## C A L I B R E S Y S T E M ##
## L V S R E P O R T ##
REPORT FILE NAME: ADV7180_top.lvs.report
layout NAME: /home/feili/CDS/calibre/ADV7180_top.sp ('ADV7180_top')
SOURCE NAME: /home/feili/CDS/calibre/all.cdl ('ADV7180_top')
RULE FILE: /home/feili/CDS/calibre/_calibre.lvs_
CREATION TIME: Tue Feb 6 17:29:49 2018
CURRENT DIRECTORY: /home/feili/CDS/calibre
USER NAME: feili
CALIBRE VERSION: v2012.2_36.25 Mon Jul 2 12:15:31 PDT 2012
OVERALL COMPARISON RESULTS
# # INCORRECT #
Error: Different numbers of nets.
Error: Different numbers of instances.
Error: Connectivity errors.
Error: Property errors.
Warning: Ambiguity points were found and resolved arbitrarily.
CELL SUMMARY
Result Layout Source
INCORRECT ADV7180_top ADV7180_top
LVS PARAMETERS
o LVS Setup:
// LVS COMPONENT TYPE PROPERTY
// LVS COMPONENT SUBTYPE PROPERTY
// LVS PIN NAME PROPERTY
LVS POWER NAME "AVD33" "AVD33B" "AVD33G" "AVD33R" "AVD33WELL" "AVDD" "AVDDB" "AVDDBG" "AVDDG" "AVDDR"
"AVDWELL" "DVDD" "TAVD33" "TAVD33PST" "TAVDD" "TAVDDPST" "VD33" "VD33WELL" "VDD" "VDD5V"
"VDDG" "VDDPST" "VDDSA" "VDWELL"
LVS GROUND NAME "AGND" "AVS33" "AVS33B" "AVS33G" "AVS33R" "AVS33SUB" "AVSS" "AVSSB" "AVSSBG" "AVSSG"
"AVSSR" "AVSSUB" "DVSS" "GND" "TAVSS" "TAVSSPST" "VS33" "VS33SUB" "VSS" "VSSG" "VSSPST"
"VSSUB"
LVS CELL SUPPLY NO
LVS RECOGNIZE GATES ALL
LVS IGNORE PORTS NO
LVS CHECK PORT NAMES YES
LVS IGNORE TRIVIAL NAMED PORTS NO
LVS BUILTIN DEVICE PIN SWAP YES
LVS ALL CAPACITOR PINS SWAPPABLE YES
LVS DISCARD PINS BY DEVICE NO
LVS SOFT SUBSTRATE PINS NO
LVS INJECT LOGIC YES
LVS EXPAND UNBALANCED CELLS YES
LVS FLATTEN INSIDE CELL NO
LVS EXPAND SEED PROMOTIONS NO
LVS PRESERVE PARAMETERIZED CELLS NO
LVS GLOBALS ARE PORTS YES
LVS REVERSE WL NO
LVS SPICE PREFER PINS YES
LVS SPICE SLASH IS SPACE YES
LVS SPICE ALLOW FLOATING PINS YES
// LVS SPICE ALLOW INLINE PARAMETERS
LVS SPICE ALLOW UNQUOTED STRINGS NO
LVS SPICE CONDITIONAL LDD NO
LVS SPICE CULL PRIMITIVE SUBCIRCUITS NO
LVS SPICE IMPLIED MOS AREA NO
// LVS SPICE MULTIPLIER NAME
LVS SPICE OVERRIDE GLOBALS NO
LVS SPICE REDEFINE PARAM NO
LVS SPICE REPLICATE DEVICES NO
LVS SPICE SCALE X PARAMETERS NO
LVS SPICE STRICT WL NO
// LVS SPICE OPTION
LVS STRICT SUBTYPES NO
LVS EXACT SUBTYPES NO
LAYOUT CASE YES
SOURCE CASE YES
LVS COMPARE CASE NAMES TYPES SUBTYPES VALUES
LVS DOWNCASE DEVICE NO
LVS REPORT MAXIMUM 50
LVS PROPERTY RESOLUTION MAXIMUM 32
// LVS SIGNATURE MAXIMUM
// LVS FILTER UNUSED OPTION
// LVS REPORT OPTION
LVS REPORT UNITS YES
// LVS NON USER NAME PORT
// LVS NON USER NAME NET
// LVS NON USER NAME INSTANCE
// Device Type Map
LVS DEVICE TYPE RESISTOR "rnod_m" "rnodrpo_m" "rnodw_m" "rnpo1_dis" "rnpo1rpo_dis" "rnpo1w_dis" "rnwod_m"
"rnwsti_m" "rpod_m" "rpodrpo_m" "rpodw_m" "rppo1_dis" "rppo1rpo_dis"
"rppo1w_dis" "rppolyhri_dis" [ POS=PLUS NEG=MINUS ] SOURCE LAYOUT
// Reduction
LVS REDUCE SERIES MOS NO
LVS REDUCE PARALLEL MOS YES
LVS REDUCE SEMI SERIES MOS NO
LVS REDUCE SPLIT GATES YES
LVS REDUCE PARALLEL BIPOLAR YES
LVS REDUCE SERIES CAPACITORS YES
LVS REDUCE PARALLEL CAPACITORS YES
LVS REDUCE SERIES RESISTORS YES
LVS REDUCE PARALLEL RESISTORS YES
LVS REDUCE PARALLEL DIODES YES
LVS REDUCE rnod_m PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rnod_m SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rnodrpo_m PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rnodrpo_m SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rnodw_m PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rnodw_m SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rnpo1_dis PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rnpo1_dis SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rnpo1rpo_dis PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rnpo1rpo_dis SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rnpo1w_dis PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rnpo1w_dis SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rnwod_m PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rnwod_m SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rnwsti_m PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rnwsti_m SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rpod_m PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rpod_m SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rpodrpo_m PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rpodrpo_m SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rpodw_m PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rpodw_m SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rppo1_dis PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rppo1_dis SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rppo1rpo_dis PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rppo1rpo_dis SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rppo1w_dis PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rppo1w_dis SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCE rppolyhri_dis PARALLEL [ TOLERANCE lr 0 ]
LVS REDUCE rppolyhri_dis SERIES PLUS MINUS [ TOLERANCE wr 0 ]
LVS REDUCTION PRIORITY PARALLEL
LVS SHORT EQUIVALENT NODES NO
// Trace Property
TRACE PROPERTY mn(N) l l 0
TRACE PROPERTY mn(N) w w 0
TRACE PROPERTY mn(N1) l l 0
TRACE PROPERTY mn(N1) w w 0
TRACE PROPERTY mn(N2) l l 0
TRACE PROPERTY mn(N2) w w 0
TRACE PROPERTY mn(NA) l l 0
TRACE PROPERTY mn(NA) w w 0
TRACE PROPERTY mn(NB) l l 0
TRACE PROPERTY mn(NB) w w 0
TRACE PROPERTY mn(ND) l l 0
TRACE PROPERTY mn(ND) w w 0
TRACE PROPERTY mn(NL) l l 0
TRACE PROPERTY mn(NL) w w 0
TRACE PROPERTY mn(NN) l l 0
TRACE PROPERTY mn(NN) w w 0
TRACE PROPERTY mp(P) l l 0
TRACE PROPERTY mp(P) w w 0
TRACE PROPERTY mp(PA) l l 0
TRACE PROPERTY mp(PA) w w 0
TRACE PROPERTY mp(PD) l l 0
TRACE PROPERTY mp(PD) w w 0
TRACE PROPERTY d(D1) a a 0
TRACE PROPERTY d(D2) a a 0
TRACE PROPERTY d(D3) a a 0
TRACE PROPERTY d(DB) a a 0
TRACE PROPERTY d(DN) a a 0
TRACE PROPERTY d(DP) a a 0
TRACE PROPERTY d(DW) a a 0
TRACE PROPERTY d(ndio_3m) a a 0
TRACE PROPERTY d(ndio_m) a a 0
TRACE PROPERTY d(pdio_m) a a 0
TRACE PROPERTY r(LR) r r 0
TRACE PROPERTY r(M1) r r 0
TRACE PROPERTY r(M2) r r 0
TRACE PROPERTY r(M3) r r 0
TRACE PROPERTY r(M4) r r 0
TRACE PROPERTY r(MT) r r 0
TRACE PROPERTY r(ND) r r 0
TRACE PROPERTY r(NI) r r 0
TRACE PROPERTY r(NR) r r 0
TRACE PROPERTY r(NS) r r 0
TRACE PROPERTY r(PD) r r 0
TRACE PROPERTY r(PI) r r 0
TRACE PROPERTY r(PR) r r 0
TRACE PROPERTY r(PS) r r 0
TRACE PROPERTY q(NV) a a 0
TRACE PROPERTY q(NV_mis) a a 0
TRACE PROPERTY q(P1) a a 0
TRACE PROPERTY q(PV) a a 0
TRACE PROPERTY q(PV_mis) a a 0
TRACE PROPERTY r(WO) r r 0
TRACE PROPERTY r(WR) r r 0
TRACE PROPERTY crtmom nv nv 0
TRACE PROPERTY crtmom nh nh 0
TRACE PROPERTY crtmom s s 0
TRACE PROPERTY crtmom w w 0
TRACE PROPERTY crtmom stm stm 0
TRACE PROPERTY crtmom spm spm 0
TRACE PROPERTY mimcap_1p0_sin lt lt 0
TRACE PROPERTY mimcap_1p0_sin wt wt 0
TRACE PROPERTY mimcap_1p0_sin_3t lt lt 0
TRACE PROPERTY mimcap_1p0_sin_3t wt wt 0
TRACE PROPERTY mimcap_1p0_sin_3t lay lay 0
TRACE PROPERTY nmoscap lr lr 0
TRACE PROPERTY nmoscap wr wr 0
TRACE PROPERTY nmoscap mr mr 0
TRACE PROPERTY nmoscap_33 lr lr 0
TRACE PROPERTY nmoscap_33 wr wr 0
TRACE PROPERTY nmoscap_33 mr mr 0
TRACE PROPERTY rnod_m wr wr 0
TRACE PROPERTY rnod_m lr lr 0
TRACE PROPERTY rnodrpo_m wr wr 0
TRACE PROPERTY rnodrpo_m lr lr 0
TRACE PROPERTY rnodw_m wr wr 0
TRACE PROPERTY rnodw_m lr lr 0
TRACE PROPERTY rnpo1_dis wr wr 0
TRACE PROPERTY rnpo1_dis lr lr 0
TRACE PROPERTY rnpo1rpo_dis wr wr 0
TRACE PROPERTY rnpo1rpo_dis lr lr 0
TRACE PROPERTY rnpo1w_dis wr wr 0
TRACE PROPERTY rnpo1w_dis lr lr 0
TRACE PROPERTY rnwod_m wr wr 0
TRACE PROPERTY rnwod_m lr lr 0
TRACE PROPERTY rnwsti_m wr wr 0
TRACE PROPERTY rnwsti_m lr lr 0
TRACE PROPERTY rpod_m wr wr 0
TRACE PROPERTY rpod_m lr lr 0
TRACE PROPERTY rpodrpo_m wr wr 0
TRACE PROPERTY rpodrpo_m lr lr 0
TRACE PROPERTY rpodw_m wr wr 0
TRACE PROPERTY rpodw_m lr lr 0
TRACE PROPERTY rppo1_dis wr wr 0
TRACE PROPERTY rppo1_dis lr lr 0
TRACE PROPERTY rppo1rpo_dis wr wr 0
TRACE PROPERTY rppo1rpo_dis lr lr 0
TRACE PROPERTY rppo1w_dis wr wr 0
TRACE PROPERTY rppo1w_dis lr lr 0
TRACE PROPERTY rppolyhri_dis wr wr 0
TRACE PROPERTY rppolyhri_dis lr lr 0
CELL COMPARISON RESULTS ( TOP LEVEL )
# # INCORRECT #
Error: Different numbers of nets (see below).
Error: Different numbers of instances (see below).
