在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1519|回复: 4
[资料] Regular Expressions Cookbook 2nd Edition PDF
发表于 2018-6-15 06:09:49 | 显示全部楼层 |阅读模式
Take the guesswork out of using regular expressions. With more than 140 practical recipes, this cookbook provides everything you need to solve a wide range of real-world problems. Novices will learn basic skills and tools, and programmers and experienced users will find a wealth of detail. Each recipe provides samples you can use right away.
This revised edition covers the regular expression flavors used by C#, Java, JavaScript, Perl, PHP, Python, Ruby, and VB.NET. You’ll learn powerful new tricks, avoid flavor-specific gotchas, and save valuable time with this huge library of practical solutions.
  • Learn regular expressions basics through a detailed tutorial
  • Use code listings to implement regular expressions with your language of choice
  • Understand how regular expressions differ from language to language
  • Handle common user input with recipes for validation and formatting
  • Find and manipulate words, special characters, and lines of text
  • Detect integers, floating-point numbers, and other numerical formats
  • Parse source code and process log files
  • Use regular expressions in URLs, paths, and IP addresses
  • Manipulate HTML, XML, and data exchange formats
  • Discover little-known regular expression tricks and techniques
发表于 2018-6-15 17:21:06 | 显示全部楼层
Where is the attachment?
发表于 2018-6-15 19:43:05 | 显示全部楼层
where ?????
发表于 2018-9-5 20:39:41 | 显示全部楼层
where ?????
发表于 2018-9-5 21:48:59 | 显示全部楼层
在哪里?
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-25 07:24 , Processed in 0.020337 second(s), 6 queries , Gzip On, Redis On.
