在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2761|回复: 2
[讨论] how DC handle multicycle path check
发表于 2018-1-27 10:49:27 | 显示全部楼层 |阅读模式
How Design compiler handle multicycle path checkfor instance, in this:
set_multicycle_path 2 -to mult/product*
DC will check setup time violations on the second capture clock rising edge, after the launch clock, right?
what about hold time violation? at the rise edge of the launch clock? or the first capture clock?
It makes more sense the first capture clock.
Do we have a way to specify to DC?
发表于 2018-1-29 13:20:27 | 显示全部楼层
你直接dc里面man set_multicycle_path
里面把setup/hold这几个参数研究一下就有的事情,有必要发一堆鸟语在论坛上吗?
 楼主| 发表于 2018-1-30 02:03:54 | 显示全部楼层
回复 2# churchmice
Thank you for your responseMy confusion came from the man page:
"If neither  -hold nor -setup are specified, path_multiplier is used
              for setup, and 0 is used for hold."
path_multiplier is used for setup, in my case 2 is easy to understand, and was just what I thought
But "0 is used for hold", does that mean DC is checking against the launch clock, rather than the 1st receiving
clock.
Is there a way in DC I could see how DC apply path_multiplier to the calculations of setup and hold check?
Many thanks
GMT+8, 2024-4-25 20:42 , Processed in 0.017656 second(s), 7 queries , Gzip On, Redis On.
