Who Is This Book For?The examples and supporting code for this book are in Python. You should know core Python and you should be familiar with object-oriented features, at least using objects if not defining your own. If you are not already familiar with Python, you might want to start with my other book, Think Python, which is an introduction to Python for people who have never programmed, or Mark Lutz’s Learning Python, which might be better for people with programming experience. I use NumPy and SciPy extensively. If you are familiar with them already, that’s great, but I will also explain the functions and data structures I use. I assume that the reader knows basic mathematics, including complex numbers. You don’t need much calculus; if you understand the concepts of integration and differentiation, that will do. I use some linear algebra, but I will explain it as we go along.
压缩包包含epub和mobi格式
Think DSP Digital Signal Processing in Python.zip
(13.4 MB, 下载次数: 528 )