LAYOUT CELL NAME: ADV7180_top
SOURCE CELL NAME: ADV7180_top
INITIAL NUMBERS OF OBJECTS
Layout Source Component Type
Ports: 83 84 *
Nets: 849923 840863 *
Instances: 891044 867623 * MN (4 pins)
892814 867733 * MP (4 pins)
0 1 * D_RAM (31 pins)
0 10 * blk_mem_gen0 (99 pins)
0 1 * mem_Bur1 (32 pins)
0 3 * ramm (54 pins)
Total Inst: 1783858 1735371
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports: 83 83
Nets: 480238 462923 *
Instances: 50682 50827 * MN (4 pins)
52793 52816 * MP (4 pins)
83 83 AOI_3_1 (5 pins)
1 1 AOI_3_3 (7 pins)
29 29 OAI_3_1 (5 pins)
1 1 OAI_3_3 (7 pins)
7 7 SDW3 (4 pins)
36 36 SUP3 (4 pins)
2132 2104 * SPDW_2_1 (4 pins)
296 298 * SPDW_2_1_1 (5 pins)
981 981 SPDW_2_2 (5 pins)
745 743 * SPDW_2_2_1 (6 pins)
618 618 SPDW_2_2_2 (7 pins)
36 36 SPDW_3_2 (6 pins)
671 647 * SPUP_2_1 (4 pins)
35 35 SPUP_2_1_1 (5 pins)
12937 12933 * SPUP_2_2 (5 pins)
95 95 SPUP_2_2_1 (6 pins)
1202 1202 SPUP_2_2_2 (7 pins)
7 7 SPUP_3_2 (6 pins)
1 1 SPMN((2+1)*1) (6 pins)
9748 9748 SPMN((2+2)*1) (7 pins)
9748 9748 SPMP((2+2)*1) (7 pins)
17669 17669 _bitcoreb (6 pins)
235350 235438 * _invv (4 pins)
2 2 _invx13v (4 pins)
14767 14812 * _invx2v (4 pins)
3325 3381 * _invx3v (4 pins)
2041 1959 * _invx4v (4 pins)
271 271 _invx5v (4 pins)
7 4 * _invx6v (4 pins)
1 1 _invx9v (4 pins)
720 720 _mx2v (6 pins)
15540 15517 * _nand2v (5 pins)
273 273 _nand3v (6 pins)
499 499 _nand4v (7 pins)
45319 45201 * _nor2v (5 pins)
322 258 * _nor3v (6 pins)
325 316 * _nor4v (7 pins)
36 90 * _pdw2v (4 pins)
297 297 _pup2v (4 pins)
99601 99652 * _smn2v (4 pins)
1 65 * _smp3v (5 pins)
0 9 * _smp4v (6 pins)
76989 77135 * _sup2v (4 pins)
35338 35338 _tgmb (7 pins)
4914 4914 _xr2v (5 pins)
1319 1319 _xra2v (5 pins)
Total Inst: 697810 698151
* = Number of objects in layout different from number in source.
INCORRECT OBJECTS
LEGEND:
ne = Naming Error (same layout name found in source
circuit, but object was matched otherwise).
INCORRECT NETS
DISC# LAYOUT NAME SOURCE NAME
1 Net VDD VDD
(_invx4v):sup1 ** missing connection **
X2/X1611/M18(2144.800,747.140):b
X2/X1611/M18(2144.800,747.140):s
X2/X1611/M14(2142.240,747.140):b
X2/X1611/M14(2142.240,747.140):s
X2/X1342/M4(2127.940,742.460):b
X2/X1342/M4(2127.940,742.460):s
X2/X1342/M3(2127.140,742.460):b
X2/X1342/M3(2127.140,742.460):d
X13/X4194/M6(2484.820,3947.900):b
X13/X4194/M6(2484.820,3947.900):s
X13/X4194/M4(2483.460,3947.900):b
X13/X4194/M4(2483.460,3947.900):s
X12/X6803/M4(3381.080,3504.345):b
X12/X6803/M4(3381.080,3504.345):s
X12/X6803/M3(3380.480,3504.565):b
X12/X6803/M3(3380.480,3504.565):d
X13/X4192/M6(2449.180,3947.900):b
X13/X4192/M6(2449.180,3947.900):s
X13/X4192/M4(2447.820,3947.900):b
X13/X4192/M4(2447.820,3947.900):s
X12/X6802/M4(3365.240,3448.615):b
X12/X6802/M4(3365.240,3448.615):s
X12/X6802/M3(3364.640,3448.395):b
X12/X6802/M3(3364.640,3448.395):d
X13/X4195/M6(2503.300,3947.900):b
X13/X4195/M6(2503.300,3947.900):s
X13/X4195/M4(2501.940,3947.900):b
X13/X4195/M4(2501.940,3947.900):s
X12/X6801/M4(3348.080,3519.175):b
X12/X6801/M4(3348.080,3519.175):s
X12/X6801/M3(3347.480,3518.955):b
X12/X6801/M3(3347.480,3518.955):d
X13/X4196/M6(2513.860,3947.900):b
X13/X4196/M6(2513.860,3947.900):s
X13/X4196/M4(2512.500,3947.900):b
X13/X4196/M4(2512.500,3947.900):s
X12/X6800/M4(3340.160,3514.425):b
X12/X6800/M4(3340.160,3514.425):s
X12/X6800/M3(3339.560,3514.645):b
X12/X6800/M3(3339.560,3514.645):d
X13/X4187/M6(2360.740,3947.900):b
X13/X4187/M6(2360.740,3947.900):s
X13/X4187/M4(2359.380,3947.900):b
X13/X4187/M4(2359.380,3947.900):s
X12/X6799/M4(3330.920,3448.615):b
X12/X6799/M4(3330.920,3448.615):s
X12/X6799/M3(3330.320,3448.395):b
X12/X6799/M3(3330.320,3448.395):d
X13/X4193/M6(2473.600,3957.980):b
X13/X4193/M6(2473.600,3957.980):s
X13/X4193/M4(2472.240,3957.980):b
X13/X4193/M4(2472.240,3957.980):s
X12/X6798/M4(3328.940,3478.855):b
X12/X6798/M4(3328.940,3478.855):s
X12/X6798/M3(3328.340,3478.635):b
X12/X6798/M3(3328.340,3478.635):d
X13/X4198/M6(2564.020,3947.900):b
X13/X4198/M6(2564.020,3947.900):s
X13/X4198/M4(2562.660,3947.900):b
X13/X4198/M4(2562.660,3947.900):s
X12/X6797/M4(3311.120,3514.425):b
X12/X6797/M4(3311.120,3514.425):s
X12/X6797/M3(3310.520,3514.645):b
X12/X6797/M3(3310.520,3514.645):d
X13/X4186/M6(2334.340,3957.980):b
X13/X4186/M6(2334.340,3957.980):s
X13/X4186/M4(2332.980,3957.980):b
X13/X4186/M4(2332.980,3957.980):s
X12/X6796/M4(3299.240,3519.175):b
X12/X6796/M4(3299.240,3519.175):s
X12/X6796/M3(3298.640,3518.955):b
X12/X6796/M3(3298.640,3518.955):d
X13/X4189/M6(2395.060,3962.660):b
X13/X4189/M6(2395.060,3962.660):s
X13/X4189/M4(2393.700,3962.660):b
X13/X4189/M4(2393.700,3962.660):s
X12/X6795/M4(3279.440,3474.105):b
X12/X6795/M4(3279.440,3474.105):s
X12/X6795/M3(3278.840,3474.325):b
X12/X6795/M3(3278.840,3474.325):d
X13/X4197/M6(2544.880,3947.900):b
X13/X4197/M6(2544.880,3947.900):s
X13/X4197/M4(2543.520,3947.900):b
X13/X4197/M4(2543.520,3947.900):s
X12/X6794/M4(3274.820,3519.175):b
X12/X6794/M4(3274.820,3519.175):s
X12/X6794/M3(3274.220,3518.955):b
X12/X6794/M3(3274.220,3518.955):d
X13/X4188/M6(2374.600,3957.980):b
X13/X4188/M6(2374.600,3957.980):s
X13/X4188/M4(2373.240,3957.980):b
X13/X4188/M4(2373.240,3957.980):s
X12/X6793/M4(3259.640,3484.185):b
X12/X6793/M4(3259.640,3484.185):s
X12/X6793/M3(3259.040,3484.405):b
X12/X6793/M3(3259.040,3484.405):d
X13/X4191/M6(2424.760,3962.660):b
X13/X4191/M6(2424.760,3962.660):s
X13/X4191/M4(2423.400,3962.660):b
X13/X4191/M4(2423.400,3962.660):s
X12/X6792/M4(3238.520,3448.615):b
X12/X6792/M4(3238.520,3448.615):s
X12/X6792/M3(3237.920,3448.395):b
X12/X6792/M3(3237.920,3448.395):d
X13/X4190/M6(2405.620,3962.660):b
X13/X4190/M6(2405.620,3962.660):s
X13/X4190/M4(2404.260,3962.660):b
X13/X4190/M4(2404.260,3962.660):s
X12/X6791/M4(3236.540,3468.775):b
X12/X6791/M4(3236.540,3468.775):s
X12/X6791/M3(3235.940,3468.555):b
X12/X6791/M3(3235.940,3468.555):d
X12/X6286/M6(2421.460,3549.380):b
X12/X6286/M6(2421.460,3549.380):s
X12/X6286/M4(2420.100,3549.380):b
X12/X6286/M4(2420.100,3549.380):s
X12/X6770/M4(2425.400,3549.415):b
X12/X6770/M4(2425.400,3549.415):s
X12/X6770/M3(2424.800,3549.195):b
X12/X6770/M3(2424.800,3549.195):d
X12/X6285/M6(2345.560,3554.780):b
X12/X6285/M6(2345.560,3554.780):s
X12/X6285/M4(2344.200,3554.780):b
X12/X6285/M4(2344.200,3554.780):s
X12/X6776/M4(2458.400,3554.745):b
X12/X6776/M4(2458.400,3554.745):s
X12/X6776/M3(2457.800,3554.965):b
X12/X6776/M3(2457.800,3554.965):d
(_invx6v):sup1 ** missing connection **
X13/X553/M15(1886.780,3927.740):b
X13/X553/M15(1886.780,3927.740):s
X13/X553/M11(1884.180,3927.740):b
X13/X553/M11(1884.180,3927.740):s
X12/X7020/M4(2285.020,3509.060):b
X12/X7020/M4(2285.020,3509.060):s
X12/X7020/M3(2284.220,3509.060):b
X12/X7020/M3(2284.220,3509.060):d
X12/X6777/M4(2473.580,3509.095):b
X12/X6777/M4(2473.580,3509.095):s
X12/X6777/M3(2472.980,3508.875):b
X12/X6777/M3(2472.980,3508.875):d
X13/X552/M15(1857.080,3942.500):b
X13/X552/M15(1857.080,3942.500):s
X13/X552/M11(1854.480,3942.500):b
X13/X552/M11(1854.480,3942.500):s
X12/X5720/M4(2255.320,3519.140):b
X12/X5720/M4(2255.320,3519.140):s
X12/X5720/M3(2254.520,3519.140):b
X12/X5720/M3(2254.520,3519.140):d
X12/X6790/M4(3134.240,3519.175):b
X12/X6790/M4(3134.240,3519.175):s
X12/X6790/M3(3133.640,3518.955):b
X12/X6790/M3(3133.640,3518.955):d
X12/X6284/M6(2235.340,3474.140):b
X12/X6284/M6(2235.340,3474.140):s
X12/X6284/M4(2233.980,3474.140):b
X12/X6284/M4(2233.980,3474.140):s
X12/X6771/M4(2431.340,3474.105):b
X12/X6771/M4(2431.340,3474.105):s
X12/X6771/M3(2430.740,3474.325):b
X12/X6771/M3(2430.740,3474.325):d
X12/X7019/M4(2112.760,3534.620):b
X12/X7019/M4(2112.760,3534.620):s
X12/X7019/M3(2111.960,3534.620):b
X12/X7019/M3(2111.960,3534.620):d
X12/X6779/M4(2488.760,3534.585):b
X12/X6779/M4(2488.760,3534.585):s
X12/X6779/M3(2488.160,3534.805):b
X12/X6779/M3(2488.160,3534.805):d
X12/X7018/M4(2094.940,3514.460):b
X12/X7018/M4(2094.940,3514.460):s
X12/X7018/M3(2094.140,3514.460):b
X12/X7018/M3(2094.140,3514.460):d
X12/X880/M12(2437.860,3509.060):b
X12/X880/M12(2437.860,3509.060):s
X12/X880/M9(2435.940,3508.510):b
X12/X880/M9(2435.940,3508.510):d
X12/X6773/M4(2437.280,3514.425):b
X12/X6773/M4(2437.280,3514.425):s
X12/X6773/M3(2436.680,3514.645):b
X12/X6773/M3(2436.680,3514.645):d
X12/X5719/M4(2065.900,3504.380):b
X12/X5719/M4(2065.900,3504.380):s
X12/X5719/M3(2065.100,3504.380):b
X12/X5719/M3(2065.100,3504.380):d
X12/X6772/M4(2437.280,3504.345):b
X12/X6772/M4(2437.280,3504.345):s
X12/X6772/M3(2436.680,3504.565):b
X12/X6772/M3(2436.680,3504.565):d
X12/X6287/M6(2436.640,3579.620):b
X12/X6287/M6(2436.640,3579.620):s
X12/X6287/M4(2435.280,3579.620):b
X12/X6287/M4(2435.280,3579.620):s
X12/X6774/M4(2437.280,3564.825):b
X12/X6774/M4(2437.280,3564.825):s
X12/X6774/M3(2436.680,3565.045):b
X12/X6774/M3(2436.680,3565.045):d
X12/X6283/M6(2130.400,3534.620):b
X12/X6283/M6(2130.400,3534.620):s
X12/X6283/M4(2129.040,3534.620):b
X12/X6283/M4(2129.040,3534.620):s
X12/X6775/M4(2438.600,3534.585):b
X12/X6775/M4(2438.600,3534.585):s
X12/X6775/M3(2438.000,3534.805):b
X12/X6775/M3(2438.000,3534.805):d
X9/X16513/M20(4130.040,2541.380):b
X9/X16513/M20(4130.040,2541.380):s
X9/X16513/M14(4126.200,2541.380):b
X9/X16513/M14(4126.200,2541.380):s
X9/X7176/M4(4125.100,2496.380):b
X9/X7176/M4(4125.100,2496.380):s
X9/X7176/M3(4124.300,2496.380):b
X9/X7176/M3(4124.300,2496.380):d
X9/X16512/M20(4123.440,2531.300):b
X9/X16512/M20(4123.440,2531.300):s
X9/X16512/M14(4119.600,2531.300):b
X9/X16512/M14(4119.600,2531.300):s
X9/X7172/M4(4118.500,2501.060):b
X9/X7172/M4(4118.500,2501.060):s
X9/X7172/M3(4117.700,2501.060):b
X9/X7172/M3(4117.700,2501.060):d
X9/X7174/M4(4121.800,2460.740):b
X9/X7174/M4(4121.800,2460.740):s
X9/X7174/M3(4121.000,2460.740):b
X9/X7174/M3(4121.000,2460.740):d
X9/X5989/M4(4118.500,2460.740):b
X9/X5989/M4(4118.500,2460.740):s
X9/X5989/M3(4117.700,2460.740):b
X9/X5989/M3(4117.700,2460.740):d
X9/X7173/M4(4120.480,2466.140):b
X9/X7173/M4(4120.480,2466.140):s
X9/X7173/M3(4119.680,2466.140):b
X9/X7173/M3(4119.680,2466.140):d
X9/X5988/M4(4117.180,2466.140):b
X9/X5988/M4(4117.180,2466.140):s
X9/X5988/M3(4116.380,2466.140):b
