有兴趣的同学,可以将简历发到ab23com@163.com
1.asic/ layout Design Engineer - PD
RESPONSIBILITIES: - Understand the architecture of the graphics IP and functional block being designed
- Build C/C++ model for simulation
- Build test bench and monitors for DUT
- Compose test plan and validation vectors to ensure functional completeness
- Debug function/performance bugs of graphics IP
- Work with global Front-End design team and physical design team for large scale ASIC chip physical implementation
- Focus on physical design of deep sub-micron GPU chips including block level (full chip) floor planning, timing closure, place&route, physical verification etc
REQUIREMENTS: - Have in depth knowledge of entire design process from Design specification, defining architecture, micro-architecture, RTL design and functional verification, synthesis, Physical Design, Timing closure, Tape-out, and post-Si debug.
- Have hands-on experience in Chiplevel Design/Integration activities.
- Some Physical Design exposure required.
- Perform Synthesis and netlisting tasks such as SDC Development, Scan Insertion, ECO implementation, Formal Verification, etc.
- Some exposure to DFT is a strong plus.
- Work with Physical Design team on Floor Plan, budgeting, timing closure, Signal Integrity, ECO flows, Power analysis, IO PAD placement, etc.
- Should have expertise in: Cadence RTL Compiler, Design Compiler, PrimeTime, Conformal LEC. Good knowledge of datapath compilers is required.
- Expertise in Perl and Tcl is a must.
- Knowledge of chip bus interfaces such as AHB and various standard peripherals & interfaces is a plus.
- Should be able to work closely with RTL Designers and Backend Physical Design teams across multiple sites.
- Must have good communication & Analytical thinking skills.
- Should have proficiency in flow development and scripting.
EDUCATION: - Master with at least 2 years or Bachelor with at least 4 years working experience in ASIC area
2. ASIC Layout Design Engineer - Feint (DC Synthesis, ICC P&R)
3.ASIC/ Layout Design Engineer - DV
Job Responsibilities: *Subsystem/IP level test plan development *Work with architecture/IP designers to get a full deep insight on the designunder test *Subsystem level test bench build, verification component build Education& Qualifications: Candidate is preferred to be MSEE withminimum of 2 years, or BSEE with minimum of 4-year experience in digitalASIC/SOC design verification.
Experience: 1.
Complex IP/ASIC/SOC Design Verification, direct experience in IP/SOC or Processor (cpu or GPU) or Industry bus standard (PCI-e, HT) is preferred. 2.
Good knowledge of UVM 3.
Good knowledge of verilog/C/C++/System C/SystemVerilog. 4.
Verification insights into random techniques. 5.
Experience of verification lead is an asset. 6.
Experience of PCIe verification is an asset. 7.
Experience in power verification is an asset. 8.
Verification of Virtualization is an asset. 9.
Strong C and C++ software development and scripting languages (Perl, C Shell, Makefile, …) experience. 10.
Solid background with hardware verification methodologies such as coverage-based verification methodology with the use of hardware assertions (PSL or SVA). |
4. ASIC/Layout Design Engineer - DFT
- Should be able to Lead a team, and provide Technical mentoring and guidance to junior engineers.
5.Machine/ Deep Learning Software engineerJob description We are now looking for a Machine/Deep Learning Software Development Engineer: What You’ll Be Doing But Not Limited - Responsible for AMD Machine/Deep Learning Software Development (Driver, SDK, Frameworks);
- Develop testing for Machine/Deep Learning products to ensure functionality, compatibility and performance;
- Performance/Power Analysis, Optimization, Tuning of Deep Learning Kernels
- Triage, isolate failures of root cause analysis and work with global development team to verify fixes;
What We Need To See - BS or higher degree in CS/EE/CE or equivalent;
- Strong programming skills in C or C++
- Excellent communicator, both written and verbal;
- Scripting language (Python, Perl ) knowledge and UNIX/Linux experience is required;
Ways To Stand Out From The Crowd - Driver development experiment is a good Plus
- OpenCL/CUDA/C++ Amp/ROCm/Compiler development experience is a strong Plus
- Familiarity working with GPU hardware is a strong plus;
* Familiarity any Deep Learning framework is a strong plus; |
