在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 971|回复: 0
[招聘] Cadence 上海招聘资深产品工程师-PHY IP
发表于 2018-1-18 13:07:40 | 显示全部楼层 |阅读模式
更多职位信息敬请关注Cadence公众微信平台:Cadence微招聘
If you have interest, PLS send your update CV to job_china@cadence.com
Principal / Lead Product Engineering -PHY/ high speedSerDes
Description:
This is a unique opportunity to join the rapidly growingProduct Engineering team in the IP Group at Cadence Design Systems. We are lookingfor a Lead Product Engineer who will be the main technical interface on keycustomer engagements deploying our advanced high speed PHY and SerDes IP.
Position is in high speed SerDes R&D team.
Primary Responsibilities:
•           Supporting customers high speed SerDes SOC integration reviews, and systemintegration questions.
•           Support customers with SerDes silicon bring up and lab testing.
•           Presales technical support of customer demos and evaluations.
•           Primary technical link between SerDes R&D team and Field ApplicationEngineers
•           Generate technical SerDes specification, data sheets, and application notes.
•           Update R&D team with the latest customer feedback and competitive analysis.
PositionRequirements:
•           M.S. Electrical/Computer Engineering (or similar degree)
•           2+ years experience developing or using high speed PHYs (8Gbps+)
•           Strong debug and problem solving skills.
•           Experience working with USB, SATA, PCIe, or Ethernet protocols.
•           Experience in SOC design implementation, from RTL to final GDS, and productionramp.
•           verilog design, simulation, and static timing experience.
•           Familiarity with industry standard DFT flows and test methodologies.
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-24 14:01 , Processed in 0.015922 second(s), 6 queries , Gzip On, Redis On.
