查看: 15086|回复: 42
5G System Design: Architectural and Functional Considerations
发表于 2018-4-11 19:39:37 | 显示全部楼层 |阅读模式
Patrick Marsch and Ömer Bulakci, "5G System Design: Architectural and Functional Considerations and Long Term Research"
English | ISBN: 1119425123 | 2018 | 608 pages | PDF | 8 MB
This book provides a comprehensive overview of the latest research and standardization progress towards the 5th generation (5G) of mobile communications technology and beyond. It covers a wide range of topics from 5G use cases and their requirements, to spectrum, 5G end–to–end (E2E) system architecture including core network (CN), transport network (TN) and radio access network (RAN) architecture, network slicing, security and network management. It further dives into the detailed functional design and the evaluation of different 5G concepts, and provides details on planned trials and pre–commercial deployments across the globe. While the book naturally captures the latest agreements in 3 rd Generation Partnership Project (3GPP) New Radio (NR) Release 15, it goes significantly beyond this by describing the likely developments towards the final 5G system that will ultimately utilize a wide range of spectrum bands, address all envisioned 5G use cases, and meet or exceed the International Mobile Telecommunications (IMT) requirements for the year 2020 and beyond (IMT–2020). 5G System Design: Architectural and Functional Considerations and Long Term Research is based on the knowledge and consensus from 158 leading researchers and standardization experts from 54 companies or institutes around the globe, representing key mobile network operators, network vendors, academic institutions and regional bodies for 5G. Different from earlier books on 5G, it does not focus on single 5G technology components, but describes the full 5G system design from E2E architecture to detailed functional design, including details on 5G performance, implementation and roll–out.
5G System Design.pdf (8.05 MB , 下载次数: 469 )
发表于 2018-4-12 02:07:26 | 显示全部楼层
Thank you for sharing
发表于 2018-4-12 10:31:12 | 显示全部楼层
good.best
发表于 2018-4-12 20:19:20 | 显示全部楼层
kankankan
发表于 2018-4-22 20:16:50 | 显示全部楼层
5G的资料值得参考
发表于 2018-4-23 09:43:03 | 显示全部楼层
回复 1# ab3028
    thanks for sharing
发表于 2018-4-23 10:03:55 | 显示全部楼层
Thanks for sharing.
发表于 2018-4-23 16:36:31 | 显示全部楼层
发表于 2018-4-24 07:12:05 | 显示全部楼层
回复 1# ab3028
谢谢分享
发表于 2018-4-24 22:03:18 | 显示全部楼层
thanks alot
GMT+8, 2025-12-8 08:48 , Processed in 0.022303 second(s), 6 queries , Gzip On, Redis On.
