在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 5783|回复: 8
[求助] calibre 进行LVS的时候版图器件不能识别
发表于 2018-3-21 20:33:44 | 显示全部楼层 |阅读模式
简单的逻辑电路进行LVS,看结果,原理图中的器件都正确识别了,而版图中的器件没有被识别。PIPO.LOG
INFO (XSTRM-162): You have not used the viaMap option. If the OpenAccess design has native oaVia instances, use the -viaMap option for preserving oaVia instances in a Stream Out - Stream In round trip. Using the -viaMap option improves performance and VM usage of applications using the Streamed-In design.  For details on the viaMap option, refer to the "Design Data Translator's Reference" guide for XStream.
WARNING (XSTRM-35): The objects in the layer-purpose pair 'text:drawing' are ignored. This is because the layer-purpose pair used in the design is not specified in the layer map file. Specify the layer-purpose pair in the layer map file and try again.
INFO (XSTRM-180): You have not used the objectMap option. The design has instance(s) of at least one of following OpenAccess objects: oaBlockage, oaBoundary, oaRow, and oaMarker. Any information about these objects will not be translated into the generated stream file. Use the objectMap option to translate/preserve these objects using XStream. For details on the objectMap option, refer to the "Design Data Translator's Reference" guide for XStream.
xx.sp
.SUBCKT inv gnd!
** N=1 EP=1 IP=0 FDC=0
*.CALIBRE WARNING SHORT Short circuit(s) detected by extraction in this cell. See extraction report for details.
.ENDS
请大神指点,如果需要其他文件,也可以贴。
发表于 2018-3-22 09:01:21 | 显示全部楼层
回复 1# 2hen
   感觉你应该和我遇到同一类型问题了,能发一下你的calibre设置吗?input、lvs option这些的
 楼主| 发表于 2018-3-22 14:15:31 | 显示全部楼层
回复 2# pancrasMa
发表于 2018-3-22 15:49:15 | 显示全部楼层
回复 3# 2hen
   你用的是tsmc的什么工艺?听说小于20nm的工艺都是finFET,layout和以前的planar的画法有点不太一样。
发表于 2018-3-23 20:57:00 | 显示全部楼层
第一个图,转出gds不用加map.file
 楼主| 发表于 2018-3-24 09:47:02 | 显示全部楼层
回复 5# powerboy711
   怎么看加没加map library
发表于 2018-4-11 22:26:06 | 显示全部楼层
问问领导是不是还有别的文件需要加载在一起,有的 rule不全,器件在rule里面没有定义。
 楼主| 发表于 2018-4-19 20:26:50 | 显示全部楼层
回复 7# 天上掉个饼
谢谢。确实是还有文件没加载。
发表于 2022-1-27 20:02:43 | 显示全部楼层
thanks
GMT+8, 2024-3-29 04:00 , Processed in 0.030613 second(s), 12 queries , Gzip On, Redis On.
