查看: 2500|回复: 0
[资料] 华大M0+低功耗MCU RTC模块程序示例
发表于 2018-2-9 16:49:19 | 显示全部楼层 |阅读模式
样例使用说明
版本历史
日期       版本    负责人
IAR
MDK ***********/
017-07-14
0.1
CJ
7.70
5.14 **********/
QQ:3386208645
功能描述
本样例主要涉及时钟模块计数寄存器的写入和读取**********/
/*说明:
/*计数初值写入计数寄存器
/*启动计数
/*读取计数寄存器数值
/******* 测试环境
测试用板:
SK-L110-TSSOP20 V10
/*******辅助工具:
JLINK
调试工具
#define IS_VALID_CLK(x)
(RtcClk32768 == (x)||\
RtcClk32768_1== (x)||\
RtcClk32== (x)||\
RtcClk32_1== (x)||\
RtcClkHxt128 ==(x)||\
RtcClkHxt256 == (x)||\
RtcClkHxt512 == (x)||\
RtcClkHxt1024 == (x))
#define IS_VALID_CYCSEL(x)
(RtcPrads == (x)||\
RtcPradx==(x))
#define IS_VALID_PRDS(x)
(Rtc_None == (x)||\
Rtc_05S == (x)||\
Rtc_1S == (x)||\
Rtc_1Min == (x)||\
Rtc_1H == (x)||\
Rtc_1Day ==(x)||\
Rtc_1Mon ==(x)||\
Rtc_1Mon_1 ==(x))
#define
IS_VALID_IRQ_SEL(x)
(RtcPrdf== (x) ||\
RtcAlmf== (x))
#define
IS_VALID_FUNC(x)
((RtcCount<=(x))&&\
(Rtc1HzOutEn>=(x)))
#define
CkDateTime
0x7F
#define
CkDate
0x78
#define
CkTime
0x07
#define RTC_TIMEOUT
1000//test 1s
#define
T1_PORT
(3)
#define
T1_PIN
(3)
uint8_t cyccnt=0;
uint8_t u8Alarmcnt=0;
uint8_t flg=0;
stc_rtc_time_t
stcReadTime;
/********************************************************************************** \brief
RTC
计数时钟选择
** ** \param [in] enClk时钟源
** ** \retval Ok
en_result_t Rtc_SelClk(en_rtc_clk_t enClk)
en_result_t enRet = Error;
ASSERT(IS_VALID_CLK(enClk));
M0P_RTC->CR1_f.CKSEL = enClk;
enRet = Ok;
return enRet;
**\brief
RTC
周期中断方式选择
**\param [in] pstccCyc
周期中断方式及周期间隔选择
**\retval Ok
en_result_t Rtc_SetCyc(stc_rtc_cyc_sel_t*pstcCyc)
ASSERT(IS_VALID_CYCSEL(pstcCyc->enCyc_sel));
ASSERT(IS_VALID_PRDS(pstcCyc->enPrds_sel));
M0P_RTC->CR0_f.PRDSEL= pstcCyc->enCyc_sel;
if(pstcCyc->enCyc_sel)
M0P_RTC->CR0_f.PRDX = pstcCyc->u8Prdx;
else
M0P_RTC->CR0_f.PRDS= pstcCyc->enPrds_sel;
enRet = Ok;
returnenRet;
**\brief
RTC
时制选择
**\param [in] bmode
12时制or24时制
**\retval Ok
设置正常
**\retval ErrorInvalidParameter
设置异常
en_result_t Rtc_SetAmPm(en_rtc_ampm_tenMode)
switch(enMode)
case 0:
case 1:
M0P_RTC->CR0_f.AMPM = enMode;
break;
default:
return ErrorInvalidParameter;
enRet = Ok;
return enRet;
**\brief
RTC
闹钟中断设置
**\param [in] pstcAlarmTime
闹钟时间时、分、周
**\retval Ok
设置正常
en_result_tRtc_SetAlarmTime(stc_rtc_alarmset_t* pstcAlarmTime)
en_result_t enRet = Ok;
ASSERT(NULL != pstcAlarmTime);
if(Rtc12h == M0P_RTC->CR0_f.AMPM)
enRet = Check_BCD_Format(pstcAlarmTime->u8Hour,0x00,0x12);
else
enRet = Check_BCD_Format(pstcAlarmTime->u8Hour,0x00,0x24);