X9/X5988/M3(4116.380,2466.140):d
X9/X16511/M20(4120.140,2536.700):b
X9/X16511/M20(4120.140,2536.700):s
X9/X16511/M14(4116.300,2536.700):b
X9/X16511/M14(4116.300,2536.700):s
X9/X7171/M4(4115.200,2511.140):b
X9/X7171/M4(4115.200,2511.140):s
X9/X7171/M3(4114.400,2511.140):b
X9/X7171/M3(4114.400,2511.140):d
X9/X16510/M20(4075.260,2536.700):b
X9/X16510/M20(4075.260,2536.700):s
X9/X16510/M14(4071.420,2536.700):b
X9/X16510/M14(4071.420,2536.700):s
X9/X7170/M4(4070.320,2506.460):b
X9/X7170/M4(4070.320,2506.460):s
X9/X7170/M3(4069.520,2506.460):b
X9/X7170/M3(4069.520,2506.460):d
X8/X9999/M10(959.975,2325.440):b
X8/X9999/M10(959.975,2325.440):d
X11/X7328/M3(997.920,3176.410):b
X11/X7328/M3(997.920,3176.410):s
X11/X7328/M2(997.320,3176.410):b
X11/X7328/M2(997.320,3176.410):d
X11/X7599/M34(1001.935,3175.450):b
X11/X7599/M34(1001.935,3175.450):s
X8/X10001/M10(962.615,2309.120):b
X8/X10001/M10(962.615,2309.120):d
X11/X7319/M3(967.560,3201.990):b
X11/X7319/M3(967.560,3201.990):s
X11/X7319/M2(966.960,3201.990):b
X11/X7319/M2(966.960,3201.990):d
X11/X7591/M34(971.575,3202.950):b
X11/X7591/M34(971.575,3202.950):s
X8/X10000/M10(961.955,2218.400):b
X8/X10000/M10(961.955,2218.400):d
X11/X7317/M3(967.560,3186.490):b
X11/X7317/M3(967.560,3186.490):s
X11/X7317/M2(966.960,3186.490):b
X11/X7317/M2(966.960,3186.490):d
X11/X7589/M34(971.575,3185.530):b
X11/X7589/M34(971.575,3185.530):s
X8/X9991/M10(952.715,2248.640):b
X8/X9991/M10(952.715,2248.640):d
X11/X7322/M3(970.200,3171.750):b
X11/X7322/M3(970.200,3171.750):s
X11/X7322/M2(969.600,3171.750):b
X11/X7322/M2(969.600,3171.750):d
X11/X7594/M34(974.215,3172.710):b
X11/X7594/M34(974.215,3172.710):s
X8/X9996/M10(957.995,2264.960):b
X8/X9996/M10(957.995,2264.960):d
X11/X7316/M3(967.560,3181.830):b
X11/X7316/M3(967.560,3181.830):s
X11/X7316/M2(966.960,3181.830):b
X11/X7316/M2(966.960,3181.830):d
X11/X7588/M34(971.575,3182.790):b
X11/X7588/M34(971.575,3182.790):s
X8/X9994/M10(955.355,2204.480):b
X8/X9994/M10(955.355,2204.480):d
X11/X7325/M3(985.380,3196.570):b
X11/X7325/M3(985.380,3196.570):s
X11/X7325/M2(984.780,3196.570):b
X11/X7325/M2(984.780,3196.570):d
X11/X7596/M34(989.395,3195.610):b
X11/X7596/M34(989.395,3195.610):s
X8/X9988/M10(950.075,2278.880):b
X8/X9988/M10(950.075,2278.880):d
X11/X7315/M3(967.560,3171.750):b
X11/X7315/M3(967.560,3171.750):s
X11/X7315/M2(966.960,3171.750):b
X11/X7315/M2(966.960,3171.750):d
X11/X15491/X1/M34(968.935,3175.450):b
X11/X15491/X1/M34(968.935,3175.450):s
X8/X9992/M10(954.035,2295.200):b
X8/X9992/M10(954.035,2295.200):d
X11/X7321/M3(969.540,3212.070):b
X11/X7321/M3(969.540,3212.070):s
X11/X7321/M2(968.940,3212.070):b
X11/X7321/M2(968.940,3212.070):d
X11/X7593/M34(973.555,3213.030):b
X11/X7593/M34(973.555,3213.030):s
X8/X9998/M10(959.975,2234.720):b
X8/X9998/M10(959.975,2234.720):d
X11/X7318/M3(967.560,3196.570):b
X11/X7318/M3(967.560,3196.570):s
X11/X7318/M2(966.960,3196.570):b
X11/X7318/M2(966.960,3196.570):d
X11/X7590/M34(971.575,3195.610):b
X11/X7590/M34(971.575,3195.610):s
X7/X11649/M10(960.635,1986.560):b
X7/X11649/M10(960.635,1986.560):d
X10/X18865/X0/M3(1008.480,3040.710):b
X10/X18865/X0/M3(1008.480,3040.710):s
X10/X18865/X0/M2(1007.880,3040.710):b
X10/X18865/X0/M2(1007.880,3040.710):d
X10/X18865/X1/M34(1012.495,3041.670):b
X10/X18865/X1/M34(1012.495,3041.670):s
X7/X11656/M10(961.945,2047.040):b
X7/X11656/M10(961.945,2047.040):d
X11/X7314/M3(967.560,3166.330):b
X11/X7314/M3(967.560,3166.330):s
X11/X7314/M2(966.960,3166.330):b
X11/X7314/M2(966.960,3166.330):d
X11/X7587/M34(971.575,3165.370):b
X11/X7587/M34(971.575,3165.370):s
X7/X11654/M10(963.935,1821.440):b
X7/X11654/M10(963.935,1821.440):d
X10/X18864/X0/M3(1007.820,3000.390):b
X10/X18864/X0/M3(1007.820,3000.390):s
X10/X18864/X0/M2(1007.220,3000.390):b
X10/X18864/X0/M2(1007.220,3000.390):d
X10/X18864/X1/M34(1011.835,3001.350):b
X10/X18864/X1/M34(1011.835,3001.350):s
X7/X11652/M10(962.615,2033.120):b
X7/X11652/M10(962.615,2033.120):d
X11/X7320/M3(967.560,3206.650):b
X11/X7320/M3(967.560,3206.650):s
X11/X7320/M2(966.960,3206.650):b
X11/X7320/M2(966.960,3206.650):d
X11/X7592/M34(971.575,3205.690):b
X11/X7592/M34(971.575,3205.690):s
X7/X11639/M10(952.715,2093.600):b
X7/X11639/M10(952.715,2093.600):d
X11/X7324/M3(985.380,3186.490):b
X11/X7324/M3(985.380,3186.490):s
X11/X7324/M2(984.780,3186.490):b
X11/X7324/M2(984.780,3186.490):d
X11/X7595/M34(989.395,3185.530):b
X11/X7595/M34(989.395,3185.530):s
X7/X11650/M10(960.635,2077.280):b
X7/X11650/M10(960.635,2077.280):d
X11/X7323/M3(985.380,3181.830):b
X11/X7323/M3(985.380,3181.830):s
X11/X7323/M2(984.780,3181.830):b
X11/X7323/M2(984.780,3181.830):d
X11/X15491/X0/M34(984.115,3175.450):b
X11/X15491/X0/M34(984.115,3175.450):s
X7/X11646/M10(956.675,1926.080):b
X7/X11646/M10(956.675,1926.080):d
X10/X18855/X0/M3(981.420,3005.050):b
X10/X18855/X0/M3(981.420,3005.050):s
X10/X18855/X0/M2(980.820,3005.050):b
X10/X18855/X0/M2(980.820,3005.050):d
X10/X18855/X1/M34(985.435,3004.090):b
X10/X18855/X1/M34(985.435,3004.090):s
X7/X11655/M10(963.935,1865.600):b
X7/X11655/M10(963.935,1865.600):d
X10/X7615/M3(987.360,3000.390):b
X10/X7615/M3(987.360,3000.390):s
X10/X7615/M2(986.760,3000.390):b
X10/X7615/M2(986.760,3000.390):d
X10/X17470/X1/M34(991.375,3001.350):b
X10/X17470/X1/M34(991.375,3001.350):s
X7/X11641/M10(953.375,1972.640):b
X7/X11641/M10(953.375,1972.640):d
X10/X18863/X0/M3(999.240,3020.550):b
X10/X18863/X0/M3(999.240,3020.550):s
X10/X18863/X0/M2(998.640,3020.550):b
X10/X18863/X0/M2(998.640,3020.550):d
X10/X18863/X1/M34(1003.255,3021.510):b
X10/X18863/X1/M34(1003.255,3021.510):s
X7/X11658/M10(978.455,1835.360):b
X7/X11658/M10(978.455,1835.360):d
X10/X18859/X0/M3(988.680,3015.130):b
X10/X18859/X0/M3(988.680,3015.130):s
X10/X18859/X0/M2(988.080,3015.130):b
X10/X18859/X0/M2(988.080,3015.130):d
X10/X18859/X1/M34(992.695,3014.170):b
X10/X18859/X1/M34(992.695,3014.170):s
X7/X11638/M10(952.055,1805.120):b
X7/X11638/M10(952.055,1805.120):d
X10/X18862/X0/M3(999.240,3005.050):b
X10/X18862/X0/M3(999.240,3005.050):s
X10/X18862/X0/M2(998.640,3005.050):b
X10/X18862/X0/M2(998.640,3005.050):d
X10/X18862/X1/M34(1003.255,3004.090):b
X10/X18862/X1/M34(1003.255,3004.090):s
2 Net VSS VSS
(_invx4v):sup2 ** missing connection **
X2/X1611/M4(2144.840,748.625):b
X2/X1611/M4(2144.840,748.625):s
X2/X1611/M0(2142.240,748.625):b
X2/X1611/M0(2142.240,748.625):s
X2/X1342/M1(2127.940,740.850):b
X2/X1342/M1(2127.940,740.850):s
X2/X1342/M0(2127.140,740.950):b
X2/X1342/M0(2127.140,740.950):d
X13/X4194/M1(2484.900,3946.420):b
X13/X4194/M1(2484.900,3946.420):s
X13/X4194/M0(2484.260,3945.770):b
X13/X4194/M0(2484.260,3945.770):d
X12/X6803/M1(3381.120,3502.745):b
X12/X6803/M1(3381.120,3502.745):s
X12/X6803/M0(3380.520,3502.745):b
X12/X6803/M0(3380.520,3502.745):d
X13/X4192/M1(2449.260,3946.420):b
X13/X4192/M1(2449.260,3946.420):s
X13/X4192/M0(2448.620,3945.770):b
X13/X4192/M0(2448.620,3945.770):d
X12/X6802/M1(3365.280,3450.215):b
X12/X6802/M1(3365.280,3450.215):s
X12/X6802/M0(3364.680,3450.215):b
X12/X6802/M0(3364.680,3450.215):d
X13/X4195/M1(2503.380,3946.420):b
X13/X4195/M1(2503.380,3946.420):s
X13/X4195/M0(2502.740,3945.770):b
X13/X4195/M0(2502.740,3945.770):d
X12/X6801/M1(3348.120,3520.775):b
X12/X6801/M1(3348.120,3520.775):s
X12/X6801/M0(3347.520,3520.775):b
X12/X6801/M0(3347.520,3520.775):d
X13/X4196/M1(2513.940,3946.420):b
X13/X4196/M1(2513.940,3946.420):s
X13/X4196/M0(2513.300,3945.770):b
X13/X4196/M0(2513.300,3945.770):d
X12/X6800/M1(3340.200,3512.825):b
X12/X6800/M1(3340.200,3512.825):s
X12/X6800/M0(3339.600,3512.825):b
X12/X6800/M0(3339.600,3512.825):d
X13/X4187/M1(2360.820,3946.420):b
X13/X4187/M1(2360.820,3946.420):s
X13/X4187/M0(2360.180,3945.770):b
X13/X4187/M0(2360.180,3945.770):d
X12/X6799/M1(3330.960,3450.215):b
X12/X6799/M1(3330.960,3450.215):s
X12/X6799/M0(3330.360,3450.215):b
X12/X6799/M0(3330.360,3450.215):d
X13/X4193/M1(2473.680,3956.500):b
X13/X4193/M1(2473.680,3956.500):s
X13/X4193/M0(2473.040,3955.850):b
X13/X4193/M0(2473.040,3955.850):d
X12/X6798/M1(3328.980,3480.455):b
X12/X6798/M1(3328.980,3480.455):s
X12/X6798/M0(3328.380,3480.455):b
X12/X6798/M0(3328.380,3480.455):d
X13/X4198/M1(2564.100,3946.420):b
X13/X4198/M1(2564.100,3946.420):s
X13/X4198/M0(2563.460,3945.770):b
X13/X4198/M0(2563.460,3945.770):d
X12/X6797/M1(3311.160,3512.825):b
X12/X6797/M1(3311.160,3512.825):s
X12/X6797/M0(3310.560,3512.825):b
X12/X6797/M0(3310.560,3512.825):d
X13/X4186/M1(2334.420,3956.500):b
X13/X4186/M1(2334.420,3956.500):s
X13/X4186/M0(2333.780,3955.850):b
X13/X4186/M0(2333.780,3955.850):d
X12/X6796/M1(3299.280,3520.775):b
X12/X6796/M1(3299.280,3520.775):s
X12/X6796/M0(3298.680,3520.775):b
X12/X6796/M0(3298.680,3520.775):d
X13/X4189/M1(2395.140,3964.140):b
X13/X4189/M1(2395.140,3964.140):s
X13/X4189/M0(2394.500,3964.790):b
X13/X4189/M0(2394.500,3964.790):d
X12/X6795/M1(3279.480,3472.505):b
X12/X6795/M1(3279.480,3472.505):s
X12/X6795/M0(3278.880,3472.505):b
X12/X6795/M0(3278.880,3472.505):d
X13/X4197/M1(2544.960,3946.420):b
X13/X4197/M1(2544.960,3946.420):s
X13/X4197/M0(2544.320,3945.770):b
X13/X4197/M0(2544.320,3945.770):d
X12/X6794/M1(3274.860,3520.775):b
X12/X6794/M1(3274.860,3520.775):s
X12/X6794/M0(3274.260,3520.775):b
X12/X6794/M0(3274.260,3520.775):d
X13/X4188/M1(2374.680,3956.500):b
X13/X4188/M1(2374.680,3956.500):s
X13/X4188/M0(2374.040,3955.850):b
X13/X4188/M0(2374.040,3955.850):d
X12/X6793/M1(3259.680,3482.585):b
X12/X6793/M1(3259.680,3482.585):s
X12/X6793/M0(3259.080,3482.585):b
X12/X6793/M0(3259.080,3482.585):d
X13/X4191/M1(2424.840,3964.140):b
X13/X4191/M1(2424.840,3964.140):s
X13/X4191/M0(2424.200,3964.790):b
X13/X4191/M0(2424.200,3964.790):d
X12/X6792/M1(3238.560,3450.215):b
X12/X6792/M1(3238.560,3450.215):s
X12/X6792/M0(3237.960,3450.215):b
X12/X6792/M0(3237.960,3450.215):d
X13/X4190/M1(2405.700,3964.140):b
X13/X4190/M1(2405.700,3964.140):s
X13/X4190/M0(2405.060,3964.790):b
X13/X4190/M0(2405.060,3964.790):d
X12/X6791/M1(3236.580,3470.375):b
X12/X6791/M1(3236.580,3470.375):s
X12/X6791/M0(3235.980,3470.375):b
X12/X6791/M0(3235.980,3470.375):d
X12/X6286/M1(2421.540,3550.860):b
X12/X6286/M1(2421.540,3550.860):s
X12/X6286/M0(2420.900,3551.510):b
