在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 16820|回复: 85
[资料] 文字版 High-Speed Signaling: Jitter Modeling, Analysis, and Budgeting
发表于 2018-3-23 17:56:15 | 显示全部楼层 |阅读模式
Kyung Suk (Dan) Oh (Author), Xing Chao (Chuck) Yuan (Author)
Hardcover: 528 pages
Publisher: Prentice Hall; 1 edition (October 16, 2011)
Language: English
ISBN-10: 0132826917
ISBN-13: 978-0132826914
Table of Contents
Chapter 1: Introduction
     Section 1.1. Signal Integrity Analysis Trends
     Section 1.2. Challenges of High-Speed Signal Integrity Design
     Section 1.3. Organization of This Book
Chapter 2: High-Speed Signaling Basics
     Section 2.1. I/O Signaling Basics and Components
     Section 2.2. Noise Sources
     Section 2.3. Jitter Basics and Decompositions
     Section 2.4. Summary
Part I: Channel Modeling and Design
Chapter 3: Channel Modeling and Design Methodology
     Section 3.1. Channel Design Methodology
     Section 3.2. Channel Modeling Methodology
     Section 3.3. Modeling with Electromagnetic Field Solvers
     Section 3.4. Backplane Channel Modeling Example
     Section 3.5. Summary
Chapter 4: Network Parameters
     Section 4.1. Generalized Network Parameters for Multi-Conductor Systems
     Section 4.2. Preparing an Accurate S-Parameter Time-Domain Model
     Section 4.3. Passivity Conditions
     Section 4.4. Causality Conditions
     Section 4.5. Summary
Chapter 5: Transmission Lines
     Section 5.1. Transmission Line Theory
     Section 5.2. Forward and Backward Crosstalk
     Section 5.3. Time-Domain Simulation of Transmission Lines
     Section 5.4. Modeling Transmission Line from Measurements
     Section 5.5. On-Chip Wire Modeling
     Section 5.6. Comparison of On-Chip, Package, and PCB Traces
     Section 5.7. Summary
Part II: Analyzing Link Performance
Chapter 6: Channel Voltage and Timing Budget
     Section 6.1. Timing Budget Equation and Components
     Section 6.2. Fibre Channel Dual-Dirac Model
     Section 6.3. Component-Level Timing Budget
     Section 6.4. Pitfalls of Timing Budget Equation
     Section 6.5. Voltage Budget Equations and Components
     Section 6.6. Summary
Chapter 7: Manufacturing Variation Modeling
     Section 7.1. Introduction to the Taguchi Method
     Section 7.2. DDR DRAM Command/Address Channel Example
     Section 7.3. Backplane Link Modeling Example
     Section 7.4. Summary
Chapter 8: Link BER Modeling and Simulation
     Section 8.1. Historical Background and Chapter Organization
     Section 8.2. Statistical Link BER Modeling Framework
     Section 8.3. Intersymbol Interference Modeling
     Section 8.4. Transmitter and Receiver Jitter Modeling
     Section 8.5. Periodic Jitter Modeling
     Section 8.6. Summary
Chapter 9: Fast Time-Domain Channel Simulation Techniques
     Section 9.1. Fast Time-Domain Simulation Flow Overview
     Section 9.2. Fast System Simulation Techniques
     Section 9.3. Simultaneous Switching Noise Example
     Section 9.4. Comparison of Jitter Modeling Methods
     Section 9.5. Peak Distortion Analysis
     Section 9.6. Summary
Chapter 10: Clock Models in Link BER Analysis
     Section 10.1. Independent and Common Clock Jitter Models
     Section 10.2. Modeling Common Clocking Schemes
     Section 10.3. CDR Circuitry Modeling
     Section 10.4. Passive Channel JIF and Jitter Amplification
     Section 10.5. Summary
Part III: Supply Noise and Jitter
Chapter 11: Overview of Power Integrity Engineering
     Section 11.1. PDN Design Goals and Supply Budget
     Section 11.2. Power Supply Budget Components
     Section 11.3. Deriving a Power Supply Budget
     Section 11.4. Supply Noise Analysis Methodology
     Section 11.5. Steps in Power Supply Noise Analysis
     Section 11.6. Summary
Chapter 12: SSN Modeling and Simulation
     Section 12.1. SSN Modeling Challenges
     Section 12.2. SI and PI Co-Simulation Methodology
     Section 12.3. Signal Current Loop and Supply Noise
     Section 12.4. Additional SSN Modeling Topics
     Section 12.5. Case Study: DDR2 SSN Analysis for Consumer Applications
     Section 12.6. Summary
Chapter 13: SSN Reduction Codes and Signaling
     Section 13.1. Data Bus Inversion Code
     Section 13.2. Pseudo Differential Signaling Based on 4b6b Code
     Section 13.3. Summary
Chapter 14: Supply Noise and Jitter Characterization
     Section 14.1. Importance of Supply Noise Induced Jitter
     Section 14.2. Overview of PSIJ Modeling Methodology
     Section 14.3. Noise and Jitter Simulation Methodology
     Section 14.4. Case Study
     Section 14.5. Summary
Chapter 15: Substrate Noise Induced Jitter
     Section 15.1. Introduction
     Section 15.2. Modeling Techniques
     Section 15.3. Measurement Techniques
     Section 15.4. Case Study
     Section 15.5. Summary
Chapter 16: On-Chip Link Measurement Techniques
     Section 16.1. Shmoo and BER Eye Diagram Measurements
     Section 16.2. Capturing Signal Waveforms
     Section 16.3. Link Performance Measurement and Correlation
     Section 16.4. On-Chip Supply Noise Measurement Techniques
     Section 16.5. Advanced Power Integrity Measurements
     Section 16.6. Summary
Chapter 17: Signal Conditioning
     Section 17.1. Single-Bit Response
     Section 17.2. Equalization Techniques
     Section 17.3. Equalization Adaptation Algorithms
     Section 17.4. CDR and Equalization Adaptation Interaction
     Section 17.5. ADC-Based Receive Equalization
     Section 17.6. Future of High-Speed Wireline Equalization
     Section 17.7. Summary
Chapter 18: Applications
     Section 18.1. XDR: High-Performance Differential Memory System
     Section 18.2. Mobile XDR: Low Power Differential Memory System
     Section 18.3. Main Memory Systems beyond DDR3
     Section 18.4. Future Signaling Systems
High-Speed Signaling - Jitter-Modeling Analysis and Budgeting.pdf
10.6 MB, 下载次数: 897 , 下载积分: 资产 -4 信元, 下载支出 4 信元
发表于 2018-3-27 00:13:41 | 显示全部楼层
High-Speed Signaling - Jitter-Modeling Analysis and Budgeting.pdf (10.6 MB)
发表于 2018-3-27 15:19:32 | 显示全部楼层
谢谢!!!!
发表于 2018-3-27 15:41:37 | 显示全部楼层
thank you very much
发表于 2018-3-28 18:52:08 | 显示全部楼层
回复 1# jianchongzhou
   good
发表于 2018-4-10 22:23:26 | 显示全部楼层
多谢分享。。。
发表于 2018-4-11 08:51:07 | 显示全部楼层
谢谢!!!!!!!!!!
发表于 2018-4-23 21:53:42 | 显示全部楼层
多谢分享。。
发表于 2018-4-28 15:20:15 | 显示全部楼层
发表于 2018-5-14 15:41:35 | 显示全部楼层
Thanks for sharing
GMT+8, 2024-4-25 20:32 , Processed in 0.045926 second(s), 7 queries , Gzip On, Redis On.