if(enRet != Ok)
return enRet;
enRet = Check_BCD_Format(pstcAlarmTime->u8Minute,0x00,0x59);
if(enRet != Ok)
return enRet;
//enRet = Check_BCD_Format(pstcAlarmTime->u8Week,0x00,0x06);
if(enRet != Ok)
return enRet;
M0P_RTC->ALMHOUR = pstcAlarmTime->u8Hour;
M0P_RTC->ALMMIN = pstcAlarmTime->u8Minute;
M0P_RTC->ALMWEEK = pstcAlarmTime->u8Week;
enRet = Ok;
return enRet;
**\brief
RTC
闹钟中断时间获取
闹钟时间时、分、周
**\retval Ok
设置正常
en_result_tRtc_GetAlarmTime(stc_rtc_alarmset_t* pstcAlarmTime)
pstcAlarmTime->u8Minute = M0P_RTC->ALMMIN;
pstcAlarmTime->u8Hour = M0P_RTC->ALMHOUR;
pstcAlarmTime->u8Week = M0P_RTC->ALMWEEK;
enRet = Ok;
return enRet;
**\brief
RTC 1hz
模式选择
**\param [in] bmode
高精度和普通精度
**\retval Ok
设置正常
en_result_t Rtc_Set1HzMode(boolean_t bMode)
M0P_RTC->CR0_f.HZ1SEL = bMode;
enRet = Ok;
return enRet;
**\brief
RTC 1hz
补偿值设置
**\param [in] u16Cr
补偿值
**\retval Ok
设置正常
en_result_t Rtc_SetCompCr(uint16_t u16Cr)
M0P_RTC->COMPEN_f.CR = u16Cr;
enRet = Ok;
return enRet;
**\brief
RTC
功能使能设置
**\param [in] enFunc
功能选择
**\retval Ok
设置正常
设置异常
en_result_t Rtc_EnableFunc(en_rtc_func_tenFunc)
ASSERT(IS_VALID_FUNC(enFunc));
switch(enFunc)
case RtcCount:
M0P_RTC->CR0_f.START = 1u;
break;
case RtcAlarmEn:
M0P_RTC->CR1_f.ALMEN = 1u;
break;
case Rtc_ComenEn:
M0P_RTC->COMPEN_f.EN = 1u;
break;
case Rtc1HzOutEn:
M0P_RTC->CR0_f.HZ1OE = 1u;
break;
default:
return Ok;
**\brief
RTC
功能禁止设置
功能选择
**\retval Ok
设置正常
设置异常
en_result_t Rtc_DisableFunc(en_rtc_func_tenFunc)
switch(enFunc)
case RtcCount:
M0P_RTC->CR0_f.START = 0u;
break;
case RtcAlarmEn:
M0P_RTC->CR1_f.ALMEN = 0u;
break;
case Rtc_ComenEn:
M0P_RTC->COMPEN_f.EN = 0u;
break;
case Rtc1HzOutEn:
M0P_RTC->CR0_f.HZ1OE = 0u;
break;
default:
return Ok;
uint8_t Change_DateTimeFormat(uint8_t u8sr)
uint8_tu8de=0;
while(u8sr>=0x10)
u8de+=10;
u8sr-=0x10;
u8de+= u8sr;
return(u8de);
**\brief
RTC
平、闰年检测
**\param [in] u8year
年十进制低两位
**\retval 1
闰年
**\retval 0
平年
uint8_t Rtc_CheckLeapYear(uint8_t u8year)
uint8_t u8year_shl,u8year_shr;
u8year_shl = u8year>>2;
u8year_shr = u8year_shl<<2;
if(u8year== u8year_shr)
return 1;
else
return 0;
**\brief
RTC
根据日期计算周数
**\param [in] pu8Date
日期
**\retval week
周数
uint8_t Rtc_CalWeek(uint8_t* pu8Date)
uint8_t u8week;
if((Rtc_CheckLeapYear(Change_DateTimeFormat(*(pu8Date+2)))==1))
u8week=(Change_DateTimeFormat(*(pu8Date+2))+Change_DateTimeFormat(*(pu8Date+2))/4+Leap_Month_Base[Change_DateTimeFormat(*(pu8Date+1))-1]+Change_DateTimeFormat(*(pu8Date))+2)%7;
