在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
返回列表 发新帖
楼主: duty001
[解决] HSPICE中如何测量单个MOSFET的阈值电压
发表于 2018-11-26 16:57:56 | 显示全部楼层
回复 1# duty001
为什么我使用lv9和vth或者vtho  print的结果不正常啊,vth是10^-29的数量级大牛您帮忙解释一下吗?
发表于 2019-6-11 17:44:00 | 显示全部楼层
零点61吧 发表于 2018-7-7 11:32
'vth0' is just a parameter in modelcard file and used to calculate electrical specs such as Ids. If  ...
Good information.
would you like to share some documents introducing these two method?
I searched two papers on internet, but have no permission to access them.
发表于 2019-6-12 14:03:40 | 显示全部楼层
"2. maximum transconductance method
Vth_gm=Vgmax-Id/gm(max)-Vd/2"
It seems there should be no "-Vd/2" in that equation ?
发表于 2019-6-20 19:38:21 | 显示全部楼层
For short channel length device, channel length modulation effect appear.
vds should be took into consideration. So there should be '- vds/2'.
发表于 2020-5-14 12:14:47 | 显示全部楼层
thanks.
发表于 2020-5-15 10:25:16 | 显示全部楼层
学习了,
发表于 2023-5-8 13:58:12 | 显示全部楼层
hello 我也想问一下这个问题,我用measure tran vth0 find lv9想测vth值,但是输出说failed
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 06:06 , Processed in 0.021903 second(s), 6 queries , Gzip On, Redis On.