X12/X6286/M0(2420.900,3551.510):d
X12/X6770/M1(2425.440,3551.015):b
X12/X6770/M1(2425.440,3551.015):s
X12/X6770/M0(2424.840,3551.015):b
X12/X6770/M0(2424.840,3551.015):d
X12/X6285/M1(2345.640,3553.300):b
X12/X6285/M1(2345.640,3553.300):s
X12/X6285/M0(2345.000,3552.650):b
X12/X6285/M0(2345.000,3552.650):d
X12/X6776/M1(2458.440,3553.145):b
X12/X6776/M1(2458.440,3553.145):s
X12/X6776/M0(2457.840,3553.145):b
X12/X6776/M0(2457.840,3553.145):d
(_invx6v):sup2 ** missing connection **
X13/X553/M3(1886.140,3926.265):b
X13/X553/M3(1886.140,3926.265):s
X13/X553/M0(1884.180,3925.610):b
X13/X553/M0(1884.180,3925.610):d
X12/X7020/M1(2285.020,3511.190):b
X12/X7020/M1(2285.020,3511.190):s
X12/X7020/M0(2284.220,3511.060):b
X12/X7020/M0(2284.220,3511.060):d
X12/X6777/M1(2473.620,3510.695):b
X12/X6777/M1(2473.620,3510.695):s
X12/X6777/M0(2473.020,3510.695):b
X12/X6777/M0(2473.020,3510.695):d
X13/X552/M3(1856.440,3943.975):b
X13/X552/M3(1856.440,3943.975):s
X13/X552/M0(1854.480,3944.630):b
X13/X552/M0(1854.480,3944.630):d
X12/X5720/M1(2255.320,3520.750):b
X12/X5720/M1(2255.320,3520.750):s
X12/X5720/M0(2254.520,3520.650):b
X12/X5720/M0(2254.520,3520.650):d
X12/X6790/M1(3134.280,3520.775):b
X12/X6790/M1(3134.280,3520.775):s
X12/X6790/M0(3133.680,3520.775):b
X12/X6790/M0(3133.680,3520.775):d
X12/X6284/M1(2235.420,3472.660):b
X12/X6284/M1(2235.420,3472.660):s
X12/X6284/M0(2234.780,3472.010):b
X12/X6284/M0(2234.780,3472.010):d
X12/X6771/M1(2431.380,3472.505):b
X12/X6771/M1(2431.380,3472.505):s
X12/X6771/M0(2430.780,3472.505):b
X12/X6771/M0(2430.780,3472.505):d
X12/X7019/M1(2112.760,3532.490):b
X12/X7019/M1(2112.760,3532.490):s
X12/X7019/M0(2111.960,3532.620):b
X12/X7019/M0(2111.960,3532.620):d
X12/X6779/M1(2488.800,3532.985):b
X12/X6779/M1(2488.800,3532.985):s
X12/X6779/M0(2488.200,3532.985):b
X12/X6779/M0(2488.200,3532.985):d
X12/X7018/M1(2094.940,3512.330):b
X12/X7018/M1(2094.940,3512.330):s
X12/X7018/M0(2094.140,3512.460):b
X12/X7018/M0(2094.140,3512.460):d
X12/X880/M3(2437.940,3510.540):b
X12/X880/M3(2437.940,3510.540):s
X12/X880/M0(2436.020,3510.450):b
X12/X880/M0(2436.020,3510.450):d
X12/X6773/M1(2437.320,3512.825):b
X12/X6773/M1(2437.320,3512.825):s
X12/X6773/M0(2436.720,3512.825):b
X12/X6773/M0(2436.720,3512.825):d
X12/X5719/M1(2065.900,3502.770):b
X12/X5719/M1(2065.900,3502.770):s
X12/X5719/M0(2065.100,3502.870):b
X12/X5719/M0(2065.100,3502.870):d
X12/X6772/M1(2437.320,3502.745):b
X12/X6772/M1(2437.320,3502.745):s
X12/X6772/M0(2436.720,3502.745):b
X12/X6772/M0(2436.720,3502.745):d
X12/X6287/M1(2436.720,3581.100):b
X12/X6287/M1(2436.720,3581.100):s
X12/X6287/M0(2436.080,3581.750):b
X12/X6287/M0(2436.080,3581.750):d
X12/X6774/M1(2437.320,3563.225):b
X12/X6774/M1(2437.320,3563.225):s
X12/X6774/M0(2436.720,3563.225):b
X12/X6774/M0(2436.720,3563.225):d
X12/X6283/M1(2130.480,3533.140):b
X12/X6283/M1(2130.480,3533.140):s
X12/X6283/M0(2129.840,3532.490):b
X12/X6283/M0(2129.840,3532.490):d
X12/X6775/M1(2438.640,3532.985):b
X12/X6775/M1(2438.640,3532.985):s
X12/X6775/M0(2438.040,3532.985):b
X12/X6775/M0(2438.040,3532.985):d
X9/X16513/M4(4130.080,2542.865):b
X9/X16513/M4(4130.080,2542.865):s
X9/X16513/M0(4127.280,2543.510):b
X9/X16513/M0(4127.280,2543.510):s
X9/X7176/M1(4125.100,2494.250):b
X9/X7176/M1(4125.100,2494.250):s
X9/X7176/M0(4124.300,2494.380):b
X9/X7176/M0(4124.300,2494.380):d
X9/X16512/M4(4123.480,2532.785):b
X9/X16512/M4(4123.480,2532.785):s
X9/X16512/M0(4120.680,2533.430):b
X9/X16512/M0(4120.680,2533.430):s
X9/X7172/M1(4118.500,2503.190):b
X9/X7172/M1(4118.500,2503.190):s
X9/X7172/M0(4117.700,2503.060):b
X9/X7172/M0(4117.700,2503.060):d
X9/X7174/M1(4121.800,2462.870):b
X9/X7174/M1(4121.800,2462.870):s
X9/X7174/M0(4121.000,2462.740):b
X9/X7174/M0(4121.000,2462.740):d
X9/X5989/M1(4118.500,2462.350):b
X9/X5989/M1(4118.500,2462.350):s
X9/X5989/M0(4117.700,2462.250):b
X9/X5989/M0(4117.700,2462.250):d
X9/X7173/M1(4120.480,2464.010):b
X9/X7173/M1(4120.480,2464.010):s
X9/X7173/M0(4119.680,2464.140):b
X9/X7173/M0(4119.680,2464.140):d
X9/X5988/M1(4117.180,2464.530):b
X9/X5988/M1(4117.180,2464.530):s
X9/X5988/M0(4116.380,2464.630):b
X9/X5988/M0(4116.380,2464.630):d
X9/X16511/M4(4120.180,2535.215):b
X9/X16511/M4(4120.180,2535.215):s
X9/X16511/M0(4117.380,2534.570):b
X9/X16511/M0(4117.380,2534.570):s
X9/X7171/M1(4115.200,2513.270):b
X9/X7171/M1(4115.200,2513.270):s
X9/X7171/M0(4114.400,2513.140):b
X9/X7171/M0(4114.400,2513.140):d
X9/X16510/M4(4075.300,2535.215):b
X9/X16510/M4(4075.300,2535.215):s
X9/X16510/M0(4072.500,2534.570):b
X9/X16510/M0(4072.500,2534.570):s
X9/X7170/M1(4070.320,2504.330):b
X9/X7170/M1(4070.320,2504.330):s
X9/X7170/M0(4069.520,2504.460):b
X9/X7170/M0(4069.520,2504.460):d
X8/X9999/M4(959.975,2323.380):b
X8/X9999/M4(959.975,2323.380):d
X11/X7328/M1(997.960,3178.225):b
X11/X7328/M1(997.960,3178.225):s
X11/X7328/M0(997.360,3177.885):b
X11/X7328/M0(997.360,3177.885):d
X11/X7599/M15(1002.205,3178.550):b
X11/X7599/M15(1002.205,3178.550):s
X8/X10001/M4(962.615,2311.180):b
X8/X10001/M4(962.615,2311.180):d
X11/X7319/M1(967.600,3200.175):b
X11/X7319/M1(967.600,3200.175):s
X11/X7319/M0(967.000,3200.515):b
X11/X7319/M0(967.000,3200.515):d
X11/X7591/M15(971.845,3199.850):b
X11/X7591/M15(971.845,3199.850):s
X8/X10000/M4(961.955,2220.460):b
X8/X10000/M4(961.955,2220.460):d
X11/X7317/M1(967.600,3188.305):b
X11/X7317/M1(967.600,3188.305):s
X11/X7317/M0(967.000,3187.965):b
X11/X7317/M0(967.000,3187.965):d
X11/X7589/M15(971.845,3188.630):b
X11/X7589/M15(971.845,3188.630):s
X8/X9991/M4(952.715,2250.700):b
X8/X9991/M4(952.715,2250.700):d
X11/X7322/M1(970.240,3169.935):b
X11/X7322/M1(970.240,3169.935):s
X11/X7322/M0(969.640,3170.275):b
X11/X7322/M0(969.640,3170.275):d
X11/X7594/M15(974.485,3169.610):b
X11/X7594/M15(974.485,3169.610):s
X8/X9996/M4(957.995,2262.900):b
X8/X9996/M4(957.995,2262.900):d
X11/X7316/M1(967.600,3180.015):b
X11/X7316/M1(967.600,3180.015):s
X11/X7316/M0(967.000,3180.355):b
X11/X7316/M0(967.000,3180.355):d
X11/X7588/M15(971.845,3179.690):b
X11/X7588/M15(971.845,3179.690):s
X8/X9994/M4(955.355,2202.420):b
X8/X9994/M4(955.355,2202.420):d
X11/X7325/M1(985.420,3198.385):b
X11/X7325/M1(985.420,3198.385):s
X11/X7325/M0(984.820,3198.045):b
X11/X7325/M0(984.820,3198.045):d
X11/X7596/M15(989.665,3198.710):b
X11/X7596/M15(989.665,3198.710):s
X8/X9988/M4(950.075,2280.940):b
X8/X9988/M4(950.075,2280.940):d
X11/X7315/M1(967.600,3169.935):b
X11/X7315/M1(967.600,3169.935):s
X11/X7315/M0(967.000,3170.275):b
X11/X7315/M0(967.000,3170.275):d
X11/X15491/X1/M15(969.205,3178.550):b
X11/X15491/X1/M15(969.205,3178.550):s
X8/X9992/M4(954.035,2293.140):b
X8/X9992/M4(954.035,2293.140):d
X11/X7321/M1(969.580,3210.255):b
X11/X7321/M1(969.580,3210.255):s
X11/X7321/M0(968.980,3210.595):b
X11/X7321/M0(968.980,3210.595):d
X11/X7593/M15(973.825,3209.930):b
X11/X7593/M15(973.825,3209.930):s
X8/X9998/M4(959.975,2232.660):b
X8/X9998/M4(959.975,2232.660):d
X11/X7318/M1(967.600,3198.385):b
X11/X7318/M1(967.600,3198.385):s
X11/X7318/M0(967.000,3198.045):b
X11/X7318/M0(967.000,3198.045):d
X11/X7590/M15(971.845,3198.710):b
X11/X7590/M15(971.845,3198.710):s
X7/X11649/M4(960.635,1988.620):b
X7/X11649/M4(960.635,1988.620):d
X10/X18865/X0/M1(1008.520,3038.895):b
X10/X18865/X0/M1(1008.520,3038.895):s
X10/X18865/X0/M0(1007.920,3039.235):b
X10/X18865/X0/M0(1007.920,3039.235):d
X10/X18865/X1/M15(1012.765,3038.570):b
X10/X18865/X1/M15(1012.765,3038.570):s
X7/X11656/M4(961.945,2049.100):b
X7/X11656/M4(961.945,2049.100):d
X11/X7314/M1(967.600,3168.145):b
X11/X7314/M1(967.600,3168.145):s
X11/X7314/M0(967.000,3167.805):b
X11/X7314/M0(967.000,3167.805):d
X11/X7587/M15(971.845,3168.470):b
X11/X7587/M15(971.845,3168.470):s
X7/X11654/M4(963.935,1819.380):b
X7/X11654/M4(963.935,1819.380):d
X10/X18864/X0/M1(1007.860,2998.575):b
X10/X18864/X0/M1(1007.860,2998.575):s
X10/X18864/X0/M0(1007.260,2998.915):b
X10/X18864/X0/M0(1007.260,2998.915):d
X10/X18864/X1/M15(1012.105,2998.250):b
X10/X18864/X1/M15(1012.105,2998.250):s
X7/X11652/M4(962.615,2031.060):b
X7/X11652/M4(962.615,2031.060):d
X11/X7320/M1(967.600,3208.465):b
X11/X7320/M1(967.600,3208.465):s
X11/X7320/M0(967.000,3208.125):b
X11/X7320/M0(967.000,3208.125):d
X11/X7592/M15(971.845,3208.790):b
X11/X7592/M15(971.845,3208.790):s
X7/X11639/M4(952.715,2091.540):b
X7/X11639/M4(952.715,2091.540):d
X11/X7324/M1(985.420,3188.305):b
X11/X7324/M1(985.420,3188.305):s
X11/X7324/M0(984.820,3187.965):b
X11/X7324/M0(984.820,3187.965):d
X11/X7595/M15(989.665,3188.630):b
X11/X7595/M15(989.665,3188.630):s
X7/X11650/M4(960.635,2079.340):b
X7/X11650/M4(960.635,2079.340):d
X11/X7323/M1(985.420,3180.015):b
X11/X7323/M1(985.420,3180.015):s
X11/X7323/M0(984.820,3180.355):b
X11/X7323/M0(984.820,3180.355):d
X11/X15491/X0/M15(984.385,3178.550):b
X11/X15491/X0/M15(984.385,3178.550):s
X7/X11646/M4(956.675,1928.140):b
X7/X11646/M4(956.675,1928.140):d
X10/X18855/X0/M1(981.460,3006.865):b
X10/X18855/X0/M1(981.460,3006.865):s
X10/X18855/X0/M0(980.860,3006.525):b
X10/X18855/X0/M0(980.860,3006.525):d
X10/X18855/X1/M15(985.705,3007.190):b
X10/X18855/X1/M15(985.705,3007.190):s
X7/X11655/M4(963.935,1867.660):b
X7/X11655/M4(963.935,1867.660):d
X10/X7615/M1(987.400,2998.575):b
X10/X7615/M1(987.400,2998.575):s
X10/X7615/M0(986.800,2998.915):b
X10/X7615/M0(986.800,2998.915):d
X10/X17470/X1/M15(991.645,2998.250):b
X10/X17470/X1/M15(991.645,2998.250):s
X7/X11641/M4(953.375,1970.580):b
X7/X11641/M4(953.375,1970.580):d
X10/X18863/X0/M1(999.280,3018.735):b
X10/X18863/X0/M1(999.280,3018.735):s
X10/X18863/X0/M0(998.680,3019.075):b
X10/X18863/X0/M0(998.680,3019.075):d
X10/X18863/X1/M15(1003.525,3018.410):b
X10/X18863/X1/M15(1003.525,3018.410):s
X7/X11658/M4(978.455,1837.420):b
X7/X11658/M4(978.455,1837.420):d
X10/X18859/X0/M1(988.720,3016.945):b
X10/X18859/X0/M1(988.720,3016.945):s
X10/X18859/X0/M0(988.120,3016.605):b
X10/X18859/X0/M0(988.120,3016.605):d
X10/X18859/X1/M15(992.965,3017.270):b
X10/X18859/X1/M15(992.965,3017.270):s
X7/X11638/M4(952.055,1807.180):b
X7/X11638/M4(952.055,1807.180):d
X10/X18862/X0/M1(999.280,3006.865):b
X10/X18862/X0/M1(999.280,3006.865):s
X10/X18862/X0/M0(998.680,3006.525):b