else
u8week= (Change_DateTimeFormat(*(pu8Date+2))+Change_DateTimeFormat(*(pu8Date+2))/4+NonLeap_Month_Base[Change_DateTimeFormat(*(pu8Date+1))-1]+Change_DateTimeFormat(*(pu8Date))+2)%7;
return u8week;
**\brief
RTC
根据年月获取天数
**\param [in] u8month
月份,u8year年份
**\retval u8day
天数
uint8_t Get_Month_Max_Day(uint8_t u8month,uint8_t u8year)
uint8_tu8day = 0;
u8day= Cnst_Month_Tbl[u8month - 1];
if((u8month== 2) && ((u8year % 4) == 0))
u8day++;
return(u8day);//day
的格式是bcd码,例如;日为31天,day=0x31
**\brief
RTC
根据日期计算周数
**\param [in] pu8buf
日期时间数据,u8len检查数据长度,u8limit_min最小值,u8limit_max最大值
**\retval Error
错误,Ok校验正确
en_result_t Check_BCD_Format(uint8_tu8data,uint8_t u8limit_min, uint8_t u8limit_max)
if (((u8data & 0x0F) > 0x09) || ((u8data & 0xF0) > 0x90)
||(u8data > u8limit_max) || (u8data < u8limit_min))
return Error;
return Ok;
**\brief
RTC
时间格式检测
**\param [in] pu8TimeDate
日期时间数据,u8Mode检测模式
**\retval enRet
校验结果
en_result_tRtc_CheckDateTimeFormat(uint8_t* pu8TimeDate,uint8_t u8Mode)
uint8_t u8i=0;
uint8_t u8mon_max_day = 0x28;
uint8_t u8date[3];
en_result_t enRet;
while(u8i<7)
if(u8Mode&&(1<<u8i))
switch(u8i)
case 0:
enRet = Check_BCD_Format(*pu8TimeDate,0x00,0x59);//
break;
case 1:
enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x59);//
break;
case 2:
enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x12);//
else
enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x24);
break;
case 3:
enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x06);
break;
case 4:
enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x31);
u8date[0] = *pu8TimeDate;
break;
case 5:
u8date[1] = *pu8TimeDate;
break;
case 6:
enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x99);
u8date[2] = *pu8TimeDate;
break;
pu8TimeDate++;
if(enRet!=Ok)
return enRet;
u8i++;
if((u8Mode&0x10)&&(u8Mode&0x20))
if(u8Mode&0x40)
u8mon_max_day= Get_Month_Max_Day(Change_DateTimeFormat(u8date[1]),Change_DateTimeFormat(u8date[2]));
else
u8mon_max_day= Get_Month_Max_Day(Change_DateTimeFormat(u8date[1]), 1);
if(u8date[0]>u8mon_max_day)
returnError;
if((u8Mode&0x10)&&(!(u8Mode&0x20)))
if(u8date[0]>0x28)
returnError;
enRet = Ok;
return(enRet);
**\brief
RTC
设置时间函数
**\param [in] pstcTimeDate
日期时间数据、bUpdateTime是否更改时间、bUpdateDate是否更改日期
**\retval Ok
设置正常
**\retval ErrorTimeout
时间溢出错误
en_result_tRtc_WriteDateTime(stc_rtc_time_t* pstcTimeDate,boolean_t bUpdateTime,
