bipolar Power Transistors in Switching Power Supplies ................................... 362
ST-13  Limiting Inrush Current to a Switching Power Supply Improves Reliability, Efficiency ................................ 379
ST-PSD-1  Switching Power Supply Design Review, 60 Watt Flyback Regulator ................................................. 383
PC100  Power Conversion Design Guide .................................................................................. 430
TVSlOO  Transient Voltage Suppressor Guide .............................................................................. 471
MOTOR CONTROL DESIGN
U-99
U-102
U-105
U-106
UC3717 and L-C Filter Reduce EMI and Chopping Losses in Step Motor ............................................ 216
UC16371263713637 Switched Mode Controller for DC Motor Drive ................................................ 243
How to Measure KT and Kv Without Measuring Torque or Angular Velocity .......................................... 272
UC3620: Brushless DC Motors Get a Controller IC that Replaces Complex Circuits .................................. 274
1987_Unitrode_Applications_Handbook.part1.rar (10 MB, 下载次数: 91 ) 1987_Unitrode_Applications_Handbook.part2.rar (10 MB, 下载次数: 87 ) 1987_Unitrode_Applications_Handbook.part3.rar (8.2 MB, 下载次数: 64 )
发表于 2018-8-12 20:52:31 | 显示全部楼层
多谢分享
发表于 2018-8-13 09:36:10 | 显示全部楼层
多谢分享
发表于 2018-8-15 09:23:35 | 显示全部楼层
thanks
发表于 2018-9-6 22:01:43 | 显示全部楼层
多谢分享
发表于 2018-9-26 23:22:00 | 显示全部楼层
回复 1# jtopee
    多谢分享
发表于 2018-11-12 16:20:35 | 显示全部楼层
66666
发表于 2021-12-25 17:10:31 来自手机 | 显示全部楼层
谢谢分享
发表于 2021-12-25 18:14:28 来自手机 | 显示全部楼层
谢谢分享
发表于 2021-12-26 13:42:04 | 显示全部楼层
谢谢分享
GMT+8, 2024-4-26 11:43 , Processed in 0.030398 second(s), 6 queries , Gzip On, Redis On.
