compile_ultra 有一个叫做 -top 的option-top Fixes design rule and top-level timing violations in a design. By default, this option fixes all design rule violations, but only those timing violations whose paths cross top-level hierarchical boundaries . if you want this option to fix timing violations for all paths, set the compile_top_all_paths varible to true
介绍如上面, 现在的问题是, 我加上-top 这个参数,和不加 -top 综合出来的是网表 ,在formality 时, 一个能过, 一个过不了
请问,有谁知道这是什么原因吗,或者遇到过类似的情形 |