boolean_t bUpdateDate)
int32_t u32TimeOut;
u32TimeOut = RTC_TIMEOUT;
uint8_t* pu8TimeDate;
pu8TimeDate = &pstcTimeDate->u8Second;
ASSERT(NULL != pstcTimeDate);
if(1 == M0P_RTC->CR0_f.START)
M0P_RTC->CR1_f.WAIT = 1;
while(--u32TimeOut)
if(M0P_RTC->CR1_f.WAITF)
break;
if(u32TimeOut==0)
return ErrorTimeout;
if(TRUE == bUpdateTime)
enRet = Rtc_CheckDateTimeFormat(pu8TimeDate,CkTime);
if(enRet != Ok)
return enRet;
M0P_RTC->SEC = pstcTimeDate->u8Second;
M0P_RTC->MIN = pstcTimeDate->u8Minute;
M0P_RTC->HOUR = pstcTimeDate->u8Hour;
if(TRUE == bUpdateDate)
enRet = Rtc_CheckDateTimeFormat(pu8TimeDate,CkDate);
if(enRet != Ok)
return enRet;
M0P_RTC->DAY = pstcTimeDate->u8Day;
M0P_RTC->MON = pstcTimeDate->u8Month;
M0P_RTC->YEAR = pstcTimeDate->u8Year;
M0P_RTC->WEEK = pstcTimeDate->u8DayOfWeek;
M0P_RTC->CR1_f.WAIT = 0;
while(M0P_RTC->CR1_f.WAITF);
return enRet;
**\brief
RTC
获取时间函数
日期时间数据
**\retval Ok
获取正常
时间溢出错误
en_result_tRtc_ReadDateTime(stc_rtc_time_t* pstcTimeDate)
uint32_t u32TimeOut;
uint8_t
u8DayOfWeek, u8BcdSec,u8BcdMin, u8BcdHour, u8Day, u8Month, u8Year;
while(u32TimeOut--)
break;
if(u32TimeOut==0)
u8BcdSec
= M0P_RTC->SEC;
u8BcdMin
= M0P_RTC->MIN;
u8BcdHour = M0P_RTC->HOUR;
u8Day
= M0P_RTC->DAY;
u8Month
= M0P_RTC->MON;
u8Year
= M0P_RTC->YEAR;
u8DayOfWeek = M0P_RTC->WEEK;
pstcTimeDate->u8Second = u8BcdSec;//BcdToDec(u8BcdSec);
pstcTimeDate->u8Minute = u8BcdMin;//BcdToDec(u8BcdMin);
=u8BcdHour;//BcdToDec(u8BcdHour);
pstcTimeDate->u8Day
=u8Day;//BcdToDec(u8Day);
=u8Month;//BcdToDec(u8Month);
=u8Year;//BcdToDec(u8Year);
pstcTimeDate->u8DayOfWeek = u8DayOfWeek;//BcdToDec(u8DayOfWeek);
return Ok;
**\brief
RTC
计数or读写状态获取
**\param [in]
**\retval
计数or读写状态
boolean_t Rtc_RDStatus(void)
boolean_t bRet;
bRet = M0P_RTC->CR1_f.WAITF;
return bRet;
**\brief
RTC
闹钟中断使能
**\param [in] enordis
中断使能or禁止
**\retval Ok
设置成功
en_result_tRtc_EnAlarmIrq(en_rtc_alarmirq_t enIrqEn)
M0P_RTC->CR1_f.ALMIE = enIrqEn;
Rtc_ClrIrqStatus(RtcAlmf);//
使能中断后清除中断请求标记
enRet = Ok;
return enRet;
**\brief
RTC
中断请求状态获取
**\param [in] enIrqSel
获取哪种中断请求
**\retval
中断请求状态
boolean_t Rtc_GetIrqStatus(en_rtc_status_irq_tenIrqSel)
boolean_t bRet = FALSE;
ASSERT(IS_VALID_IRQ_SEL(enIrqSel));
switch(enIrqSel)
case RtcPrdf:
(M0P_RTC->CR1_f.PRDF == 1)?(bRet = TRUE) : (bRet = FALSE);
break;
case RtcAlmf :
(M0P_RTC->CR1_f.ALMF == 1)?(bRet = TRUE) : (bRet = FALSE);
break;
default:
break;
return bRet;
**\brief
RTC
中断请求清除
