在Encounter导入lef文件时,出现警告:
WARNENCLE-200)in 'A' in macro 'ANTENNA' has no ANTENNAGATEAREA value defined.The library data is incomplete and some process antenna rules will not be checked correctly.
lef文件中关于该macro的描写如下:
MACRO ANTENNA
CLASS CORE ANTENNACELL;
PIN A
AntennaDiffArea 1.0764;
END A
END ANTENNA
这是smic18的库的lef文件
我该如何设置ANTENNAGATEAREA的值?这个值是计算来的?还是我随便定义一个都可以? |
