在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2385|回复: 1
[资料] EW103通信电子战CD
发表于 2017-12-25 23:10:35 | 显示全部楼层 |阅读模式
READ ME
This CD hasformulas which will allow you to work problems by plugging in parametric valuesand reading out the answers to mathematical procedures.  Appendix C in the EW103 text book alsocontains the instructions in the balance of this Read Me file.  The formula files on this CD require onlythat you have Microsoft Excel software on your computer, XP or compatiblerelease.
The procedure isto up-load the desired excel file to your computer hard drive, plug in therequired values in the locations, and read out the answers in the indicatedlocations.  The procedures on the CD are:
  • Line of sight loss -- one way link     equation
  • Two-ray loss -- one way link     equation
  • Knife edge diffraction loss
  • Fresnel Zone distance
  • Receiver sensitivity
  • Receiver system noise figure
  • Analog receiver dynamic range
  • Digital receiver dynamic range
  • CEP from RMS error
  • CEP from EEP
  • Communication J/S
  • Frequency spread for partial band     jamming
  • Received Power in one way link
  • Effective Range in     one way link
File LOS.xls      Lineof sight loss -- one way link equation
Input linkdistance (in km) at A4
Input frequency(in MHz) at A5
Read line of sightloss (in dB) at A10
File 2ray.xls       Two-rayloss -- one way link equation
Input transmittingantenna height (in meters) at A5
Input receivingantenna height (in meters) at A6
Read 2-ray loss(in dB) at A10
File KED.xls      Knifeedge diffraction loss
Input distancefrom transmitter to ridge line (in km) at A4
Input distancefrom ridge line to receiver (in km) at A5
Input height ofridge line (above or below line of sight – in meters) at A6
State whetherridge line is above or below line of sight (A or B) at A7
Read knife edgediffraction loss (in dB) at A10
File FZ.xls   Fresnelzone distance
Input transmittingantenna height (in meters) at A4
Input receivingantenna height (in meters) at A5
Input frequency(in MHz) at A6
Read Fresnel zonedistance (in km) at A10
File Sens.xls      Receiversensitivity
Input effectivereceiver system bandwidth (in MHz) at A4
Input system noisefigure (in dB) at A5
Input requiredpredetection signal to noise ratio at A6
Read systemsensitivity at A10
File NF.xls  Receiversystem noise figure
Input loss beforepreamplifier (in dB) at A4
Input preamplifiergain (in dB) at A5
Input preamplifiernoise figure (in dB) at A6
Input loss betweenpreamplifier and receiver (in dB) at A7
Input receivernoise figure (in dB) at A8
Read system noisefigure (in dB) at A10
File ADR.xls     Analogreceiver dynamic range
Input receiversystem sensitivity (in dBm) at A4
Insert net gainbetween receiver input and output of preamplifier (in dB) at A5
Input second orderpreamplifier second order intercept point (in dBm) at A6
Input preamplifierthird order intercept point (in dBm) at A7
Read receiversystem second order spurious free dynamic range at A10
Read receiversystem third order spurious free dynamic range at A11
File DDR.xls     Digitalreceiver dynamic range
Input number ofquantizing bits at A4
Read receiverdynamic range (in dB) at A10
File CEP_RMS.xls  CEPfrom RMS error
Input RMS error(in degrees) at A4
Input range fromboth DF sites (in km) at A5
Read CEP (in km)at A10
File CEP_EEP.xls    CEPfrom EEP
Input long axis ofEEP (in km) at A4
Input short axisof EEP (in km) at A5
File JtoS.xls       CommunicationJ/S
Input ERP ofdesired signal transmitter (in dBm) at A4
Input ERP ofjammer (in dBm) at A5
Input desiredsignal transmit antenna height (in meters) at A6
Input jammerantenna height (in meters) at A7
Input receiverantenna height (in meters) at A8
Input frequency(in MHz) at A9
Input targetreceiving antenna gain toward desired signal transmitter (in dB) at A10
Input target receivingantenna gain toward jammer (in dB) at A11
Read jamming to signalratio (J/S) (in dB) at A14
File PBJ.xls       Frequencyspread for partial band jamming
Input targetsignal information bandwidth (in kHz) at A4
Input targetsignal hopping range (in MHz) at A5
Input singlechannel J/S (in dB) at A6
Read optimumjamming bandwidth (in MHz) at A10
Read jamming dutycycle (in %) at A11
File RcvPwr.xls  ReceivedPower in one way link
Input linkdistance( in km) at A4
Input frequency (inMHz) at A7
Read receivedsignal power (in dBm) at A10
File EffRng.xls   Effective range in one way link
Note that thisfile determines the propagation mode (Line of Sight or 2 Ray) and calculatesthe effective range.  This assumes thatwide beam-width antennas are used and that the terrain is clear.  If antennas are directional or propagation isdown a valley, the effective range is the “LOS distance.”    Atmospheric and rain attenuation are notincluded.
Input transmitterpower (in dBm) at A5
Input transmitantenna gain toward receiver (in dB) at A6
Input receivingantenna gain toward transmitter (in dB) at A7.
Input transmitterantenna height (in meters) at A8
Input receivingantenna height (in meters) at A9
Input frequency(in MHz) at A10
Input receiversystem sensitivity (in dBm) at A11
Read effectiverange (in km) at A18
With narrowantennas or propagation down a valley read effective range (LOS) at B18
formulas.rar
31.57 KB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2018-10-8 17:17:49 | 显示全部楼层
谢谢分享!!!
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 04:16 , Processed in 0.016874 second(s), 7 queries , Gzip On, Redis On.