清除哪种中断请求
**\retval Ok
清除成功
清除失败
en_result_tRtc_ClrIrqStatus(en_rtc_status_irq_t enIrqSel)
switch(enIrqSel)
case RtcPrdf:
M0P_RTC->CR1_f.PRDF = 0;
break;
case
RtcAlmf:
M0P_RTC->CR1_f.ALMF = 0;
break;
default:
return Ok;
**\brief
RTC
中断处理函数接口获取
**\param [in]
**\retval
接口函数地址
static stc_rtc_intern_cb_t*RtcGetInternDataCb(void)
return &stcRtcIrqCb;
**\brief
RTC
总体初始化函数
**\param [in] pstcRtcConfig
初始化结构
**\retval Ok
初始化成功
初始化错误
en_result_t Rtc_Init(stc_rtc_config_t*pstcRtcConfig)
stc_rtc_intern_cb_t* pstcRtcInternCb;
if(NULL == pstcRtcConfig)
return Error;
pstcRtcInternCb =
RtcGetInternDataCb();
enRet = Rtc_SelClk(pstcRtcConfig->enClkSel);
enRet = Rtc_SetAmPm(pstcRtcConfig->enAmpmSel);
if(enRet != Ok)
return enRet;
if(NULL != pstcRtcConfig->pstcCycSel)
if(Ok != Rtc_SetCyc(pstcRtcConfig->pstcCycSel))
return Error;
if(NULL != pstcRtcConfig->pstcTimeDate)
if(Ok != Rtc_WriteDateTime(pstcRtcConfig->pstcTimeDate,TRUE,TRUE))
return Error;
if(NULL != pstcRtcConfig->pstcIrqCb)
pstcRtcInternCb->pfnAlarmIrqCb =pstcRtcConfig->pstcIrqCb->pfnAlarmIrqCb;
pstcRtcInternCb->pfnTimerIrqCb =pstcRtcConfig->pstcIrqCb->pfnTimerIrqCb;
if(TRUE == pstcRtcConfig->bTouchNvic)
EnableNvic(RTC_IRQn,DDL_IRQ_LEVEL_DEFAULT,TRUE);
else
EnableNvic(RTC_IRQn,DDL_IRQ_LEVEL_DEFAULT,FALSE);
return enRet;
**\brief
RTC
计数禁止函数
**\param [in]
**\retval Ok
禁止设置成功
en_result_t Rtc_DeInit(void)
Rtc_DisableFunc(RtcCount);
Rtc_DisableFunc(RtcAlarmEn);
Rtc_DisableFunc(Rtc_ComenEn);
Rtc_DisableFunc(Rtc1HzOutEn);
return Ok;
**\brief
RTC
中断处理函数
**\param [in]
**\retval
void Rtc_IRQHandler(void)
pstcRtcInternCb = RtcGetInternDataCb() ;
if(TRUE == M0P_RTC->CR1_f.ALMF)
M0P_RTC->CR1_f.ALMF = 0u;
if(NULL != pstcRtcInternCb->pfnAlarmIrqCb)
pstcRtcInternCb->pfnAlarmIrqCb();
if(TRUE == M0P_RTC->CR1_f.PRDF)
if(NULL != pstcRtcInternCb->pfnTimerIrqCb)
pstcRtcInternCb->pfnTimerIrqCb();
static void RtcCycCb(void)
cyccnt++;
flg = ~flg;
Gpio_SetIO(3,3,flg);
static void RtcAlarmCb(void)
u8Alarmcnt++;
int32_t main(void)
stc_rtc_config_t stcRtcConfig;
stc_rtc_irq_cb_t stcIrqCb;
stc_rtc_time_t
stcTime;
stc_rtc_alarmset_t stcAlarm;
stc_rtc_cyc_sel_t
stcCycSel;
DDL_ZERO_STRUCT(stcRtcConfig);
DDL_ZERO_STRUCT(stcIrqCb);
DDL_ZERO_STRUCT(stcAlarm);
DDL_ZERO_STRUCT(stcTime);
DDL_ZERO_STRUCT(stcCycSel);
Clk_SetPeripheralGate(ClkPeripheralGpio,TRUE);//
使能GPIO时钟
Gpio_SetAnalog(1,4,1);//
配置成模拟端口即为晶振口
Gpio_SetAnalog(1,5,1);
Clk_Enable(ClkXTL, TRUE);//