X10/X18862/X0/M0(998.680,3006.525):d
X10/X18862/X1/M15(1003.525,3007.190):b
X10/X18862/X1/M15(1003.525,3007.190):s
3 Net 5440 Act_O
(_invx3v):in ** missing connection **
X2/X1791/M0(2392.960,741.070):g
X2/X1791/M2(2392.960,742.460):g
** missing connection ** (_invv):in
XSDP_OUTPUT_BT656/XU110/M0:g
XSDP_OUTPUT_BT656/XU110/M1:g
4 Net 284 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[13].U/Xx_shifter/n29
(SPUP_2_1):input ** missing connection **
X4/X3537/M5(2318.420,1028.710):g
** missing connection ** (_sup2v):in2
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[13].U/Xx_shifter/XU192/M2:g
5 Net 438 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[10].U/Xy_shifter/n268
(SPUP_2_1)utput ** missing connection **
X3/X3262/M5(2849.060,988.390):d
** missing connection ** (_sup2v)ut1
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[10].U/Xy_shifter/XU192/M2:d
6 Net 435 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[10].U/Xy_shifter/n23
X3/X3262/M5(2849.060,988.390):g
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[10].U/Xy_shifter/XU192/M2:g
7 Net 530 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[8].U/Xx_shifter/n21
X4/X3565/M5(3140.780,1035.450):g
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[8].U/Xx_shifter/XU193/M2:g
8 Net 5720 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[5].U/Xx_shifter/n268
X4/X3569/M5(3421.940,1176.570):d
** missing connection ** (_sup2v):out1
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[5].U/Xx_shifter/XU191/M2:d
9 Net 889 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[5].U/Xx_shifter/n29
X4/X3569/M5(3421.940,1176.570):g
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[5].U/Xx_shifter/XU191/M2:g
10 Net 1910 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xx_shifter/n30
X7/X6099/M5(2923.640,1811.610):g
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xx_shifter/XU170/M2:g
11 Net 2533 Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/FE_OFN646_ram_addr_1_
(_invx4v):in ** missing connection **
X9/X7170/M0(4069.520,2504.460):g
X9/X7170/M3(4069.520,2506.460):g
** missing connection ** (_invx2v):in
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC647_ram_addr_1_/M2:g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC647_ram_addr_1_/M3:g
** missing connection ** Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xline0_buf:A[1]
** missing connection ** Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xline1_buf:A[1]
12 Net 3163 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n52
(_invx2v):in ** missing connection **
X9/X3281/M0(970.400,2573.100):g
X9/X3281/M1(970.400,2571.620):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU39/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU39/M1:g
13 Net 3168 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n58
X9/X11280/X0/M0(972.380,2625.940):g
X9/X11280/X0/M1(972.380,2627.420):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU33/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU33/M1:g
14 Net 3160 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n53
X9/X3282/M0(973.700,2583.180):g
X9/X3282/M1(973.700,2581.700):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU41/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU41/M1:g
15 Net 3161 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n56
X9/X11281/X0/M0(977.660,2605.780):g
X9/X11281/X0/M1(977.660,2607.260):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU47/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU47/M1:g
16 Net 3167 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n32
X9/X12406/X1/M0(978.980,2563.020):g
X9/X12406/X1/M1(978.980,2561.540):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU35/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU35/M1:g
17 Net 3166 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n57
X9/X3283/M0(984.920,2615.860):g
X9/X3283/M1(984.920,2617.340):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU49/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU49/M1:g
18 Net 3164 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n33
X9/X3284/M0(985.580,2565.460):g
X9/X3284/M1(985.580,2566.940):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU37/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU37/M1:g
19 Net 3165 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n54
X9/X11362/X1/M0(986.900,2585.620):g
X9/X11362/X1/M1(986.900,2587.100):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU43/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU43/M1:g
20 Net 3162 Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/n59
X9/X3285/M0(986.900,2636.020):g
X9/X3285/M1(986.900,2637.500):g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU31/M0:g
Xsdp_inst/XComb_Filter_inst/Xu2_ntsc_top/Xinst_y_gen/XU31/M1:g
21 Net 3670 Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/FE_OFN657_ram_addr_5_
(_invx4v):out ** missing connection **
X9/X7173/M1(4120.480,2464.010):d
X9/X7173/M4(4120.480,2466.140):d
** missing connection ** (_invx2v):out
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC657_ram_addr_5_/M0:d
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC657_ram_addr_5_/M1:s
22 Net 5596 Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/FE_OFN640_ram_addr_4_
X9/X7176/M0(4124.300,2494.380):g
X9/X7176/M3(4124.300,2496.380):g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC641_ram_addr_4_/M2:g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC641_ram_addr_4_/M3:g
** missing connection ** Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xline0_buf:A[4]
** missing connection ** Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xline1_buf:A[4]
23 Net 5594 Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/FE_OFN644_ram_addr_2_
X9/X7171/M0(4114.400,2513.140):g
X9/X7171/M3(4114.400,2511.140):g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC645_ram_addr_2_/M2:g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC645_ram_addr_2_/M3:g
** missing connection ** Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xline0_buf:A[2]
** missing connection ** Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xline1_buf:A[2]
24 Net 5595 Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/FE_OFN642_ram_addr_3_
X9/X7172/M0(4117.700,2503.060):g
X9/X7172/M3(4117.700,2501.060):g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC643_ram_addr_3_/M2:g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XFE_OFC643_ram_addr_3_/M3:g
** missing connection ** Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xline0_buf:A[3]
** missing connection ** Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xline1_buf:A[3]
25 Net 4804 Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/FE_OFN653_ram_addr_7_
(SPUP_2_2):input ** missing connection **
X12/X3442/M5(1290.860,3685.935):g
(_nand2v):in2 ** missing connection **
X12/X6304/M13(1289.375,3689.895):g
X12/X6304/M5(1289.255,3691.875):g
(_smn2v):in1 ** missing connection **
X12/X3442/M1(1290.820,3684.015):g
(_invv):in ** missing connection **
X12/X6304/M4(1289.855,3692.145):g
X12/X6304/M12(1289.975,3689.895):g
** missing connection ** (SPUP_2_2):input
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XU418/M4:g
** missing connection ** (_nand2v):in2
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xadd_2081/XU1_1_7/M0:g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xadd_2081/XU1_1_7/M2:g
** missing connection ** (_smn2v):in1
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/XU418/M3:g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xadd_2081/XU1_1_7/M14:g
Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_line_buf_ctrl_ntsc/Xadd_2081/XU1_1_7/M15:g
26 Net X2/688 XSDP_OUTPUT_BT656/addra[6]
X2/X1342/M0(2127.140,740.950):g
X2/X1342/M3(2127.140,742.460):g
XSDP_OUTPUT_BT656/XFE_OFC316_addra_6_/M2:g
XSDP_OUTPUT_BT656/XFE_OFC316_addra_6_/M3:g
27 Net X2/226 XSDP_OUTPUT_BT656/FE_OFCN8414_FE_OFN316_addra_6_
X2/X1611/M4(2144.840,748.625):d
X2/X1611/M18(2144.800,747.140):d
XSDP_OUTPUT_BT656/XFE_OFCC8414_FE_OFN316_addra_6_/M0:d
XSDP_OUTPUT_BT656/XFE_OFCC8414_FE_OFN316_addra_6_/M1:s
** missing connection ** XSDP_OUTPUT_BT656/XCbCb:AA[6]
** missing connection ** XSDP_OUTPUT_BT656/XYYY:AA[6]
28 Net X3/816 XSDP_OUTPUT_BT656/XVS/XVS_NTSC/\add_1_root_add_18533/carry[4]
(_nand2v):in1 ** missing connection **
X3/X1704/M3(1715.090,947.545):g
X3/X1704/M0(1715.240,949.935):g
(_xr2v):in2 ** missing connection **
X3/X1596/M1(1711.995,950.870):g
X3/X1596/M7(1712.070,948.610):g
** missing connection ** (_nand2v):in1
XSDP_OUTPUT_BT656/XVS/XVS_NTSC/XU179/M3:g
XSDP_OUTPUT_BT656/XVS/XVS_NTSC/XU179/M5:g
** missing connection ** (_xr2v):in2
XSDP_OUTPUT_BT656/XVS/XVS_NTSC/XU180/M10:g
XSDP_OUTPUT_BT656/XVS/XVS_NTSC/XU180/M11:g
29 Net X3/818 XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19004_cf/carry[4]
X3/X1597/M1(1715.955,991.190):g
X3/X1597/M7(1716.030,988.930):g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M10:g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M11:g
30 Net X3/828 XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19002_cf/carry[2]
X3/X1605/M1(1749.615,941.930):g
X3/X1605/M7(1749.690,944.190):g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M10:g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M11:g
31 Net X3/1809 XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19004_cf/carry[1]
X3/X1729/M3(1813.430,955.335):g
X3/X1729/M0(1813.580,952.945):g
X3/X5613/X0/M1(1808.355,952.010):g
X3/X5613/X0/M7(1808.430,954.270):g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU30/M3:g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU30/M5:g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M10:g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M11:g
32 Net X3/1132 XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19002_cf/carry[1]
(_nor2v):in2 ** missing connection **
X3/X2122/M1(1715.230,993.270):g
X3/X2122/M4(1715.220,995.120):g
** missing connection ** (_nor2v):in2
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU50/M4:g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU50/M2:g
