在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3462|回复: 9
[求助] verilog RTL coding, of synthesisible code
发表于 2018-2-20 02:15:51 | 显示全部楼层 |阅读模式
do we have a way to declare mutex, mutually exclusive, in verilog RTL, of synthesizable codeor in Design compiler runs to set constraints?
Many thanks
---------------my RTL code---------
   always @(posedge phck[0] or negedge reset_)
     begin
        if(!reset_)
          begin
             reg_phck[0] <= 0 ;
             reg_phck[1] <= 0 ;
             reg_phck[2] <= 0 ;
             reg_phck[3] <= 0 ;
          end
        else
          begin
               reg_phck[0] <= reg4dq_in[0] ;
               reg_phck[1] <= reg4dq_in[16] ;
               reg_phck[2] <= reg4dq_in[32] ;
               reg_phck[3] <= reg4dq_in[48] ;
          end
  end
   always @(posedge phck_[0] or negedge reset_)
     begin
        if(!reset_)
          begin
             reg_phck[0] <= 0 ;
             reg_phck[1] <= 0 ;
             reg_phck[2] <= 0 ;
             reg_phck[3] <= 0 ;
          end
        else
          begin
               reg_phck[0] <= reg4dq_in[1] ;
               reg_phck[1] <= reg4dq_in[17] ;
               reg_phck[2] <= reg4dq_in[33] ;
               reg_phck[3] <= reg4dq_in[49] ;
          end
  end
-----------------end of RTL code inclusion-----------
When I tried to read in  the code:
read_verilog ../ref/fifo_rtl/readfifo64to4.v
I got the
Error:  /home/dubeeloo/proj/dDesign/DFTcompiler/ref/fifo_rtl/readfifo64to4.v:53: Net 'reg_phck[3]' or a directly
connected net is driven by more than one source, and not all drivers are three-state. (ELAB-366)
but I know phck[0] and phck_[0] are mutually exclusive, they would not have rising edge at the same time
发表于 2018-2-24 15:55:51 | 显示全部楼层
multi drive,同一个信号不能在多个always里赋值
发表于 2018-2-26 09:36:21 | 显示全部楼层
看这意思是要双沿采样?
 楼主| 发表于 2018-2-27 02:43:41 | 显示全部楼层
回复 3# zsftm
   yes, 是要双沿采样
没有办法 mutex吗?
发表于 2018-2-27 08:59:50 | 显示全部楼层
仿真用的代码这么写是没事的,自己保证不可能同时赋值就可以了。综合用的代码这么写就是多驱了。有phck[0]的2倍频时钟么
 楼主| 发表于 2018-2-27 15:50:03 | 显示全部楼层
回复 5# zsftm
   Thank you for replying
没有2倍频, 我可以试一下用 standard cell build
DC 没有mutex吗?像C++ ?
发表于 2018-2-27 16:52:32 | 显示全部楼层
没有的。而且dc不做仿真,不会知道设计者的一块电路实现了什么。dc只做结构上的检查。
发表于 2018-3-1 16:09:16 | 显示全部楼层
看看!!!!!!!!!!!!!!
发表于 2018-5-17 15:48:17 | 显示全部楼层
看这意思是要双沿采样?
发表于 2018-7-15 17:30:06 | 显示全部楼层
这是不允许的,应采用双沿写法
GMT+8, 2024-3-29 03:50 , Processed in 0.029560 second(s), 6 queries , Gzip On, Redis On.