开启外部晶振32.768
//Clk_Enable(ClkRCL, TRUE);
//Clk_Enable(ClkXTH, TRUE);
Clk_SetPeripheralGate(ClkPeripheralRtc,TRUE);//
使能rtc时钟
stcRtcConfig.enClkSel = RtcClk32768;//RtcClkHxt1024;//RtcClk32;//
stcRtcConfig.enAmpmSel = Rtc24h;//Rtc12h;//
stcTime.u8Year = 0x17;
stcTime.u8Month = 0x06;
stcTime.u8Day = 0x07;
stcTime.u8Hour = 0x12;
stcTime.u8Minute = 0x59;
stcTime.u8Second = 0x59;
stcTime.u8DayOfWeek = Rtc_CalWeek(&stcTime.u8Day);
stcRtcConfig.pstcTimeDate = &stcTime;
stcIrqCb.pfnAlarmIrqCb = RtcAlarmCb;
stcIrqCb.pfnTimerIrqCb = RtcCycCb;
stcRtcConfig.pstcIrqCb = &stcIrqCb;
stcRtcConfig.bTouchNvic = FALSE;
Rtc_Init(&stcRtcConfig);
Rtc_EnableFunc(RtcCount);
Rtc_ReadDateTime(&stcReadTime);
while (1);
*EOF (not truncated)
样例使用说明
版本历史
日期       版本    负责人
IAR
MDK ***********/
017-07-14
0.1
CJ
7.70
5.14 **********/
QQ:3386208645
功能描述
/*说明:
/*计数初值写入计数寄存器
/*启动计数
/*读取计数寄存器数值
/******* 测试环境
测试用板:
SK-L110-TSSOP20 V10
/*******辅助工具:
JLINK
调试工具
RtcClk32== (x)||\
RtcClk32_1== (x)||\
(RtcPrads == (x)||\
RtcPradx==(x))
(Rtc_None == (x)||\
Rtc_05S == (x)||\
Rtc_1S == (x)||\
Rtc_1Min == (x)||\
Rtc_1H == (x)||\
Rtc_1Day ==(x)||\
Rtc_1Mon ==(x)||\
Rtc_1Mon_1 ==(x))
#define
IS_VALID_IRQ_SEL(x)
(RtcPrdf== (x) ||\
RtcAlmf== (x))
#define
IS_VALID_FUNC(x)
((RtcCount<=(x))&&\
(Rtc1HzOutEn>=(x)))
#define
CkDateTime
0x7F
#define
CkDate
0x78
#define
CkTime
0x07
#define RTC_TIMEOUT
1000//test 1s
#define
T1_PORT
(3)
#define
T1_PIN
(3)
uint8_t cyccnt=0;
uint8_t flg=0;
stc_rtc_time_t
stcReadTime;
RTC
计数时钟选择
** ** \retval Ok
enRet = Ok;
return enRet;
**\brief
RTC
周期中断方式选择
周期中断方式及周期间隔选择
**\retval Ok
else
enRet = Ok;
returnenRet;
**\brief
RTC
时制选择
**\param [in] bmode
12时制or24时制
**\retval Ok
设置正常
设置异常
switch(enMode)
case 0:
case 1:
break;
default:
enRet = Ok;
return enRet;
**\brief
RTC
闹钟中断设置
闹钟时间时、分、周
**\retval Ok
设置正常
else
if(enRet != Ok)
return enRet;
if(enRet != Ok)
return enRet;
if(enRet != Ok)
return enRet;
enRet = Ok;
return enRet;
**\brief
RTC
闹钟中断时间获取
闹钟时间时、分、周
**\retval Ok
设置正常
enRet = Ok;
return enRet;
**\brief
RTC 1hz
模式选择
**\param [in] bmode
高精度和普通精度
**\retval Ok
设置正常
enRet = Ok;
return enRet;
**\brief
RTC 1hz
补偿值设置
**\param [in] u16Cr
补偿值
**\retval Ok
设置正常
enRet = Ok;
return enRet;
**\brief
RTC
功能使能设置
功能选择
**\retval Ok
设置正常
设置异常
switch(enFunc)
case RtcCount:
break;
case RtcAlarmEn:
break;
case Rtc_ComenEn:
break;
case Rtc1HzOutEn:
break;
default:
return Ok;
**\brief
RTC
功能禁止设置
功能选择