33 Net X3/1150 XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19004_cf/carry[3]
X3/X2126/M1(1736.350,942.870):g
X3/X2126/M4(1736.340,944.720):g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU26/M4:g
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU26/M2:g
34 Net X3/3362 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[10].U/Xx_shifter/n23
X3/X3256/M5(2748.080,927.910):g
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[10].U/Xx_shifter/XU192/M2:g
35 Net X3/976 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[10].U/Xx_shifter/n268
(SPUP_2_1):output ** missing connection **
X3/X3256/M5(2748.080,927.910):d
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[10].U/Xx_shifter/XU192/M2:d
36 Net X3/3185 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[12].U/Xx_shifter/n263
X3/X3250/M5(2538.200,1005.210):d
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[12].U/Xx_shifter/XU198/M2:d
37 Net X3/3278 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[11].U/Xx_shifter/n263
X3/X3255/M5(2697.580,958.150):d
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[11].U/Xx_shifter/XU198/M2:d
38 Net X3/1203 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xsub_5119/XU1/net38
(_xra2v):in1 ** missing connection **
X3/X3210/M0(1904.705,990.680):g
X3/X3210/M6(1904.800,988.400):g
X3/X3210/M2(1903.030,990.605):g
X3/X3210/M9(1902.300,988.930):g
** missing connection ** (_xra2v):in2
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xsub_5119/XU1/M8:g
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xsub_5119/XU1/M9:g
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xsub_5119/XU1/M3:s
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xsub_5119/XU1/M1:s
39 Net X3/1206 XSDP_OUTPUT_BT656/XVS/Xsub_17845/XU2/net38
(_invv):out ** missing connection **
X3/X5555/X1/M0(1909.180,990.540):d
X3/X5555/X1/M1(1909.180,989.060):d
** missing connection ** (_invv):out
XSDP_OUTPUT_BT656/XVS/Xsub_17845/XU2/M10:d
XSDP_OUTPUT_BT656/XVS/Xsub_17845/XU2/M11:s
40 Net X3/X1708/8 XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU48/net11
(_nand2v):out ** missing connection **
X3/X1708/M4(1720.950,988.725):s
X3/X1708/M3(1720.370,987.865):s
X3/X1708/M1(1721.080,990.255):d
** missing connection ** (_nand2v):out
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU48/M2:s
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU48/M3:s
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU48/M4:s
41 Net X3/X1713/8 XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU24/net11
X3/X1713/M4(1760.550,948.405):s
X3/X1713/M3(1759.970,947.545):s
X3/X1713/M1(1760.680,949.935):d
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU24/M2:s
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU24/M3:s
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU24/M4:s
42 Net X3/X1727/8 XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU32/net11
X3/X1727/M4(1814.010,944.395):s
X3/X1727/M3(1814.590,945.255):s
X3/X1727/M1(1813.880,942.865):d
** missing connection ** (_smn2v):out1
XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU32/M4:s
** missing connection ** XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU32/M2:s
43 Net X3/X3210/9 XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/net38
X3/X3210/M1(1904.055,991.190):d
X3/X3210/M7(1904.130,988.935):d
XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M10:d
XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M11:s
44 Net X3/X3214/9 XSDP_OUTPUT_BT656/XVS/Xsub_17845/n12
X3/X3214/M1(1914.705,991.190):d
X3/X3214/M7(1914.630,988.935):d
XSDP_OUTPUT_BT656/XVS/Xsub_17845/XU15/M0:d
XSDP_OUTPUT_BT656/XVS/Xsub_17845/XU15/M1:s
45 Net X3/X5214/X1/8 XSDP_OUTPUT_BT656/XVS/XVS_NTSC/XU181/net11
X3/X5214/X1/M4(1713.030,944.395):s
X3/X5214/X1/M3(1712.450,945.255):s
X3/X5214/X1/M1(1713.160,942.865):d
XSDP_OUTPUT_BT656/XVS/XVS_NTSC/XU181/M2:s
XSDP_OUTPUT_BT656/XVS/XVS_NTSC/XU181/M3:s
XSDP_OUTPUT_BT656/XVS/XVS_NTSC/XU181/M4:s
46 Net X4/4875 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[8].U/Xy_shifter/n21
X4/X3559/M5(3045.740,1156.410):g
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[8].U/Xy_shifter/XU193/M2:g
47 Net X4/1426 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[13].U/Xx_shifter/n268
X4/X3537/M5(2318.420,1028.710):d
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[13].U/Xx_shifter/XU192/M2:d
48 Net X4/1502 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[8].U/Xx_shifter/n268
X4/X3565/M5(3140.780,1035.450):d
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[8].U/Xx_shifter/XU193/M2:d
49 Net X4/3865 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[12].U/Xy_shifter/n263
X4/X3551/M5(2581.100,1136.250):d
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[12].U/Xy_shifter/XU198/M2:d
50 Net X4/4984 Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[8].U/Xy_shifter/n263
X4/X3563/M5(3111.400,1176.570):d
Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[8].U/Xy_shifter/XU198/M2:d
INCORRECT INSTANCES
51 (_nor2v) ** missing injected instance **
Devices:
X3/X3052/M2(2199.080,928.470) MP(P)
X3/X3052/M3(2199.640,928.470) MP(P)
X3/X3052/M0(2199.000,930.260) MN(N)
X3/X3052/M1(2199.720,930.260) MN(N)
52 (_nor2v) ** missing injected instance **
Devices:
X6/X15058/X1/M3(3293.920,1538.890) MP(P)
X6/X15058/X1/M2(3293.360,1538.890) MP(P)
X6/X15058/X1/M1(3294.000,1537.100) MN(N)
X6/X15058/X1/M0(3293.280,1537.100) MN(N)
53 (_nor2v) ** missing injected instance **
Devices:
X6/X15057/X1/M3(3287.980,1690.090) MP(P)
X6/X15057/X1/M2(3287.420,1690.090) MP(P)
X6/X15057/X1/M1(3288.060,1688.300) MN(N)
X6/X15057/X1/M0(3287.340,1688.300) MN(N)
54 (_nor2v) ** missing injected instance **
Devices:
X6/X9354/X1/M2(3099.320,1680.010) MP(P)
X6/X9354/X1/M3(3099.880,1680.010) MP(P)
X6/X9354/X1/M0(3099.240,1678.220) MN(N)
X6/X9354/X1/M1(3099.960,1678.220) MN(N)
55 (_nor2v) ** missing injected instance **
Devices:
X4/X7080/X1/X1/M2(2541.620,1055.050) MP(P)
X4/X7080/X1/X1/M3(2542.180,1055.050) MP(P)
X4/X7080/X1/X1/M0(2541.540,1053.260) MN(N)
X4/X7080/X1/X1/M1(2542.260,1053.260) MN(N)
56 (_nor2v) ** missing injected instance **
Devices:
X6/X5273/M2(3424.780,1559.050) MP(P)
X6/X5273/M3(3424.220,1559.050) MP(P)
X6/X5273/M0(3424.860,1557.260) MN(N)
X6/X5273/M1(3424.140,1557.260) MN(N)
57 (_nor2v) ** missing injected instance **
Devices:
X7/X17227/X1/M3(3147.400,1805.430) MP(P)
X7/X17227/X1/M2(3146.840,1805.430) MP(P)
X7/X17227/X1/M1(3147.480,1807.220) MN(N)
X7/X17227/X1/M0(3146.760,1807.220) MN(N)
58 (_nor2v) ** missing injected instance **
Devices:
X4/X3392/M2(2344.940,1039.350) MP(P)
X4/X3392/M3(2345.500,1039.350) MP(P)
X4/X3392/M0(2344.860,1041.140) MN(N)
X4/X3392/M1(2345.580,1041.140) MN(N)
59 (_nor2v) ** missing injected instance **
Devices:
X4/X3398/M2(2376.700,1119.990) MP(P)
X4/X3398/M3(2376.140,1119.990) MP(P)
X4/X3398/M0(2376.780,1121.780) MN(N)
X4/X3398/M1(2376.060,1121.780) MN(N)
60 (_nor2v) ** missing injected instance **
Devices:
X6/X15226/X1/M3(3369.820,1720.330) MP(P)
X6/X15226/X1/M2(3369.260,1720.330) MP(P)
X6/X15226/X1/M1(3369.900,1718.540) MN(N)
X6/X15226/X1/M0(3369.180,1718.540) MN(N)
61 (_nor2v) ** missing injected instance **
Devices:
X5/X13117/X1/M2(2246.680,1276.810) MP(P)
X5/X13117/X1/M3(2246.120,1276.810) MP(P)
X5/X13117/X1/M0(2246.760,1275.020) MN(N)
X5/X13117/X1/M1(2246.040,1275.020) MN(N)
62 (_nor2v) ** missing injected instance **
Devices:
X7/X10340/X1/M3(2928.940,1805.430) MP(P)
X7/X10340/X1/M2(2928.380,1805.430) MP(P)
X7/X10340/X1/M1(2929.020,1807.220) MN(N)
X7/X10340/X1/M0(2928.300,1807.220) MN(N)
63 (_nor2v) ** missing injected instance **
Devices:
X4/X3412/M2(2531.140,1186.090) MP(P)
X4/X3412/M3(2530.580,1186.090) MP(P)
X4/X3412/M0(2531.220,1184.300) MN(N)
X4/X3412/M1(2530.500,1184.300) MN(N)
64 (_nor2v) ** missing injected instance **
Devices:
X6/X12650/X1/X1/M2(2853.140,1710.250) MP(P)
X6/X12650/X1/X1/M3(2853.700,1710.250) MP(P)
X6/X12650/X1/X1/M0(2853.060,1708.460) MN(N)
X6/X12650/X1/X1/M1(2853.780,1708.460) MN(N)
65 (_nor2v) ** missing injected instance **
Devices:
X4/X3380/M2(2211.620,1155.850) MP(P)
X4/X3380/M3(2212.180,1155.850) MP(P)
X4/X3380/M0(2211.540,1154.060) MN(N)
X4/X3380/M1(2212.260,1154.060) MN(N)
66 (_nor2v) ** missing injected instance **
Devices:
X7/X10323/X1/M3(2325.700,1952.170) MP(P)
X7/X10323/X1/M2(2325.140,1952.170) MP(P)
X7/X10323/X1/M1(2325.780,1950.380) MN(N)
X7/X10323/X1/M0(2325.060,1950.380) MN(N)
67 (_nor2v) ** missing injected instance **
Devices:
X7/X10137/X1/M3(2512.480,1952.170) MP(P)
X7/X10137/X1/M2(2511.920,1952.170) MP(P)
X7/X10137/X1/M1(2512.560,1950.380) MN(N)
X7/X10137/X1/M0(2511.840,1950.380) MN(N)
68 (_nor2v) ** missing injected instance **
Devices:
X7/X5773/M2(1802.420,1881.610) MP(P)
X7/X5773/M3(1802.980,1881.610) MP(P)
X7/X5773/M0(1802.340,1879.820) MN(N)
X7/X5773/M1(1803.060,1879.820) MN(N)
69 (_nor2v) ** missing injected instance **
Devices:
X7/X10111/X1/M3(1743.580,2052.970) MP(P)
X7/X10111/X1/M2(1743.020,2052.970) MP(P)
X7/X10111/X1/M1(1743.660,2051.180) MN(N)
X7/X10111/X1/M0(1742.940,2051.180) MN(N)
70 (_nor2v) ** missing injected instance **
Devices:
X7/X15901/X1/M2(1761.500,2002.570) MP(P)
X7/X15901/X1/M3(1762.060,2002.570) MP(P)
X7/X15901/X1/M0(1761.420,2000.780) MN(N)
X7/X15901/X1/M1(1762.140,2000.780) MN(N)
71 (_nor2v) ** missing injected instance **
Devices:
X7/X5765/M2(1737.820,1911.850) MP(P)
X7/X5765/M3(1737.260,1911.850) MP(P)
X7/X5765/M0(1737.900,1910.060) MN(N)
X7/X5765/M1(1737.180,1910.060) MN(N)
72 (_nor2v) ** missing injected instance **
Devices:
X7/X10136/X1/M3(2451.100,2012.650) MP(P)
X7/X10136/X1/M2(2450.540,2012.650) MP(P)
X7/X10136/X1/M1(2451.180,2010.860) MN(N)
X7/X10136/X1/M0(2450.460,2010.860) MN(N)
73 (_nor2v) ** missing injected instance **
Devices:
X7/X15907/X1/M3(2400.280,1891.690) MP(P)
X7/X15907/X1/M2(2399.720,1891.690) MP(P)
X7/X15907/X1/M1(2400.360,1889.900) MN(N)
X7/X15907/X1/M0(2399.640,1889.900) MN(N)
74 (_nor2v) ** missing injected instance **
Devices:
X8/X12892/X1/M3(2207.560,2248.950) MP(P)
X8/X12892/X1/M2(2207.000,2248.950) MP(P)
