在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2108|回复: 0
[讨论] 关于HDL模块划分
发表于 2018-2-19 21:53:35 | 显示全部楼层 |阅读模式
在 Design Compiler 1 Workshop Student Guide 的脚注中有这样一段话,解释什么是 poorly partitioned sub-design:
A sub-design is considered “poorly partitioned” if all of its data inputs are not directly connected to
register outputs, or if all of its data outputs are not registered. In other words, a well partitioned sub­
design does not have hierarchy boundaries that “slice” through non-clock combinatorial logic or
register inputs.
按照这个解释,对于一个复杂的设计,在寄存器输出处划分模块(原文为sub-design)是一个好的设计,也就是说模块输出需要打一拍。这样理解是否正确?如果正确,是否有例外情况?能否举例说明?
GMT+8, 2024-3-29 17:08 , Processed in 0.014789 second(s), 6 queries , Gzip On, Redis On.