**\retval Ok
设置正常
设置异常
switch(enFunc)
case RtcCount:
break;
case RtcAlarmEn:
break;
case Rtc_ComenEn:
break;
case Rtc1HzOutEn:
break;
default:
return Ok;
uint8_tu8de=0;
while(u8sr>=0x10)
u8de+=10;
u8sr-=0x10;
u8de+= u8sr;
return(u8de);
**\brief
RTC
平、闰年检测
年十进制低两位
**\retval 1
闰年
**\retval 0
平年
return 1;
else
return 0;
**\brief
RTC
根据日期计算周数
日期
**\retval week
周数
uint8_t u8week;
else
return u8week;
**\brief
RTC
根据年月获取天数
月份,u8year年份
**\retval u8day
天数
uint8_tu8day = 0;
u8day++;
return(u8day);//day
**\brief
RTC
根据日期计算周数
**\retval Error
错误,Ok校验正确
return Error;
return Ok;
**\brief
RTC
时间格式检测
日期时间数据,u8Mode检测模式
**\retval enRet
校验结果
uint8_t u8i=0;
uint8_t u8date[3];
en_result_t enRet;
while(u8i<7)
switch(u8i)
case 0:
break;
case 1:
break;
case 2:
else
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
pu8TimeDate++;
if(enRet!=Ok)
return enRet;
u8i++;
if(u8Mode&0x40)
else
returnError;
if(u8date[0]>0x28)
returnError;
enRet = Ok;
return(enRet);
**\brief
RTC
设置时间函数
**\retval Ok
设置正常
时间溢出错误
int32_t u32TimeOut;
while(--u32TimeOut)
break;
if(u32TimeOut==0)
if(enRet != Ok)
return enRet;
if(enRet != Ok)
return enRet;
return enRet;
**\brief
RTC
获取时间函数
日期时间数据
**\retval Ok
获取正常
时间溢出错误
uint8_t
while(u32TimeOut--)
break;
if(u32TimeOut==0)
u8BcdSec
= M0P_RTC->SEC;
u8BcdMin
= M0P_RTC->MIN;
u8Day
= M0P_RTC->DAY;
u8Month
= M0P_RTC->MON;
u8Year
= M0P_RTC->YEAR;
pstcTimeDate->u8Day
return Ok;
**\brief
RTC
计数or读写状态获取
**\param [in]
**\retval
计数or读写状态
boolean_t bRet;
return bRet;
**\brief
RTC
闹钟中断使能
中断使能or禁止
**\retval Ok
设置成功
使能中断后清除中断请求标记
enRet = Ok;
return enRet;
**\brief
RTC
中断请求状态获取
获取哪种中断请求
**\retval
中断请求状态
switch(enIrqSel)
case RtcPrdf:
break;
case RtcAlmf :
break;
default:
break;
return bRet;
**\brief
RTC
中断请求清除
清除哪种中断请求
**\retval Ok
清除成功
清除失败
switch(enIrqSel)
case RtcPrdf:
break;
case
RtcAlmf:
break;
default:
return Ok;
**\brief
RTC
中断处理函数接口获取
**\param [in]
**\retval
接口函数地址
**\brief
RTC
总体初始化函数
初始化结构
**\retval Ok
初始化成功
初始化错误
return Error;
pstcRtcInternCb =
if(enRet != Ok)
return enRet;
return Error;
return Error;
else
return enRet;
**\brief
RTC
计数禁止函数
**\param [in]
**\retval Ok
禁止设置成功
return Ok;
**\brief
RTC
中断处理函数
**\param [in]
**\retval
cyccnt++;
flg = ~flg;
u8Alarmcnt++;
int32_t main(void)
stc_rtc_time_t
stcTime;
stc_rtc_cyc_sel_t
stcCycSel;
使能GPIO时钟
配置成模拟端口即为晶振口
开启外部晶振32.768
使能rtc时钟
while (1);
GMT+8, 2025-12-18 00:39 , Processed in 0.075258 second(s), 4 queries , Gzip On, Redis On.