X8/X12892/X1/M1(2207.640,2250.740) MN(N)
X8/X12892/X1/M0(2206.920,2250.740) MN(N)
75 (_nor2v) ** missing injected instance **
Devices:
X5/X4785/M2(2457.140,1407.850) MP(P)
X5/X4785/M3(2457.700,1407.850) MP(P)
X5/X4785/M0(2457.060,1406.060) MN(N)
X5/X4785/M1(2457.780,1406.060) MN(N)
76 (_nor2v) ** missing injected instance **
Devices:
X5/X11589/X1/X1/M2(2406.980,1276.810) MP(P)
X5/X11589/X1/X1/M3(2407.540,1276.810) MP(P)
X5/X11589/X1/X1/M0(2406.900,1275.020) MN(N)
X5/X11589/X1/X1/M1(2407.620,1275.020) MN(N)
77 (_nor2v) ** missing injected instance **
Devices:
X5/X4798/M2(2545.000,1271.190) MP(P)
X5/X4798/M3(2544.440,1271.190) MP(P)
X5/X4798/M0(2545.080,1272.980) MN(N)
X5/X4798/M1(2544.360,1272.980) MN(N)
78 (_nor2v) ** missing injected instance **
Devices:
X8/X15625/X1/M3(2628.920,2309.430) MP(P)
X8/X15625/X1/M2(2629.480,2309.430) MP(P)
X8/X15625/X1/M1(2628.840,2311.220) MN(N)
X8/X15625/X1/M0(2629.560,2311.220) MN(N)
79 (_nor2v) ** missing injected instance **
Devices:
X5/X4774/M2(2433.380,1438.090) MP(P)
X5/X4774/M3(2433.940,1438.090) MP(P)
X5/X4774/M0(2433.300,1436.300) MN(N)
X5/X4774/M1(2434.020,1436.300) MN(N)
80 (_nor2v) ** missing injected instance **
Devices:
X5/X4804/M2(2574.040,1382.070) MP(P)
X5/X4804/M3(2573.480,1382.070) MP(P)
X5/X4804/M0(2574.120,1383.860) MN(N)
X5/X4804/M1(2573.400,1383.860) MN(N)
81 (_nor2v) ** missing injected instance **
Devices:
X6/X15211/X1/M2(2641.280,1639.690) MP(P)
X6/X15211/X1/M3(2641.840,1639.690) MP(P)
X6/X15211/X1/M0(2641.200,1637.900) MN(N)
X6/X15211/X1/M1(2641.920,1637.900) MN(N)
82 (_nor2v) ** missing injected instance **
Devices:
X5/X8454/X1/M2(2124.500,1472.790) MP(P)
X5/X8454/X1/M3(2125.060,1472.790) MP(P)
X5/X8454/X1/M0(2124.420,1474.580) MN(N)
X5/X8454/X1/M1(2125.140,1474.580) MN(N)
83 (_nor2v) ** missing injected instance **
Devices:
X5/X8610/X1/M2(1950.260,1397.770) MP(P)
X5/X8610/X1/M3(1950.820,1397.770) MP(P)
X5/X8610/X1/M0(1950.180,1395.980) MN(N)
X5/X8610/X1/M1(1950.900,1395.980) MN(N)
84 (_nor2v) ** missing injected instance **
Devices:
X5/X11588/X1/X1/M3(2280.160,1448.170) MP(P)
X5/X11588/X1/X1/M2(2279.600,1448.170) MP(P)
X5/X11588/X1/X1/M1(2280.240,1446.380) MN(N)
X5/X11588/X1/X1/M0(2279.520,1446.380) MN(N)
85 (_nor2v) ** missing injected instance **
Devices:
X8/X9027/X1/M3(2149.480,2204.170) MP(P)
X8/X9027/X1/M2(2148.920,2204.170) MP(P)
X8/X9027/X1/M1(2149.560,2202.380) MN(N)
X8/X9027/X1/M0(2148.840,2202.380) MN(N)
86 (_nor2v) ** missing injected instance **
Devices:
X6/X15052/X1/M3(2738.200,1543.350) MP(P)
X6/X15052/X1/M2(2737.640,1543.350) MP(P)
X6/X15052/X1/M1(2738.280,1545.140) MN(N)
X6/X15052/X1/M0(2737.560,1545.140) MN(N)
87 (_nor2v) ** missing injected instance **
Devices:
X6/X5213/M2(2770.720,1690.090) MP(P)
X6/X5213/M3(2770.160,1690.090) MP(P)
X6/X5213/M0(2770.800,1688.300) MN(N)
X6/X5213/M1(2770.080,1688.300) MN(N)
88 (_nor2v) ** missing injected instance **
Devices:
X6/X5217/M2(2805.040,1659.850) MP(P)
X6/X5217/M3(2804.480,1659.850) MP(P)
X6/X5217/M0(2805.120,1658.060) MN(N)
X6/X5217/M1(2804.400,1658.060) MN(N)
89 (_nor2v) ** missing injected instance **
Devices:
X5/X12400/X1/M3(2010.880,1468.330) MP(P)
X5/X12400/X1/M2(2010.320,1468.330) MP(P)
X5/X12400/X1/M1(2010.960,1466.540) MN(N)
X5/X12400/X1/M0(2010.240,1466.540) MN(N)
90 (_nor2v) ** missing injected instance **
Devices:
X5/X4723/M2(2071.040,1367.530) MP(P)
X5/X4723/M3(2071.600,1367.530) MP(P)
X5/X4723/M0(2070.960,1365.740) MN(N)
X5/X4723/M1(2071.680,1365.740) MN(N)
91 (_nor2v) ** missing injected instance **
Devices:
X5/X13051/X1/M2(2314.580,1472.790) MP(P)
X5/X13051/X1/M3(2315.140,1472.790) MP(P)
X5/X13051/X1/M0(2314.500,1474.580) MN(N)
X5/X13051/X1/M1(2315.220,1474.580) MN(N)
92 (_nor2v) ** missing injected instance **
Devices:
X8/X11966/X1/X1/M3(2655.700,2269.110) MP(P)
X8/X11966/X1/X1/M2(2655.140,2269.110) MP(P)
X8/X11966/X1/X1/M1(2655.780,2270.900) MN(N)
X8/X11966/X1/X1/M0(2655.060,2270.900) MN(N)
93 (_nor2v) ** missing injected instance **
Devices:
X6/X5183/M2(2443.940,1518.730) MP(P)
X6/X5183/M3(2444.500,1518.730) MP(P)
X6/X5183/M0(2443.860,1516.940) MN(N)
X6/X5183/M1(2444.580,1516.940) MN(N)
94 (_nor2v) ** missing injected instance **
Devices:
X6/X5212/M2(2770.060,1684.470) MP(P)
X6/X5212/M3(2769.500,1684.470) MP(P)
X6/X5212/M0(2770.140,1686.260) MN(N)
X6/X5212/M1(2769.420,1686.260) MN(N)
95 (_nor2v) ** missing injected instance **
Devices:
X7/X5803/M3(2533.220,1956.630) MP(P)
X7/X5803/M2(2533.780,1956.630) MP(P)
X7/X5803/M1(2533.140,1958.420) MN(N)
X7/X5803/M0(2533.860,1958.420) MN(N)
96 (_nor2v) ** missing injected instance **
Devices:
X8/X5370/M3(2073.860,2148.150) MP(P)
X8/X5370/M2(2074.420,2148.150) MP(P)
X8/X5370/M1(2073.780,2149.940) MN(N)
X8/X5370/M0(2074.500,2149.940) MN(N)
97 (_nor2v) ** missing injected instance **
Devices:
X7/X5768/M2(1765.460,1785.270) MP(P)
X7/X5768/M3(1766.020,1785.270) MP(P)
X7/X5768/M0(1765.380,1787.060) MN(N)
X7/X5768/M1(1766.100,1787.060) MN(N)
98 (_nor2v) ** missing injected instance **
Devices:
X5/X4776/M2(2433.380,1498.570) MP(P)
X5/X4776/M3(2433.940,1498.570) MP(P)
X5/X4776/M0(2433.300,1496.780) MN(N)
X5/X4776/M1(2434.020,1496.780) MN(N)
99 (_nor2v) ** missing injected instance **
Devices:
X7/X17206/X1/M3(1729.060,1811.050) MP(P)
X7/X17206/X1/M2(1728.500,1811.050) MP(P)
X7/X17206/X1/M1(1729.140,1809.260) MN(N)
X7/X17206/X1/M0(1728.420,1809.260) MN(N)
100 (_nor2v) ** missing injected instance **
Devices:
X8/X13646/X1/M3(2627.320,2224.330) MP(P)
X8/X13646/X1/M2(2626.760,2224.330) MP(P)
X8/X13646/X1/M1(2627.400,2222.540) MN(N)
X8/X13646/X1/M0(2626.680,2222.540) MN(N)
PROPERTY ERRORS
DISC# LAYOUT SOURCE ERROR
101 X6/M0(907.380,1746.630) MN(N) XSDA1_IO_tri/M4 MN(N)
l: 0.183073 u l: 0.18 u 1.71%
w: 1.18314 u w: 1.18 u 0.266%
102 X6/X10991/M11(3299.340,1634.180) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[2].U/Xadd_5118/XU1_19/M9 MP(P)
l: 0.182016 u l: 0.18 u 1.12%
w: 1.80314 u w: 1.8 u 0.174%
103 X7/X12237/M11(2091.540,1795.460) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[7].U/Xadd_5400/XU1_9/M9 MP(P)
104 X6/X10990/M11(3218.160,1745.060) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[1].U/Xsub_5117/XU2_19/M9 MP(P)
105 X7/X12236/M11(2064.480,1800.860) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[7].U/Xsub_5396/XU2_9/M9 MP(P)
106 X6/X10989/M11(3208.920,1750.460) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[1].U/Xadd_5113/XU1_19/M9 MP(P)
107 X6/X10988/M11(3142.260,1700.060) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[1].U/Xsub_5114/XU2_19/M9 MP(P)
108 X5/X10034/M11(2593.140,1458.140) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[2].U/Xsub_5396/XU2_9/M9 MP(P)
109 X6/X10992/M11(3300.000,1629.500) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[2].U/Xsub_5114/XU2_19/M9 MP(P)
110 X6/X10996/M11(3457.740,1679.900) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[2].U/Xsub_5117/XU2_19/M9 MP(P)
111 X7/X12240/M11(2098.800,1911.740) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[8].U/Xadd_5400/XU1_9/M9 MP(P)
112 X6/X10995/M11(3430.020,1689.980) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[2].U/Xadd_5113/XU1_19/M9 MP(P)
113 X7/X12239/M11(2096.820,1785.380) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[7].U/Xadd_5395/XU1_9/M9 MP(P)
114 X5/X10035/M11(2595.780,1468.220) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[2].U/Xadd_5400/XU1_9/M9 MP(P)
115 X6/X10994/M11(3414.840,1523.300) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[3].U/Xadd_5118/XU1_19/M9 MP(P)
116 X6/X10993/M11(3404.280,1518.620) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[3].U/Xsub_5114/XU2_19/M9 MP(P)
117 X7/X12238/M11(2080.980,1906.340) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[8].U/Xsub_5396/XU2_9/M9 MP(P)
118 X7/X12235/M11(1952.940,2133.500) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Return/X\rota1[12].U/Xsub_5399/XU2_9/M9 MP(P)
119 X6/X10982/M11(2898.720,1750.460) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xsub_5117/XU2_19/M9 MP(P)
120 X7/X12232/M11(1893.540,2057.540) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Return/X\rota1[12].U/Xadd_5397/XU1_31/M9 MP(P)
121 X6/X10981/M11(2898.720,1745.060) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xadd_5113/XU1_19/M9 MP(P)
122 X5/X10030/M11(2463.780,1442.660) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[3].U/Xadd_5395/XU1_9/M9 MP(P)
123 X7/X12231/M11(1879.020,1785.380) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Return/X\rota1[8].U/Xsub_5401/XU2_31/M9 MP(P)
124 X5/X10031/M11(2484.900,1452.740) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[3].U/Xsub_5396/XU2_9/M9 MP(P)
125 X6/X10983/M11(2930.400,1750.460) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xadd_5118/XU1_19/M9 MP(P)
126 X6/X10987/M11(3137.640,1704.740) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[1].U/Xadd_5118/XU1_19/M9 MP(P)
127 X6/X10986/M11(3092.100,1589.180) MP(P) Xsdp_inst/XFsc_inst/XLP_Costas/Xadd_6356/XU1_43/M9 MP(P)
128 X7/X12234/M11(1934.460,2128.100) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Return/X\rota1[12].U/Xadd_5395/XU1_9/M9 MP(P)
129 X6/X10985/M11(3081.540,1614.020) MP(P) Xsdp_inst/XFsc_inst/XLP_Costas/Xadd_6355/XU1_43/M9 MP(P)
130 X6/X10984/M11(2942.940,1745.060) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xsub_5114/XU2_19/M9 MP(P)
131 X7/X12233/M11(1894.200,2062.940) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Return/X\rota1[12].U/Xsub_5401/XU2_31/M9 MP(P)
132 X5/X10036/M11(2611.620,1458.140) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[2].U/Xsub_5399/XU2_9/M9 MP(P)
133 X9/X10343/M11(3906.540,2561.540) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_2924/XU1_16/M9 MP(P)
134 X9/X10344/M11(4022.040,2682.500) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_2999/XU1_33/M9 MP(P)
135 X9/X10345/M11(4034.580,2712.740) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_2993/XU1_33/M9 MP(P)
136 X9/X10346/M11(4047.120,2601.860) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_3005/XU1_33/M9 MP(P)
137 X5/X10040/M11(2799.720,1427.900) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[14].U/Xadd_5115/XU1_31/M9 MP(P)
