在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 19496|回复: 30
Calibre2017.4开始IXL,AOI,AOJ版本的区别
发表于 2018-5-11 11:07:40 | 显示全部楼层 |阅读模式
从2017.4版本开始分成三个版本
Starting with the 2017.4 Calibre releases, the Linux MGC_HOME is packaged into
three trees, IXL, AOI and AOJ.  The different executables are optimized for different Linux distributions. For example, IXL supports RHEL 5 distributions; AOI supports RHEL 6, RHEL 7.1/7.2/7.3, and SLES 11sp2/3/4 distributions; AOJ requires AVX2-capable hardware and supports RHEL 6.8/6.9, RHEL 7.1/7.2/7.3, and SLES 11sp4. AOJ requires a homogeneous environment.  AOJ will notauto-switch to avoid the different results a heterogeneous environment may create.  Please see the Calibre Administrator's Guide for more information on AOJ requirements.
 楼主| 发表于 2018-5-11 11:11:33 | 显示全部楼层
* The Calibre AOI download also contains a separate, parallel tree containing the Calibre MDPDefectReview/NxDAT software. If you are not using MDPDefectReview/NxDAT, it is safe to remove the aoi_nxdat_2018.2_15.10 directory to conserve space.
发表于 2018-5-11 13:40:16 | 显示全部楼层
学习一下版本
发表于 2018-5-11 21:23:04 | 显示全部楼层
学习了
发表于 2018-5-12 00:21:09 | 显示全部楼层
多謝, 學習了
发表于 2018-5-12 08:41:33 | 显示全部楼层
学习一下版本
发表于 2018-5-17 10:59:28 | 显示全部楼层
有没有2018啊
发表于 2018-5-17 15:50:36 | 显示全部楼层
thank you
发表于 2018-5-17 15:53:54 | 显示全部楼层
学习一下版本
发表于 2018-5-21 01:26:42 | 显示全部楼层
calibre 从2017.1就没看到有人分享了
GMT+8, 2025-1-31 01:49 , Processed in 0.022264 second(s), 8 queries , Gzip On, Redis On.