138 X9/X10347/M11(4050.420,2682.500) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_3068/XU1_34/M9 MP(P)
139 X7/X12247/M11(2159.520,2007.140) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[9].U/Xsub_5401/XU2_31/M9 MP(P)
140 X9/X10348/M11(4064.940,2677.820) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_3082/XU1_35/M9 MP(P)
141 X9/X10342/M11(3889.380,2627.420) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_2918/XU1_16/M9 MP(P)
142 X9/X10337/M11(2521.860,2486.300) MP(P) Xsdp_inst/XSDP_AGC_INST/Xdivuu24_inst3/XU62/M9 MP(P)
143 X8/X10503/M11(4068.240,2168.420) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_gen/Xadd_4804/XU1_15/M9 MP(P)
144 X9/X10338/M11(2786.520,2566.940) MP(P) Xsdp_inst/XSDP_AGC_INST/Xdivuu22_inst2/XU345/M9 MP(P)
145 X9/X10339/M11(3713.820,2712.740) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_2899/XU1_16/M9 MP(P)
146 X9/X10340/M11(3754.080,2702.660) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_2905/XU1_16/M9 MP(P)
147 X7/X12248/M11(2159.520,2047.460) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[10].U/Xsub_5401/XU2_31/M9 MP(P)
148 X9/X10341/M11(3852.420,2672.420) MP(P) Xsdp_inst/XComb_Filter_inst/Xu1_ntsc_top/Xinst_v_NP_filter/Xadd_2911/XU1_16/M9 MP(P)
149 X6/X11000/M11(3677.520,1569.020) MP(P) Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[2].U/Xadd_5115/XU1_31/M9 MP(P)
150 X7/X12243/M11(2126.520,1916.420) MP(P) Xsdp_inst/XFsc_inst/XCostas_NCO/XSin_Cos_Export/X\rota1[8].U/Xsub_5399/XU2_9/M9 MP(P)
INFORMATION AND WARNINGS
Matched Matched Unmatched Unmatched Component
Layout Source Layout Source Type
Ports: 83 83 0 0
Nets: 462747 462747 17491 176
Instances: 50682 50682 0 145 MN(N)
52793 52793 0 23 MP(P)
0 0 0 1 D_RAM
0 0 0 10 blk_mem_gen0
0 0 0 1 mem_Bur1
0 0 0 3 ramm
83 83 0 0 AOI_3_1
1 1 0 0 AOI_3_3
29 29 0 0 OAI_3_1
1 1 0 0 OAI_3_3
7 7 0 0 SDW3
36 36 0 0 SUP3
2104 2104 28 0 SPDW_2_1
296 296 0 2 SPDW_2_1_1
981 981 0 0 SPDW_2_2
743 743 2 0 SPDW_2_2_1
618 618 0 0 SPDW_2_2_2
36 36 0 0 SPDW_3_2
643 643 28 4 SPUP_2_1
35 35 0 0 SPUP_2_1_1
12933 12933 4 0 SPUP_2_2
95 95 0 0 SPUP_2_2_1
1202 1202 0 0 SPUP_2_2_2
7 7 0 0 SPUP_3_2
1 1 0 0 SPMN((2+1)*1)
9748 9748 0 0 SPMN((2+2)*1)
9748 9748 0 0 SPMP((2+2)*1)
17669 17669 0 0 _bitcoreb
235350 235350 0 88 _invv
2 2 0 0 _invx13v
14760 14760 7 52 _invx2v
3325 3325 0 56 _invx3v
1959 1959 82 0 _invx4v
271 271 0 0 _invx5v
4 4 3 0 _invx6v
1 1 0 0 _invx9v
720 720 0 0 _mx2v
15517 15517 23 0 _nand2v
273 273 0 0 _nand3v
499 499 0 0 _nand4v
45201 45201 118 0 _nor2v
258 258 64 0 _nor3v
316 316 9 0 _nor4v
36 36 0 54 _pdw2v
297 297 0 0 _pup2v
99601 99601 0 51 _smn2v
1 1 0 64 _smp3v
0 0 0 9 _smp4v
76989 76989 0 146 _sup2v
35338 35338 0 0 _tgmb
4914 4914 0 0 _xr2v
1319 1319 0 0 _xra2v
Total Inst: 697442 697442 368 709
o Statistics:
1 passthrough layout net was found.
2 passthrough source nets were found, of which 1 was deleted.
9790 source nets were deep shorted to 3296.
88872 layout mos transistors were reduced to 40159. 113 connecting nets were deleted.
48503 mos transistors were deleted by parallel reduction.
210 mos transistors and 113 connecting nets were deleted by split-gate reduction.
959 source mos transistors were reduced to 452. 113 connecting nets were deleted.
297 mos transistors were deleted by parallel reduction.
1583 source nets had all their pins removed and were deleted.
5 nets and 1 instance were matched arbitrarily.
o Passthrough Layout Nets And Their Ports:
(Layout nets which are connected only to ports).
I2C_cfdone (port: I2C_cfdone),
o Initial Correspondence Points:
Ports: VDD VSS Cr_O[6] Cb_O[6] Cr_O[5] Cr_O[3] Cr_O[1] Cr_O[7] Y_O[2] Cr_O[4] Cr_O[2]
Cr_O[0] Cb_O[7] Cb_O[5] Cb_O[4] Cb_O[3] Cb_O[2] HS_F Cb_O[1] Hsync_O Cb_O[0]
Field_F VS_F BT656_O[2] BT656_O[4] BT656_O[3] BT656_O[7] BT656_O[6] BT656_O[5]
Y_O[3] Y_O[1] Y_O[0] Y_O[7] Y_O[6] Y_O[5] Y_O[4] RSTN Vsync_O Ain1_I[8]
Ain1_I[0] Ain1_I[7] Ain1_I[9] Ain1_I[4] Ain1_I[5] Ain1_I[3] Ain3_I[0] Ain2_I[0]
Ain2_I[7] Ain2_I[8] Ain3_I[7]
o Ambiguity Resolution Points:
(Each one of the following objects belongs to a group of indistinguishable objects.
The listed objects were matched arbitrarily by the Ambiguity Resolution feature of LVS.
Arbitrary matching may be prevented by assigning names to these objects or to adjacent nets).
Layout Source
Nets
X8/X10002/12 Xsdp_inst/XComb_Filter_inst/Xu2_line_add/XU30/net39
X6/5449 XU_i2cSlaveTOP/XU_i2cSlave/Xu_registerRW/n173
X6/4188 Xsdp_inst/XComb_Filter_inst/N94
X13/X5270/X1/12 Xsdp_inst/XFsc_inst/X\Blank_O_reg[9]/pm
X13/X4337/X1/12 Xsdp_inst/XFsc_inst/X\Blank_O_reg[8]/pm
Instances
(_invv) (_invv)
Devices:
X3/X1708/M5(1721.750,988.725) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU48/M1 MP(P)
X3/X1708/M2(1721.690,990.535) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU48/M0 MN(N)
DETAILED INSTANCE CONNECTIONS
LAYOUT NAME SOURCE NAME
(This section contains detailed information about connections of
matched instances that are involved in net discrepancies).
(_xr2v) (_xr2v)
out: X3/X1596/10 out: XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/net29
sup1: VDD sup1: VDD
sup2: VSS sup2: VSS
in1: X3/815 ** no similar net **
in2: X3/816 ** XSDP_OUTPUT_BT656/XVS/XVS_NTSC/\add_1_root_add_18533/carry[4] **
** VSS ** in1: VSS
** X3/1809 ** in2: XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19004_cf/carry[1]
Devices:
X3/X1596/M8(1710.970,948.610) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M1 MP(P)
X3/X1596/M9(1710.200,948.610) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M0 MP(P)
X3/X1596/M3(1710.200,950.300) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M2 MN(N)
X3/X1596/M2(1710.970,950.300) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M3 MN(N)
X3/X1596/M6(1712.740,948.080) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M7 MP(P)
X3/X1596/M0(1712.645,950.360) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M6 MN(N)
X3/X1596/M7(1712.070,948.610) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M11 MP(P)
X3/X1596/M1(1711.995,950.870) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M10 MN(N)
X3/X1596/M10(1709.480,948.610) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M9 MP(P)
X3/X1596/M4(1709.480,950.300) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU31/M8 MN(N)
(_xr2v) (_xr2v)
out: X3/X1597/10 out: XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/net29
sup1: VDD sup1: VDD
sup2: VSS sup2: VSS
in1: X3/817 ** no similar net **
in2: X3/818 ** XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19004_cf/carry[4] **
** VDD ** in1: VDD
** X3/828 ** in2: XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19002_cf/carry[2]
Devices:
X3/X1597/M8(1714.930,988.930) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M1 MP(P)
X3/X1597/M9(1714.160,988.930) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M0 MP(P)
X3/X1597/M3(1714.160,990.620) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M2 MN(N)
X3/X1597/M2(1714.930,990.620) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M3 MN(N)
X3/X1597/M6(1716.700,988.400) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M7 MP(P)
X3/X1597/M0(1716.605,990.680) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M6 MN(N)
X3/X1597/M7(1716.030,988.930) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M11 MP(P)
X3/X1597/M1(1715.955,991.190) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M10 MN(N)
X3/X1597/M10(1713.440,988.930) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M9 MP(P)
X3/X1597/M4(1713.440,990.620) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU49/M8 MN(N)
(_xr2v) (_xr2v)
out: X3/X1605/10 out: XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/net29
sup1: VDD sup1: VDD
sup2: VSS sup2: VSS
in1: X3/827 ** no similar net **
in2: X3/828 ** XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19002_cf/carry[2] **
** VSS ** in1: VSS
** X3/818 ** in2: XSDP_OUTPUT_BT656/XVS/XVS_PAL/\add_1_root_add_19004_cf/carry[4]
Devices:
X3/X1605/M8(1748.590,944.190) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M1 MP(P)
X3/X1605/M9(1747.820,944.190) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M0 MP(P)
X3/X1605/M3(1747.820,942.500) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M2 MN(N)
X3/X1605/M2(1748.590,942.500) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M3 MN(N)
X3/X1605/M6(1750.360,944.720) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M7 MP(P)
X3/X1605/M0(1750.265,942.440) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M6 MN(N)
X3/X1605/M7(1749.690,944.190) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M11 MP(P)
X3/X1605/M1(1749.615,941.930) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M10 MN(N)
X3/X1605/M10(1747.100,944.190) MP(P) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M9 MP(P)
X3/X1605/M4(1747.100,942.500) MN(N) XSDP_OUTPUT_BT656/XVS/XVS_PAL/XU25/M8 MN(N)
(_xra2v) (_xra2v)
in2: X3/X3210/9 in2: XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/net38
out: X3/X3210/10 out: XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/net29
sup1: VDD sup1: VDD
sup2: VSS sup2: VSS
in1: X3/1203 ** Xsdp_inst/XFsc_inst/XPD_Costas/XPD_Arctan/X\rota2[0].U/Xsub_5119/XU1/net38 **
** X6/2728 ** in1: XSDP_OUTPUT_BT656/XVS/Xsub_17834/n12
Devices:
X3/X3210/M9(1902.300,988.930) MP(P) XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M0 MP(P)
X3/X3210/M8(1903.030,988.930) MP(P) XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M1 MP(P)
X3/X3210/M2(1903.030,990.605) MN(N) XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M3 MN(N)
X3/X3210/M3(1902.300,990.605) MN(N) XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M2 MN(N)
X3/X3210/M6(1904.800,988.400) MP(P) XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M7 MP(P)
X3/X3210/M0(1904.705,990.680) MN(N) XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M6 MN(N)
X3/X3210/M10(1901.540,989.060) MP(P) XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M9 MP(P)
X3/X3210/M4(1901.540,990.605) MN(N) XSDP_OUTPUT_BT656/XVS/Xsub_17834/XU2/M8 MN(N) |
